Any Promox VM NAT dummy guide?
Haven't been able to get my NAT VMs to connect to internet.
Hoping to get pointed to a nice guide that you have.
Proxmox/Ubuntu/NAT dummy here :tongue:
    edited July 2020
    I just have a separate bridge for NAT VMs.
    auto vmbr1
    iface vmbr1 inet static
        address <first_usable_internal_ip>/<netmask>
        bridge_ports none
        bridge_stp off
        bridge_fd 0
        # Set up NAT for this bridge
        post-up echo 1 > /proc/sys/net/ipv4/ip_forward
        post-up iptables -t nat -A POSTROUTING -s '<first_internal_ip>/<netmask>' -o <public_if> -j SNAT --to <pubic_ip>
        post-down iptables -t nat -D POSTROUTING -s '<first_internal_ip>/<netmask>' -o <public_if> -j SNAT --to <pubic_ip>
        post-down echo 0 > /proc/sys/net/ipv4/ip_forward
        #Port Forwarding Rules
        iptables -t nat -A PREROUTING -p tcp --dport <port> -j DNAT --to-destination <internal_vm_ip>:<port>
        iptables -t nat -A POSTROUTING -p tcp --sport <port> -s <internal_vm_ip>: -j SNAT --to-source <public_ip>:<port>
    auto vmbr1
        bridge_ports none
        bridge_stp off
        bridge_fd 0
    Anything else needed to be done on the NAT VM?
  • I just get a second IPv4 address, and give it to pfSense, and let it do NAT.
    Thanked by (1)cybertech
    Just set the netmask and put in an IP from the internal subnet in the network config, and you should be golden.
    That's what I do at home too (except the second IP).
    I kinda did that too, just gonna try again heh. Thanks.
    If it didn't work, try pinging the IP that's assigned to the bridge.
    ping internal IP from the host?
    Whoops, I mean, ping the IP from the VM. That same IP should also be the gateway for the network config inside the VM.
  • Who is the provider? What is the Server?
  • @cybertech's guide should cover it. That's all you need to do.
    Thanks everyone for the guides, read all of them and could get my NAT VM to access internet.
    Now for accessing SSH NAT VM via port 1234 from outside, I'm stuck. is this correct?
    auto vmbr1
            address 192.168.1.1/24
            bridge-ports none
            bridge-stp off
            bridge-fd 0
            post-up iptables -t nat -A POSTROUTING -s '192.168.1.0/24' -o vmbr0 -j SNAT --to (my public IPv4)
            post-down iptables -t nat -D POSTROUTING -s '192.168.1.0/24' -o vmbr0 -j SNAT --to  (my public IPv4)
            iptables -t nat -A PREROUTING -p tcp --dport 1234 -j DNAT --to-destination 192.168.1.2:22
            iptables -t nat -A POSTROUTING -p tcp --sport 22 -s 192.168.1.2 -j SNAT --to-source  (my public IPv4):1234
    in second-last line
    iptables -t nat -A PREROUTING -i vmbr1 -p tcp --dport 1234 -j DNAT --to 192.168.1.2:22
    can u try this?, you need to specify the interface I think.
    Thanked by (2)cybertech Ouji
    @Abdullah said:
    in second-last line
    Tried, does not seem to work.
    Main interface not the bridge.
    Thanked by (2)cybertech Abdullah
    edited July 2020
    auto vmbr1
            bridge-ports none
            bridge-stp off
            bridge-fd 0
    Try this:
     iptables -t nat -A POSTROUTING -p tcp --sport 22 -s 192.168.1.2 -j SNAT --to-source <public_ip>:1234
    Whups, looks like you have the exact same config. It should just work, make sure that there's nothing blocking 1234 on the host.
    After couple of tries finally got in! woohoo
    thanks all!
    Thanked by (2)Abdullah Ouji
  • @cybertech you can also use this guide as reference: https://mrpsycho.pl/cheatsheets/Proxmox-on-OVH-Kimsufi-behind-single-IP-NAT/
    It's pretty well written and that's how I did when I was running my Hetzner dedi.
    Thanked by (2)cybertech AlwaysSkint
    @SagnikS said:
    Try this:
    This worked for me, does it do the same thing?
    post-up iptables -t nat -A PREROUTING -i vmbr0 -p tcp --dport 9584 -j DNAT --to 192.168.1.2:22
    post-down iptables -t nat -D PREROUTING -i vmbr0 -p tcp --dport 9584 -j DNAT --to 192.168.1.2:22
    it does look complete, gonna boobmark it
  • edited July 2020
    Oh, hi
    @cybertech said: it does look complete, gonna boobmark it
    Thank you.
    @cybertech said: This worked for me, does it do the same thing?
    Lines starting with post-up/down should be placed inside /etc/network/interfaces. They indicate what command is going to be executed when interface is brought up/down; -A means add, -D means delete. As for the POSTROUTING - I'm not sure how would it be useful.
    E: You will want to execute what's past post-up to apply the rule immediately (as described in the tutorial).
  • @MrPsycho said: Oh, hi
    Hey hey. Thanks for the write-up, it really helped me a lot and I always link it when someone asks for NAT setup in Proxmox, I hope you don't mind.
    Thanked by (1)MrPsycho
    Hey hi, anyone can point me to a guide on adding IPv6 to openvz containers. I tried many approaches but I suspect firewalld messes with ipv6. Anyone can share their experience?
  • bdlbdl OG
    edited July 2020
    Does anyone have any opinions on using ufw on the proxmox host vs using the built in firewall (for host protection)? I'm using ufw at the moment but it's a little clunky so considering switching to use the built in firewall. Either that or grabbing a second IP and using virtualised pfsense...
  • edited July 2020
    UFW - yuk! Thought that was only a Ubuntu thing (plus Linux Mint desktop.)
    CSF. ;)
    Thanked by (1)bdl
  • bdlbdl OG
    edited July 2020
    CSF. ;)
    force of habit with Ubuntu boxen I was stuck using. Ended up just rebuilding and using the Proxmox built in fw and all is good in the pve world :)
    Thanked by (1)AlwaysSkint
