in second-last line
iptables -t nat -A PREROUTING -i vmbr1 -p tcp --dport 1234 -j DNAT --to 192.168.1.2:22
can u try this?, you need to specify the interface I think.
@Abdullah said:
in second-last line
@Abdullah said:
in second-last line
@cybertech said: This worked for me, does it do the same thing?
Lines starting with post-up/down should be placed inside /etc/network/interfaces. They indicate what command is going to be executed when interface is brought up/down; -A means add, -D means delete. As for the POSTROUTING - I'm not sure how would it be useful.
E: You will want to execute what's past post-up to apply the rule immediately (as described in the tutorial).
Hey hi, anyone can point me to a guide on adding IPv6 to openvz containers. I tried many approaches but I suspect firewalld messes with ipv6. Anyone can share their experience?
Does anyone have any opinions on using ufw on the proxmox host vs using the built in firewall (for host protection)? I'm using ufw at the moment but it's a little clunky so considering switching to use the built in firewall. Either that or grabbing a second IP and using virtualised pfsense...
I just have a separate bridge for NAT VMs.
Anything else needed to be done on the NAT VM?
I just get a second IPv4 address, and give it to pfSense, and let it do NAT.
Just set the netmask and put in an IP from the internal subnet in the network config, and you should be golden.
That's what I do at home too (except the second IP).
I kinda did that too, just gonna try again heh. Thanks.
If it didn't work, try pinging the IP that's assigned to the bridge.
ping internal IP from the host?
Whoops, I mean, ping the IP from the VM. That same IP should also be the gateway for the network config inside the VM.
Who is the provider? What is the Server?
@cybertech's guide should cover it. That's all you need to do.
https://cyberpersons.com/2016/07/27/setup-nat-proxmox/
https://webhorizon.net
Thanks everyone for the guides, read all of them and could get my NAT VM to access internet.
Now for accessing SSH NAT VM via port 1234 from outside, I'm stuck. is this correct?
in second-last line
Tried, does not seem to work.
Main interface not the bridge.
Try this:
Whups, looks like you have the exact same config. It should just work, make sure that there's nothing blocking 1234 on the host.
After couple of tries finally got in! woohoo
thanks all!
@cybertech you can also use this guide as reference: https://mrpsycho.pl/cheatsheets/Proxmox-on-OVH-Kimsufi-behind-single-IP-NAT/
It's pretty well written and that's how I did when I was running my Hetzner dedi.
it does look complete, gonna boobmark it
Oh, hi
Thank you.
post-up
to apply the rule immediately (as described in the tutorial).Hey hey. Thanks for the write-up, it really helped me a lot and I always link it when someone asks for NAT setup in Proxmox, I hope you don't mind.
UFW - yuk! Thought that was only a Ubuntu thing (plus Linux Mint desktop.)
CSF.
force of habit with Ubuntu boxen I was stuck using. Ended up just rebuilding and using the Proxmox built in fw and all is good in the pve world
https://github.com/Ne00n/NanoKVM-Tools
