Removing duplicated files in server
I have a wordpress install with heaps of duplicated images and file uploads, really, its a mess.
Need to reduce the size of the website and I thought I could run a bash script to remove the duplicated files and replace them with hard links.
Now, would this work?  has anyone attempted before?
sha256sum your files, compare. Obviously check sizes/etc, but a collision is not horribly likely. I'd suggest a soft link.
If you do not need files to be able to diverge later, then yes it would work - relatively straightforward, see above.
Otherwise you need some pro dedup tool (or filesystem).
I have used
fdupesin the past with some success. You could setup a script/line to remove any, but I generally just have the output put into a text file to manually review before removing anythingIncrease disk space and forget it.
I remember going through a similar thing about 10 years ago, it did not end well.
Another possibility is to copy/rebase onto a btrfs filesystem and use bedup (extent-panel dedup). Then you get copy-on-write if you need to make modifications. ZFS is another option.
I disagree.
You need to increase website size.
The bigger the wordpress, the stronger you become.
I have used fslint and it worked for me.
