@ehab said: @imok take it you, will not get a better price/spec ... i only know @georgedatacenter who can may get close. never tried the Hotlineservers before but you can't loose if its a monthly price.
Thanks,we don't have stock in Dallas, but I'll leave you this test
CPU model : Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
Number of cores : 2
CPU frequency : 2600.000 MHz
Total size of Disk : 22.5 GB (11.1 GB Used)
Total amount of Mem : 2005 MB (366 MB Used)
Total amount of Swap : 2559 MB (8 MB Used)
System uptime : 0 days, 0 hour 46 min
Load average : 0.01, 0.27, 0.32
OS : CentOS 6.10
Arch : x86_64 (64 Bit)
Kernel : 2.6.32-754.el6.x86_64
I/O speed(1st run) : 318 MB/s
I/O speed(2nd run) : 492 MB/s
I/O speed(3rd run) : 480 MB/s
Average I/O speed : 430.0 MB/s
Node Name IPv4 address Download Speed
CacheFly 205.234.175.175 82.1MB/s
Linode, Tokyo2, JP 139.162.65.37 11.7MB/s
Linode, Singapore, SG 139.162.23.4 6.72MB/s
Linode, London, UK 176.58.107.39 13.3MB/s
Linode, Frankfurt, DE 139.162.130.8 11.1MB/s
Linode, Fremont, CA 50.116.14.9 32.4MB/s
Softlayer, Dallas, TX 173.192.68.18 78.3MB/s
Softlayer, Seattle, WA 67.228.112.250 34.2MB/s
Softlayer, Frankfurt, DE 159.122.69.4 11.8MB/s
Softlayer, Singapore, SG 119.81.28.170 8.44MB/s
Softlayer, HongKong, CN 119.81.130.170 9.31MB/s
Hosted by Windstream (Dallas, TX) [8.01 km]: 4.73 ms
Testing download speed................................................................................
Download: 921.58 Mbit/s
Testing upload speed................................................................................................
Upload: 182.78 Mbit/s
skipped
@cybertech
Underwhelming, isn't it?
Seems like the frankfurt node. It should be doing better then that.
It's chicago.
I updated and redid.
Geekbench v4 CPU Benchmark:
Single Core : 2299 (FAIR)
Multi Core : 8143
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 537
Multi Core | 1863
Full Test | https://browser.geekbench.com/v5/cpu/2431390
What did I do wrong?
NY Node.
Geekbench looks good to me, cpu is a bit old but result is fine.
I think CPU works as expected; it's a 2660v2 after all. (Don't know if 2660 is better than 2650 though)
I wouldn't have expected Gold/Ryzen for this price either.
It's a good LES exclusive deal considering price, big ram/ssd and dedicated CPU resources.
Here's one in comparison not dedicated CPU:
--------------------------------------------------------------------------- OS : CentOS 8.1.1911 (64 Bit) Virt/Kernel : KVM / 5.6.12-1.el8.elrepo.x86_64 CPU Model : Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz CPU Cores : 4 @ 2599.998 MHz x86_64 16384 KB Cache CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled Load Average : 0.14, 0.04, 0.01 Total Space : 39G (2.5G ~7% used) Total RAM : 7959 MB (212 MB + 1372 MB Buff in use) Total SWAP : 1023 MB (0 MB in use) Uptime : 23 days 9:48 --------------------------------------------------------------------------- ASN & ISP : AS40676, Psychz Networks Organization : SmartHost LLC Location : Chinchilla, United States / US Region : Pennsylvania --------------------------------------------------------------------------- ## Geekbench v4 CPU Benchmark: Single Core : 2608 (GOOD) Multi Core : 8009 ## IO Test CPU Speed: bzip2 : 88.5 MB/s sha256 : 215 MB/s md5sum : 442 MB/s RAM Speed: Avg. write : 1754.7 MB/s Avg. read : 5051.7 MB/s Disk Speed: 1st run : 853 MB/s 2nd run : 878 MB/s 3rd run : 865 MB/s ----------------------- Average : 865.3 MB/s ## Global Speedtest Location Upload Download Ping --------------------------------------------------------------------------- Speedtest.net 229.56 Mbit/s 209.00 Mbit/s 46.95 ms USA, Chicago (Windstream) 296.37 Mbit/s 169.90 Mbit/s 46.504 ms USA, Dallas (Frontier) 351.08 Mbit/s 332.44 Mbit/s 28.241 ms USA, Los Angeles (Spectrum) 533.01 Mbit/s 727.88 Mbit/s 3.696 ms --------------------------------------------------------------------------- Finished in : 5 min 1 sec Timestamp : 2020-06-07 01:34:34 GMTI bench YABS 24/7/365 unless it's a leap year.
What's the price tag on that box @cybertech?
Thanks @cybertech
I'll hang on to this. ?
6.95
That's a nice box for the price. You got a good deal.
George Datacenter LLC
www.georgedatacenter.com
Not really, sorry. The next step on disk upgrade is unfortunately 180 GB.
Grabbed one with 90GB anyway. It's working fine.
