@Mason said:
New Launch Dedi in NYC with Clouvider
What do you guys do with those dedis? Just curious. Some people buy dedis cause they're more private. You too or your project just needs it?
This particular server is taking over as my main Plex server. The i7-6700k that I currently have is struggling to keep up with the number of concurrent streams/transcodes. Dom enabled the iGPU for me, so I can now take advantage of hardware encoding/decoding (via Intel Quick Sync), which will easily be able to keep up with the demand.
Hey all, I just pushed some minor updates to the YABS repo. Summary of changes below. Please give me a shout if anyone hits any issues with the script! We had 234 script runs yesterday (first time it's been over 200), which I thought was pretty cool! Thanks for giving this script a go, I hope you guys have found it informative and useful!
2020-06-20 YABS Updates
added ctrl+c handler that catches interrupt signal to cleanly exit script and remove any script files to reduce leftover clutter
refactored code for fio tests to be able to easily allow additional (or reduced) block sizes to evaluate (may potentially add a flag to change the block sizes or allow a custom array as input in the future)
added "-9" flag to allow BOTH geekbench 4 AND geekbench 5 tests to be run during the same script run (4+5=9)
updated geekbench 4 and 5 download links to the latest available (GB4: v4.3.3 -> v4.4.2; GB5: v5.1.0 -> 5.2.0)
This one, Infra-2-LE? https://www.ovh.com/world/dedicated-servers/infra/infra-limited-edition-2/
Thanks!
MetalVPS
Yep.
ExtraVM - High RAM Specials
Yours truly.
New Launch Dedi in NYC with Clouvider. Damn this thing is awesome!
dododododododoo
Whoa! Who/ What/Where is this beast?
VPS reviews and benchmarks |
Very soon...
@WSCallum
So day after tomorrow. ?
Don't forget a nice deal for LES. ?
What package is this? Location? So many core, so wow
It died actually
Migrated to a node with no passthrough
Fun but it's come to an end
Avoid at (no) all cost
Why? What's the problem? I have three servers with them, and no problem so far tbh
Just be cautious on what runs on them; mine was killed for no reason, then migrated to a different node, and was down twice after.
It's fun for low price but ain't nobody got time fo dat
Which vps/ location?
I believe UK, anyway not renewing
Edit maybe it's Macedonia
Has this happened? Thanks!
MetalVPS
Delayed slightly Tom sadly, DC issues announcing IP space annoyingly. There'll be an offer here as soon as they're up
Azure Standard DS3 v2 (4 vcpus, 14 GiB memory)
Example output using my laptop on my home wifi
Our 4GB plan in our new Montreal Canada location.
[root@test ~]# curl -s https://raw.githubusercontent.com/masonr/yet-another-benc h-script/master/yabs.sh | bash
Yet-Another-Bench-Script
v2020-06-20
Sat Jun 20 18:14:17 EDT 2020
Processor : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
CPU cores : 2 @ 2599.998 MHz
AES-NI : ✔ Enabled
RAM : 3.7G
Swap : 1.0G
Disk : 78G
Provider | Location (Link) | Send Speed | Recv S peed
Bouygues Telecom | Paris, FR (10G) | 872 Mbits/sec | 266 Mb its/sec
Online.net | Paris, FR (10G) | 893 Mbits/sec | 274 Mb its/sec
WorldStream | The Netherlands (10G) | 875 Mbits/sec | 323 Mb its/sec
wilhelm.tel | Hamburg, DE (10G) | 869 Mbits/sec | 245 Mb its/sec
Biznet | Bogor, Indonesia (1G) | 618 Mbits/sec | 85.5 M bits/sec
Hostkey | Moscow, RU (1G) | 774 Mbits/sec | 870 Mb its/sec
Velocity Online | Tallahassee, FL, US (10G) | 276 Mbits/sec | 105 Mb its/sec
Performing IPv4 iperf3 send test to Airstream Communications (Attempt #1 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #2 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #3 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #4 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #5 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #6 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #7 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #8 of 10). Performing IPv4 iperf3 send test to Airstream Communications (Attempt #9 of 10). Airstream Communications | Eau Claire, WI, US (10G) | busy | busy
Hurricane Electric | Fremont, CA, US (10G) | 909 Mbits/sec | 414 Mbits/sec
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 632
Multi Core | 1146
Full Test | https://browser.geekbench.com/v5/cpu/2620058
That's a nice bench. Which vps provider?
4cores deal not coming back sir?
@Mason
Trying the new script, if only elevator music played some real music
Tetahost
Yes there are few added now.
New script on readydedis
Hotlineservers
Canada Montreal
Hotlineservers Montreal
@cybertech you too migrated to Montreal?
Never tried Montreal before, first time
And some Yabba Dabba Doo
