What's the real speed of NVMe?
I saw a lot of benchmark (mostly VPS) and there were almost no difference between SSD and NVMe speed in yet-another-bench-sript. But people still instist that NVMe is way better and you have to use NVMe if you want your site working faster. Is it still true?
For example:
This is NVMe
Block Size | 4kb           (IOPS) | 64kb          (IOPS)
Read       | 127.80 MB/s  (31.9k) | 1.73 GB/s    (27.0k)
Write      | 128.13 MB/s  (32.0k) | 1.74 GB/s    (27.2k)
Total      | 255.93 MB/s  (63.9k) | 3.47 GB/s    (54.2k)
Block Size | 512kb         (IOPS) | 1mb           (IOPS)
Read       | 3.21 GB/s     (6.2k) | 3.27 GB/s     (3.1k)
Write      | 3.38 GB/s     (6.6k) | 3.49 GB/s     (3.4k)
Total      | 6.59 GB/s    (12.8k) | 6.76 GB/s     (6.6k)
This is SSD
Read       | 120.22 MB/s  (30.2k) | 1.69 GB/s    (26.8k)
Write      | 120.25 MB/s  (30.2k) | 1.69 GB/s    (26.8k)
Total      | 240.47 MB/s  (60.4k) | 3.38 GB/s    (53.6k)
Read       | 3.29 GB/s     (6.3k) | 3.17 GB/s     (3.1k)
Write      | 3.41 GB/s     (6.5k) | 3.28 GB/s     (3.4k)
Total      | 6.70 GB/s    (12.8k) | 6.76 GB/s     (6.5k)
Yes I know it also depends on how many clients split the disk but...
Sigh, benchmark junkies.
Use common sense and perhaps a little bit of logic.
For the sake of this discussion ssd and nvme only differ in the way they connect to the system: sas/sata vs pci.
This means if you are not reaching the limits of sata you won't see the difference.
Both of the results you posted are most definitely hitting a ram cache.
NVMe is a bit of a safer bet that you will have the iops available even after the node is loaded up. A well managed box with SSD storage at a good provider can work as well/better though. All comes down to how noisy your neighbors are.
see also:
https://en.wikipedia.org/wiki/SATA_Express
Yes
Those numbers seem unlikely - even the gen 4 pcie drives are like 5 gb/s max. Well the consumer tech anyway
