Inception UK ipv6 down
Been down for my vps for 6 hours. Any other Inception UK customers seeing this? (Can't report to Inception due to covid-19 no support)
    edited April 2020
    You can open tickets you just need to fill in a box to confirm, thats the same box that asks you to read the announcements before opening a ticket and there has been an announcement up about it for about 3 hours now regarding ipv6, it will be back up by the end of the day, a number of hosts in Clouvider DC are impacted.
    https://clients.inceptionhosting.com/announcements.php
    Also displayed on the first page after logging in to the client area to open a ticket.
    Thanked by (1)AlwaysSkint
  • Are you fucking kidding me, I've been banging my head against IPv6 not working for two hours lmao
    Fixed.
    Thanked by (1)vpsgeek3333
  • edited April 2020
    Fixed.
    [vpsadmin ~]$ ssh -6 vps15.bxxxxx ssh: connect to host vps15.bxxxxxx port 22: Permission denied
    Is incoming traffic blocked now?
    Or... is tcp/udp traffic blocked?
    [root@vps15 ~]# curl -6 ifconfig.co
    curl: (7) couldn't connect to host
    [root@vps15 ~]# ping6 !$
    ping6 ifconfig.co
    PING ifconfig.co(2606:4700:3039::681f:ef0a) 56 data bytes
    64 bytes from 2606:4700:3039::681f:ef0a: icmp_seq=1 ttl=56 time=1.83 ms
    64 bytes from 2606:4700:3039::681f:ef0a: icmp_seq=2 ttl=56 time=1.93 ms
    ^C
    --- ifconfig.co ping statistics ---
    2 packets transmitted, 2 received, 0% packet loss, time 1320ms
    rtt min/avg/max/mdev = 1.837/1.888/1.939/0.051 ms
    ping6 ifconfig.co
    ^C
    Working now?
    2a04:92c7:e:ca3::6d42
  • @AnthonySmith said: Working now?
    Yep, thanks, Anthony!
  • Since IPv6 connectivity was restore, I'm having significant packet loss on my VPS (but probably all are affected...)
    Any idea?
    outgoing:
     Host        Loss%   Snt   Last   Avg  Best  Wrst StDev
     1. 2a04:92c7:e:ca3:x:xxx        40.5%   612    0.8   1.6   0.5  46.2   3.0
     2. 2a04:92c5:0:64::1        18.8%   612   14.0  11.8   1.8 667.0  48.8
     3. 2a04:92c0::4        8.0%   612    6.0  13.7   1.4 563.6  44.8
     4. 2a04:92c0::9        6.0%   612   16.0  11.4   0.8 951.9  51.8
     5. lonap.thn2.peering.clouvider.net        6.4%   612    5.0   8.9   1.6 850.7  42.3
     6. e0-35.core3.lon1.he.net        5.9%   612   11.0  18.1   7.1 861.8  57.1
     7. 100ge7-2.core1.lon2.he.net        14.1%   611    3.9  12.2   1.3 891.9  63.5
     8. 100ge13-2.core1.nyc4.he.net        6.4%   611   91.1  78.2  69.5 771.1  46.2
     9. tserv1.nyc4.he.net        6.2%   611   74.5  84.0  71.7 1241.  70.0
    10. xxxxxxxxxxxxxxxxxxx        6.4%   611   95.7  91.1  69.5 898.1  60.0
     1. 2a04:92c7:e:ca3:x:xxxx        49.1%   553    1.3   1.4   0.5  12.1   1.4
     2. 2a04:92c5:0:64::1        16.3%   553    2.8   9.6   2.0 767.6  44.3
     3. 2a04:92c0::4        8.1%   553    2.2  12.9   1.6 706.4  42.8
     4. 2a04:92c0::9        7.4%   553    3.9  13.9   1.0 968.1  65.9
     5. 2001:418:16::103        7.4%   553    2.2  11.8   1.8 914.5  60.0
     6. ldn-b1-link.telia.net        57.9%   553    2.7   9.7   1.4 860.8  58.5
     7. ldn-bb4-v6.telia.net        97.3%   553   19.0  20.9  18.2  42.2   6.1
     8. prs-bb4-v6.telia.net        96.6%   553   19.8  26.2  18.2  86.0  16.1
     9. ffm-bb4-v6.telia.net        6.9%   553   18.1  28.4  17.6 924.9  71.4
    10. ffm-b1-v6.telia.net        7.1%   553   20.0  31.3  18.7 870.5  66.3
    11. as33891-ic-331888-ffm-b1.c.telia.net        7.1%   553   19.3  26.8  15.6 815.6  65.5
    12. 2a01:4a0:0:2021::3        7.2%   553   16.8  27.2  15.8 760.9  59.2
    13. 2a01:4a0:0:2071::33        7.4%   553   18.4  25.7  15.6 706.4  54.3
    14. 2a01:4a0:1338:6a::2        7.4%   553   20.1  26.5  18.4 651.9  47.7
    15. po8.core1-dus3.bb.as24961.net        7.2%   553   20.3  26.4  18.7 598.2  44.2
    16. po10.agr1-dus3.bb.as24961.net        7.4%   553   20.6  32.1  20.1 1635.  85.3
    17. po2.edge1-dus6.bb.as24961.net        7.4%   553   21.8  34.6  20.1 601.5  43.6
    18. 2001:4ba0:92f3:4a::2        7.4%   553   19.6  26.2  18.7 537.0  36.1
    19. 2a0f:5707:aa81:ffff:ffff:xxxx:xxxx:xxxxx        7.2%   553   19.8  26.1  19.3 483.1  31.4
    incoming
     1. tunnel379778.tunnel.tserv4.nyc4.ipv6.he.net        0.0%   520    6.5  14.5   3.7 158.7  20.0
     2. ve422.core1.nyc4.he.net        0.0%   520    6.8  11.5   1.4 153.5  22.6
     3. 100ge16-2.core1.lon2.he.net        0.6%   520   69.5  84.3  68.3 257.4  29.0
     4. linx-lon1.thn2.peering6.clouvider.net        0.0%   520   68.1  83.4  67.4 251.3  30.4
     5. ???
