@tetech said:
I use HE.net and find it to be very good. I run a hidden master, so no need to worry about HE API or web interface, just change on the master and do a notify for AXFR.
How do you find the AXFR response times, i.e. update delay, these days?
When I looked at HE a few years back the AXFR timing seemed very erratic, changes could take ages (10's of minutes) to propagate, making it problematic for DNS based authorisation, e.g. Letsencrypt.
I did a quick look at the last week of logs and their response to a NOTIFY seemed to be around 1-1.5 minutes behind the other slaves. Nothing drastic. Personally I am making a CNAME for LetsEncrypt records and pointing it to a subdomain at a different DNS provider which I use for that and nothing else.
Thanks, just realised @Brueggus had actually answered my query higher up but I didn't spot it. Might give HE another try as a backup, always heard good things about their reliability.
Good suggestion on doing LE on another platform altogether.
I'm using certbot and have configured dns-rfc2136-propagation-seconds=120 which works for me. The propagation delay was about 90 seconds last time I checked. And that's the total delay from my master via my opendnssec live signer, and a slave of mine.
Another HE limitation is they do not support numeric-only domains like:
1234.comOpenVPN installer | WireGuard installer
^this
HE DNS is like, first it's free and then why fix something that isn't broken...
Then, almost no body complaints to them, they simply switch over to something else...
