UK - KVM - NVMe SSD - EXTRA DISK - Free Direct Admin - Free nightly backups [LIMITED TIME]
InceptionHosting
Hosting ProviderOG
Good Aftermorning all!
Little exclusive for you from Inception Hosting Limited (established January 2011) this time from the UK/London. If you can find a better 'like for like' deal I will match it either in specs or price or both depending on what is presented!
- 2 CPU Core (E3-1270v6 @ 3.80GHz)
- 2 GB DDR4 Ram
- 60 GB Pure Samsung NVMe SSD Disk space (doubled for this promo)
- 2000 GB Bandwidth @ 1 gbit (shared)
- 1 x IPv4 address
- 1 x /64 IPv6
- DDOS protection included.
- Full daily backup of your entire disk image to a separate local raid array in the server for disaster recovery.
- Free Direct Admin license
- Free migration from your old host* (source must be a KVM VPS)
€5 /month or for extra value €50 /year
Order Link: https://clients.inceptionhosting.com/cart.php?a=add&pid=185
This plan usually comes with 30GB disk, it does not usually have 2 months free for an annual payment and never comes with free migration from your old host.
This will be available until Sunday late afternoon (UK/London time) after which depending on how popular it has been I will either make it mainstream for a few days or put the plan back to normal
- Network info and LG: https://as62240.net/
Benchmarks
Reads
hdparm -tT /dev/vda
/dev/vda:
Timing cached reads: 14236 MB in 1.99 seconds = 7142.71 MB/sec
Timing buffered disk reads: 1572 MB in 3.00 seconds = 523.23 MB/sec
sequential writes
root@test-box:~# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 1.15091 s, 933 MB/s
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 1.03522 s, 1.0 GB/s
16384+0 records in
16384+0 records out
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 1.18275 s, 908 MB/s
NVMe writes to ram (max speed test)
root@test-box:~# dd if=/dev/vda1 of=/dev/null bs=4096k iflag=direct
^C2542+0 records in
2541+0 records out
10657726464 bytes (11 GB, 9.9 GiB) copied, 6.39538 s, 1.7 GB/s
^C3108+0 records in
3107+0 records out
13031702528 bytes (13 GB, 12 GiB) copied, 7.16883 s, 1.8 GB/s
^C5412+0 records in
5411+0 records out
22695378944 bytes (23 GB, 21 GiB) copied, 13.2399 s, 1.7 GB/s
YABS (for the ladies)
# Yet-Another-Bench-Script #
# v2020-09-21 #
Thu 24 Sep 2020 12:13:24 PM BST
Processor : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz
CPU cores : 2 @ 3792.010 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 1.9Gi
Swap : 2.0Gi
Disk : 4.4G
Read | 58.07 MB/s (14.5k) | 434.85 MB/s (6.7k)
Write | 58.18 MB/s (14.5k) | 437.14 MB/s (6.8k)
Total | 116.26 MB/s (29.0k) | 871.99 MB/s (13.6k)
Read | 898.36 MB/s (1.7k) | 860.35 MB/s (840)
Write | 946.09 MB/s (1.8k) | 917.64 MB/s (896)
Total | 1.84 GB/s (3.6k) | 1.77 GB/s (1.7k)
Clouvider | London, UK (10G) | busy | busy
Online.net | Paris, FR (10G) | 919 Mbits/sec | 377 Mbits/sec
WorldStream | The Netherlands (10G) | 928 Mbits/sec | 294 Mbits/sec
Wifx | Zurich, CH (10G) | 920 Mbits/sec | 218 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | 753 Mbits/sec | 72.2 Mbits/sec
Clouvider | NYC, NY, US (10G) | 726 Mbits/sec | 115 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 864 Mbits/sec | 139 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 829 Mbits/sec | 118 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | 647 Mbits/sec | 249 Mbits/sec
Online.net | Paris, FR (10G) | 762 Mbits/sec | 388 Mbits/sec
WorldStream | The Netherlands (10G) | 788 Mbits/sec | 538 Mbits/sec
Wifx | Zurich, CH (10G) | 567 Mbits/sec | 307 Mbits/sec
Clouvider | NYC, NY, US (10G) | 629 Mbits/sec | 106 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 642 Mbits/sec | 63.9 Mbits/sec
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 3498
Multi Core | 4364
Full Test | https://browser.geekbench.com/v4/cpu/15776500
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 675
Multi Core | 955
Full Test | https://browser.geekbench.com/v5/cpu/3890777
- Link to terms: https://inceptionhosting.com/terms.html
- *Free migration is done manually and this work will be booked in through the support ticket system on request.
- no Tor
- Abuse reports from torrents = termination
- Free DA license available via support ticket.
Feel free to comment or ask any questions.
Welcome to unicorn land!
I am also happy to convert current customers to this plan, said no host ever, until now! ![]()
Thanks.
Ant.
That's a dope offer! Glws
Cracking deal and a "well balanced" server.
Was totally tempted, especially with the disc space & daily backup but will stay with my current great deal(s) with you. I had to login and double-check specs. etc.
@AnthonySmith is there a private network "link" between nodes in the UK location?
Nope, they are not even all in the same physical DC, Clouvider has 3 in London
something thing to add in future to make them sexy.
I literally just need two of these merged
Or two and a haff.
MichaelCee
I can do that but not the CPU cores.
The node I have right now has been averaging 20 - 40% CPU usage of 4*2400MHz cores for 6mo. Around 3GB RAM used and 112GB of NVMe.
Would be great to come back to Inception/Clouvider.
MichaelCee
Are you dead set on pure ssd or is ssd cached an option?
My goal is just to be able to say all locations are "NVMe". Ideally 120-150GB would be good. There is some clearing to do as well to shrink that.
I'd also be happy to pay for a drive or something.
MichaelCee
probably not the ideal solution for you atm then, but you know... November is coming
@AnthonySmith Annual shows up as 60 Euros sir..
VPS reviews and benchmarks |
oops, fixed.
Would it be possible to purchase monthly and switch to annual billing cycle in the future?
Yeah I don’t see any problem with that, I would caveat that it would need to be within 12 months.
Great! How long would DA license provision take?
usually minutes, sadly it looks like the API is down so I cant issue them right now, I will issue them asap though, this has only happened once before.