     6. 2a04:92c1:1:7::11        0.0%   520   69.9  83.8  67.9 343.2  30.6
     7. 2a04:92c0::a        0.0%   519   96.6  83.1  68.5 257.7  25.3
     8. 2a04:92c0::5        11.2%   519   70.4  84.6  69.8 246.4  28.4
     9. 2a04:92c7:e::1        9.4%   519   70.2  82.0  67.7 244.6  29.0
    10. 2a04:92c7:e:ca3::6d42        6.9%   519   70.3  96.7  69.5 1849. 113.9
    11. 2a04:92c7:e:6be:xx:xx        6.9%   519  118.7  93.9  69.3 1755. 103.7
  • I'm affected too
    Any idea?
    outgoing:
    incoming
     5. ???
    Pop a ticket in.
    edited May 2020
    @foxone said:
    I'm affected too
    I am checking now, span up a test VM, what I am 99% sure I am seeing is just ICMP queuing, I cannot see any issues with TCP, are you monitoring over ICMP only as well?
  • @AnthonySmith said: I cannot see any issues with TCP, are you monitoring over ICMP only as well?
    I used to monitor over UDP and switched to TCP yesterday around noon. I'm still having the same amount of packet loss.
    @Brueggus said: I used to monitor over UDP and switched to TCP yesterday around noon. I'm still having the same amount of packet loss.
    Let me take a look in to this further then.
    Thanked by (1)Brueggus
    @Brueggus some settings tweaked, can you check now please although this really only should have been impacting ping/icmp.
    Yes, i guess i shouldn't be worried then?
    @foxone said: Yes, i guess i shouldn't be worried then?
    tweaks have been tweaked, see if thats better for you.
    I'd say it looks much better now, there are no more gaps in the graphs. I'll check again in an hour or two.
    Thanks a bunch!
    No matter what a provider says, down time is always a good reason to open a ticket (after reading announcements).
    @sureiam said: No matter what a provider says, down time is always a good reason to open a ticket (after reading announcements).
    yep.
  • IPv6 is down again for me at the moment. I'm still a bit unsure about ticket vs. forum, but since I do not consider this an "emergency", I'll leave it here for now.
    My internal IP: 10.10.100.80. mtrs below:
    outgoing:
      1. 2a04:92c7:x:xxx::6d42  0.0%    10    2.8   1.6   0.9   2.8   0.7
      2. ???                   100.0    10    0.0   0.0   0.0   0.0   0.0
    incoming:
      1.|-- 2a00:c70:1:213:246:xx:xxx:1            0.0%    10    0.3   0.3   0.3   0.4   0.0
      2.|-- ikoula.demarc.cogentco.com             0.0%    10    1.6   3.0   1.3  12.2   3.5
      3.|-- 2a00:c70::1:16                         0.0%    10    1.3  86.3   1.2 434.5 178.6
      4.|-- 2001:7f8:1::a502:1409:1                0.0%    10    3.2  37.4   3.1 337.5 105.5
      5.|-- 10gigabitethernet-2-2.par2.he.net      0.0%    10    2.7  11.1   2.6  25.1   9.7
      6.|-- 100ge11-1.core1.lon2.he.net            0.0%    10   29.9  14.4  10.7  29.9   5.9
      7.|-- linx-lon1.thn2.peering6.clouvider.net  0.0%    10   11.0  11.7  11.0  15.8   1.4
      8.|-- ???                                   100.0    10    0.0   0.0   0.0   0.0   0.0
      9.|-- 2a04:92c1:1:7::11                      0.0%    10   11.6  11.9  11.3  16.0   1.4
     10.|-- 2a04:92c0::a                           0.0%    10   29.1  17.3  11.9  29.1   5.8
     11.|-- 2a04:92c0::5                           0.0%    10   12.4  15.9  12.0  30.3   5.6
     12.|-- 2a04:92c7:e::1                         0.0%    10   11.5  11.4  11.2  12.0   0.0
     13.|-- ???                                   100.0    10    0.0   0.0   0.0   0.0   0.0
    outgoing:
    incoming:
    yep, just recovering from an attack from China, most nodes have IPv6 again, the NAT service is not playing ball, looks like the whole node has got itself in a twist, rebooting the whole node atm.
    @Brueggus said: IPv6 is down again for me at the moment. I'm still a bit unsure about ticket vs. forum, but since I do not consider this an "emergency", I'll leave it here for now.
    Finally sorted, I can go to bed now for a few hours.
  • WSSWSS Retired
    BUT MY 32MB OVZ6 REEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
    Thanked by (1)Dream
    You missed an E, totally changed the whole meme
    Thanked by (1)Dream
  • WSSWSS Retired
    Sorry,
    My bandwidth failed. I'm using Acorn with two serial inputs and sometimes charactrs get dropd.
    Anthony, you are amazing. Thanks for the effort you put into LES.
