@verjin said:
Is there any limit on number of emails and size? (I need to transfer 10GB of emails)
As far as I know, there is only a limit on the number of accounts that you can backup at the same time. But that shouldn't be a problem with your use case.
IMAPSYNC
If you need someone to do this for you, email migration is a service that I provide.
got outlook? if so just drag and drop, done.
This works with Thunderbird too.
I used "MailStore Home" (https://www.mailstore.com/en/products/mailstore-home/) for this quite a few times lately, worked great!
Just did a backup on the old an then restored it to the new server instead.
I usually use the docker version of Imapsync but this would work if you need GUI https://imapsync.lamiral.info/X/
Yes, using this and transfer is in process. But its taking time (4 emails per 2 seconds). In docker is it fast?
Nope. It all depends upon the receiving server.
It depends on the following points between your mail servers (original and new server) and the server you're using for transferring the mail.
