You can open tickets you just need to fill in a box to confirm, thats the same box that asks you to read the announcements before opening a ticket and there has been an announcement up about it for about 3 hours now regarding ipv6, it will be back up by the end of the day, a number of hosts in Clouvider DC are impacted.
I am checking now, span up a test VM, what I am 99% sure I am seeing is just ICMP queuing, I cannot see any issues with TCP, are you monitoring over ICMP only as well?
IPv6 is down again for me at the moment. I'm still a bit unsure about ticket vs. forum, but since I do not consider this an "emergency", I'll leave it here for now.
yep, just recovering from an attack from China, most nodes have IPv6 again, the NAT service is not playing ball, looks like the whole node has got itself in a twist, rebooting the whole node atm.
@Brueggus said: IPv6 is down again for me at the moment. I'm still a bit unsure about ticket vs. forum, but since I do not consider this an "emergency", I'll leave it here for now.
Finally sorted, I can go to bed now for a few hours.
BUT MY 32MB OVZ6 REEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
Anthony, you are amazing. Thanks for the effort you put into LES.
https://clients.inceptionhosting.com/announcements.php
Also displayed on the first page after logging in to the client area to open a ticket.
Are you fucking kidding me, I've been banging my head against IPv6 not working for two hours lmao
Fixed.
[vpsadmin ~]$ ssh -6 vps15.bxxxxx ssh: connect to host vps15.bxxxxxx port 22: Permission denied
Is incoming traffic blocked now?
Or... is tcp/udp traffic blocked?
Working now?
Yep, thanks, Anthony!
Since IPv6 connectivity was restore, I'm having significant packet loss on my VPS (but probably all are affected...)
Any idea?
I'm affected too
Pop a ticket in.
I used to monitor over UDP and switched to TCP yesterday around noon. I'm still having the same amount of packet loss.
Let me take a look in to this further then.
@Brueggus some settings tweaked, can you check now please although this really only should have been impacting ping/icmp.
Yes, i guess i shouldn't be worried then?
tweaks have been tweaked, see if thats better for you.
I'd say it looks much better now, there are no more gaps in the graphs. I'll check again in an hour or two.
Thanks a bunch!
No matter what a provider says, down time is always a good reason to open a ticket (after reading announcements).
yep.
My internal IP:
10.10.100.80
. mtrs below:dnscry.pt - Public DNSCrypt resolvers hosted by LowEnd providers • Need a free NAT LXC? -> https://microlxc.net/
You missed an E, totally changed the whole meme
Sorry,
My bandwidth failed. I'm using Acorn with two serial inputs and sometimes charactrs get dropd.
