Website simulate multi connection request.
Hi,
Is there a way to test your website if it can handle many connections?
Is there a provider who provide such service?
Basically what I want is test my server if it can handle 25k-50k concurrent connection.
Is there a tool that I can use to achieve that?
I tried this k6 script from loadimpact but I get error. I don't understand.
How do you test your website or server to know if it can handle many connections at the same time.
  • I have mostly used Apache Jmeter but realistically as the infra is flexible I just use auto-scaling in the professional settings. Cron based scaling in infra where autoscaling is unavailable in likes of DO, Vultr, Linode and Hetzner. For the cron based setting I usually try to see the max peak load as that have easy to do.
    But everything depends on what is you app doing and where you wanna take it to.
  • If you are just testing number of connections, start with ab.
  • İ used wrk http test library
  • wow thank you. I am not testing it. Looking the documentation. Thanks.
  • It is okay now guys. I think I'm good with Apache2 Bench.
    I tried loader io but free plan is low. I wanted to try but their pricing is way to costly.
    AB is fine for. Thanks.
