Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Hitachi/HGST Ultrastar 7K4000
Device Model: HGST HUS724020ALA640
Serial Number: PN2181P6J3Z9XP
LU WWN Device Id: 5 000cca 22dddfdf0
Firmware Version: MF6OABY0
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue May 26 10:43:55 2020 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Thanks a lot Iroshan464. The information is enough for me. It is like a mini netbook but with a larger disk The configuration appears to be good for certain types of systems.
The wise receive respect. The dumb demand respect.
150-180MB/s if it's an enterprise drive.
What's there to say?
Also 150 IOPS maybe
I think I have a KS3.
Let me check.
A simple netbook. ?
Thank you very much for the data.
If it is not a great trouble, could you please post the output of "smartctl -i /dev/sda"?
