Anyone have a good guide for rancher?
I think I want to do a 2 node k3s setup with embedded etcd and rancher on top.
Check out TechnoTim on youtube
He seems to like rancher & his presentation style is bearable vs rest of youtube tech tutorials
https://www.youtube.com/channel/UCOk-gHyjcWZNj3Br4oxwh0A
@aaronstuder said: Anyone have a good guide for rancher? I think I want to do a 2 node k3s setup with embedded etcd and rancher on top.
Why do you need k3s when you want to use rancher?
Do you want to install rancher on top of k3s so that your rancher have HA?
Should you use RKE instead? But I think it is more complicated than k3s
@akhfa said: show previous quotes @aaronstuder said: Anyone have a good guide for rancher? I think I want to do a 2 node k3s setup with embedded etcd and rancher on top. Why do you need k3s when you want to use rancher? Do you want to install rancher on top of k3s so that your rancher have HA? Should you use RKE instead? But I think it is more complicated than k3s
@akhfa said:
Yes, I realized today that RKE is a better choice.
