WireGuard automated installer | Ubuntu, Debian, CentOS, Fedora
Lightweight WireGuard installer, written entirely in bash.
GitHub:
https://github.com/Nyr/wireguard-install
One-liner:
wget https://github.com/Nyr/wireguard-install/raw/master/wireguard-install.sh && bash wireguard-install.sh
Supported distros:
- Ubuntu
- Debian
- Centos
- Fedora
- AlmaLinux
- Rocky Linux
FAQ:
Will it work in my Raspberry Pi?
Probably, I don't have one to test. Install the raspberrypi-kernel-headers package and hope for the best. But you should consider using a distribution with built-in kernel support when it becomes available.
OpenVZ support?
Yes, via boringtun.
Can you add x feature?
Maybe, if it's worth it. But I'll keep the installer simple and functional, so keep that in mind. Niche features are unlikely to be implemented.
I like the project, how can I help?
Tell other people about it! wireguard-install is new and many people do not yet know about it. Some other low-quality tools based on my openvpn-install work exist, with credits and copyright notices removed. It's a sad sight to me after nearly a decade maintaining openvpn-install.
How about IPv6? Is there an Angristan variant that does?
IPv6 is natively supported, same as openvpn-install.
None of my work has anything to do with him, he just created a dubious quality fork of my OpenVPN installer and last I checked, he was getting funded on Patreon for it. Attention to detail between the original work and the copy just can't be compared. One was created by someone who is competent at networking, security and system administration and the other was forked by someone who wanted a "secure" version of my work because the default RSA key length was "insecure" for him.
I'm sorry, I was attempting to tease you. I had no idea the asshole was making money from this.
No problem man
I've used your openvpn script more times than I can count for a quick VPN setup because it's just so easy, glad you've branched into wireguard too. Nice work!
Thanks for sharing!
Tweeted, will RS via my main account tomoz.
Thank you very much for spending time into doing this. I've used your openvpn script many times in the past.
Thanks.
I am using this https://github.com/complexorganizations/wireguard-manager/blob/master/.github/README.md
Was waiting for your one.
@Nyr can have have a look at the above script if you have time?
That repository is based on Angristan+l-n-s, both of them are forks of my original work and the author is either unaware or trying to hide that fact. But whatever it is, my original copyright is not being respected. I will not go into the technical part of the scripts here, already did that over at LET in case you are interested, but his repo is forked from Angristan so to put it short I'd suggest not to waste your time.
If you want to experiment with other VPN installers, I'd suggest looking at the following ones:
https://github.com/StreisandEffect/streisand
https://github.com/trailofbits/algo
They use very different approaches than my minimalist bash script but work reasonably well and are well maintained by technically competent people. I'm sure there are even more options, but that's what I am aware of
Got it.
Thanks. @Nyr
I tried it first time and it looks good. Please tell me, are my ports settings good? Add or remove anything? suggestion?
⚆ ͜ʖ ͡⚆ Thanked by (1281): verjinOnly UDP is required, you can remove the TCP port
@Nyr I am searching for wg API which automates account creation or in short perform CRUD.
Do you know any? Right now I am looking at github.com/alectrocute/wg-api (beta) and github.com/suquant/wgrest (limited functionality)
⚆ ͜ʖ ͡⚆ Thanked by (1281): verjinNyr da MVP!
Trying this out on a vultr throwaway, before deploying to one of my 1Eur Arubacloud idlers. (2left)
You already know more than me! I'm new to the whole WireGuard scene and not familiar with third party projects (yet).
I have something bookmarked for this.
Here it is: Subspace
It's crazy how well this WireGuard vpn performs, thanks for sharing the script @Nyr !!
Owned-Networks | VPS and Web Hosting for every project size and budget
DAL - LEN - LA - SEA - NYC - MIA - AMS - LON
Not sure if subspace still maintained, last I saw it there were multiple unsolved issues.
Until I read this thread, I’d somehow managed to miss wireguard going v1, so thanks!
Great @Nyr
If 127.0.0.1 is chosen for DNS, will users use the Unbound resolver on the server ?
@Nyr It would be great if you included Unbound on this script
What's Min ram on KVM vps required to work well?
@cybertech
Worked on 512mb KVM.
Wireguard Go works on 128mb ovz
The script looks pretty good... Nice work.
I've got WireGuard running on a 256 MB KVM with no issues. On Linux, at runtime it's just a kernel module so the memory requirements are lower than other VPN apps that need userland apps to be running.
automagically both IPv4/IPv6 working
The "current system resolvers" option means exactly that: the resolvers currently used by the system, whatever it is in resolv.conf. So that's not necessarily 127.0.0.1, and even if it is, 127.0.0.1 would of course not be valid for VPN clients.
With that said, with WireGuard the DNS configuration is directly in the client.conf file, so you can easily configure 10.0.7.1 which is the server address.
Would you want the script to set up a recursor, or to integrate with an already running one? The second is very easy, read my comment just above this.
That depends on the OS and other factors, but others already explained what to expect. If you have only 256 MB, I'd suggest to use Debian.
Works like a charm. And WireGuard is much faster than OpenVPS. Double the throughput.
Thanks for this script @Nyr
Used this to setup my vpn. Worked flawlessly, thanks.
Cloudflare DNS is good and no logging policy so it's OK to use them. Great option for small VPS!
Unbound DNS is lightweight, I would go with unbound if my VPS had more than 512 MB RAM
