@verjin said:
Is there any limit on number of emails and size? (I need to transfer 10GB of emails)
As far as I know, there is only a limit on the number of accounts that you can backup at the same time. But that shouldn't be a problem with your use case.
IMAPSYNC
If you need someone to do this for you, email migration is a service that I provide.
got outlook? if so just drag and drop, done.
This works with Thunderbird too.
I used "MailStore Home" (https://www.mailstore.com/en/products/mailstore-home/) for this quite a few times lately, worked great!
Just did a backup on the old an then restored it to the new server instead.
⚆ ͜ʖ ͡⚆ Thanked by (1281): verjinAs far as I know, there is only a limit on the number of accounts that you can backup at the same time. But that shouldn't be a problem with your use case.
I usually use the docker version of Imapsync but this would work if you need GUI https://imapsync.lamiral.info/X/
Yes, using this and transfer is in process. But its taking time (4 emails per 2 seconds). In docker is it fast?
⚆ ͜ʖ ͡⚆ Thanked by (1281): verjinNope. It all depends upon the receiving server.
It depends on the following points between your mail servers (original and new server) and the server you're using for transferring the mail.
