2456712
  • @Neoon Any hiccup in DE ?
  • NeoonNeoon OG
    edited August 2020
    Yes, working on it.
  • NeoonNeoon OG
    edited August 2020
    @Neoon said:
    Yes, working on it.
    Iz back Online, we missed to extend the machine.
    Stuff has been changed to ensure it wont happen again.
  • Token: ebde4e2981ab8a22b58050483a462a304dd881ef
    Purpose: SearX Instance
    Thank you!
    Thank you!
    Please apply again, due to a technical issue I could not deploy your request.
    Thank you!
    Done, token: dd95e6cf49ff24b9c4d1c266a7bdfb732aa972e8
    Thank you!
  • @Freek said:
    Thank you!
    Thank you!
    Deployed.
  • @Neoon said:
    @Freek said:
    Thank you!
    Thank you!
    Deployed.
    Thank you!
  • Token: bcbc16fcbc93554d795a6b96ecf3035502343793
    I plan to use my requested NanoKVM instance to test various low-end game server configurations. These game servers have very low bandwidth and system requirements so I am confident they should not negatively impact other tenants on my node. Thank you for offering this service!
    Deployed.
    Thanked by (1)CamoYoshi
  • Romania o Romania.
    Looking for a few Testers for our old new NanoKVM Romania Location.
    Node Specs
    CPU: Duel E5 CPU E5-2450L (32 threads)
    Memory: 32GB
    Storage: 1x 500GB SSD
    Uplink: 1000Mbit
    Specs
    Cores: 4 Cores/Threads E5-2450L (Shared, CPU extensions enabled)
    Memory: Up to 2GB
    Storage: 10GB SSD (can be expanded)
    Uplink: 100Mbit
    20 Forwarded Ports (no Native v6, but you can use a broker)
    HAProxy Support
    The Test will run for at least 4 weeks, Feedback is wanted.
    If you have an existing NanoKVM account, you can test a machine as well.
    You can keep the Machine after the Test, if we decided to keep this Location for NanoKVM.
    If the Test ends and you already have an existing VM at NanoKVM, you have to decide, which one you want to keep.
    If you just have one machine, you can keep it as is, as long you use it, no idle cases.
    In case you have no existing account, do not meet the requirements fully, the request will be decided case by case basis for this test.
    If you want to test one, without an existing account, post the Token here.
    If you haven an existing account, send me a PM, I will allocate you a VM to your account.
    Thanks to @cociu
    Thanked by (2)Ganonk cociu
  • Great offer u doing
  • ok, big thx
    Token: cceb0ed9db00f44fdea558d9086ec404ea6f2ef0
  • "The following errors occurred!
    Invalid name. example: Username (A-Z,a-z,0-9)."
    I see the regex is mocking people again, fixed.
    @qmesso said:
    ok, big thx
    Just created accounts wont apply.
    Thanked by (1)_MS_
  • Token: 25733acf05e5945eb33ec8f1ab23efb5769b92c2
    Usage: peer.js broker server for testing/developing multiplayer games
  • @Neoon said:
    Romania o Romania.
    Node Specs
    Memory: 32GB
    Uplink: 1000Mbit
    Specs
    Memory: Up to 2GB
    Uplink: 100Mbit
    HAProxy Support
    Thanks to @cociu
    WOW Congrats for Romania Sir ?
  • 054e0fb2fa941e3b2df31f1d1094648abef4406f
    Reason: jellyfin or some other music streaming with rclone to my google.drive now that google music is dead. Also monitoring my other vps thanks..
    (MY account on other green forum has more post than this one but you advertised here so i am applying heré))
    Thanks
    b51ac9e8e1db2485fd1f4e8c926346e184a0bb18
  • Token: bd54b6f130588dd91fe4968a3b7c257f54f8ebfd
    Usage: I wanna use this as a sandbox, playing around with the box as well as the panel thingy itself, and have some use for it like hosting a gopher server, gemini (google it), weechat IRC client (no illegal weird and overloading stuff don't judge).
    Thanks
    Deployed
    Deployed
    Same reason for most of the rejects, the account is way to young.
  • Oopsie could I apply later?
  • @Neoon said:
    Deployed
    Well, the "exception" was meant, to apply if you do not fulfil everything but at least something.
    If you do not even meet a single requirement, then its a big no no, but if you meet for example 2 of 3 will be fine.
    I doubt that you will even fulfil 2 of 3 in the next 4 weeks.
    Not to dispute; it's your gig and you can run it any way you like and make any decision you like with or without my input, but I've had an account on post4vps since 2016. Can pm you there if you'd like :)
  • @Neoon said: 20 Forwarded Ports (no Native v6, but you can use a broker)
    we can do a test to route you a bounche of ipv6 in some days (we are too full now) , or even better after BF . In this case i will test the implementation of ipv6 with you if you are opened.
    Well, then you should post on Post4VPS.
    Nice.
    Thanks
    Deployed
    I'll pass. I prefer to play when the same rules apply to everyone. You clearly aren't hurting for testers and I don't particularly need it. I could make use of it, and maybe learn something, but not enough to dip my finger in the favoritism pool. Thank you for making your principles clear.
    Thanks
    Deployed
    The same rules apply to everyone, I see no difference, it does not matter in which forum you post.
    However, what does matter, is the abuse's we might get by handing out the servers like candy.
    Thanked by (1)bdl
  • Is is free NAT still applicable?
    If yes, I would like to try one!
    Token: 2fc96b6e386eb373237e64ebf3a498c98ae74592
    reason: host personal wordpress site
