Website simulate multi connection request.
Hi,
Is there a way to test your website if it can handle many connections?
Is there a provider who provide such service?
Basically what I want is test my server if it can handle 25k-50k concurrent connection.
Is there a tool that I can use to achieve that?
I tried this k6 script from loadimpact but I get error. I don't understand.
How do you test your website or server to know if it can handle many connections at the same time.
I have mostly used Apache Jmeter but realistically as the infra is flexible I just use auto-scaling in the professional settings. Cron based scaling in infra where autoscaling is unavailable in likes of DO, Vultr, Linode and Hetzner. For the cron based setting I usually try to see the max peak load as that have easy to do.
But everything depends on what is you app doing and where you wanna take it to.
If you are just testing number of connections, start with
ab
.Try https://loader.io
https://webhorizon.net
İ used wrk http test library
wow thank you. I am not testing it. Looking the documentation. Thanks.
It is okay now guys. I think I'm good with Apache2 Bench.
I tried loader io but free plan is low. I wanted to try but their pricing is way to costly.
AB is fine for. Thanks.
