Mr. Worldwide here went crazy and giving away too many things. Limited Qty, don't be late.
2»
  • vyasvyas OGRetired
    edited November 2020
  • Get the best deal on your next VPS or Shared/Reseller hosting from RacknerdTracker.com - The original aff garden.
    @dahartigan said:
    I love seeing the classic memes reinvented for nerds :)
    Thanked by (2)dahartigan seriesn
    The first VPS I got from Nexusbytes, last year.
    Ran a BM again before I thought I would cancel. You know how the story might end.
    #                     v2020-11-20                    #
    Sat Nov 21 15:56:08 PST 2020
    Processor  : AMD Ryzen 7 3700X 8-Core Processor
    CPU cores  : 2 @ 3593.248 MHz
    RAM        : 1.9 GiB
    Swap       : 4.0 GiB
    Disk       : 39.4 GiB
    Geekbench 4 Benchmark Test:
    Single Core     | 4775
    Multi Core      | 8076
    Full Test       | https://browser.geekbench.com/v4/cpu/15896670
    Updated:
    Not sure how many here are Vultr High Frequency Server fanboys and girls (I am not).
    Fo rsake of comparison, here are the charts to compare against your Nexusbytes Server. Not sure which Benchmark script they use.
    https://www.vultr.com/products/high-frequency-compute/
    on that note...
    Nexusbytes-Cup-of-Tea-Ad-AVyas-2020
    Thanked by (1)seriesn
    > #              Yet-Another-Bench-Script              #
    > #                     v2020-11-20                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 1.9 GiB
    > Swap       : 4.0 GiB
    > Disk       : 39.4 GiB
    > Test            | Value
    > Single Core     | 4775
    > Multi Core      | 8076
    Yeah, that's not the sort of deal you just cancel willy-nilly lol
    Me too, especially this one, it's something I'm sure we can all relate to (unless it's just quirky me)
    Thanked by (1)vyas
    > #                     v2020-11-20                    #
    > AES-NI     : ✔ Enabled
    > RAM        : 1.9 GiB
    > Swap       : 4.0 GiB
    > Disk       : 39.4 GiB
    > Test            | Value
    > Single Core     | 4775
    > Multi Core      | 8076
    Updated:
    on that note...
    Good sir,
    I applaud your creativity.
    Thanked by (1)vyas
  • edited November 2020
    hbd
    Non - Ryzen VS Ryzen :#
    Thanked by (2)seriesn cybertech
  • Due to nature of storage VPS, usage of Next Cloud or similar cloud syncing software is not recomended. You will notice degraded performance.
    Boss, what’s the backstory here? I see the STORAGE-3T with 3GB Ram and 4vCores at 3.5ghz. This is way above what Nextcloud recommends.
    What NextCloud recommends are the bare minimum, equivalent to running on a Raspberry Pi. NC requires Redis and beefy PHP settings, which means a healthy amount of RAM. It also benefits greatly from having the DB on an SSD. There are multiple scripts out there solely for installing a tuned up NextCloud.
    For example?
    Agreed, but I have used Redis and whatnot on 2-3GB ram VPS. I guess that this depends on how many (concurrent) users the NextCloud instance would have? Kudos to @seriesn to give the warning, by all means.
  • AC_FanAC_Fan OG
    @Anon said:
    For example?
    ReinerNippes has an Ansible script, NextCloudPi was also made to make it run better (it's not solely for the Pi), there's some guy who runs a website almost entirely for tips (can't remember the name, sorry).
    Yeah I suppose so, at 3GB RAM, it should work fine for a few users, the bottleneck will become the DB probably. NextCloud is heavy, like pretty heavy. Only those spirits damned Atlassian products are worse than it in terms of bloat.
  • @AC_Fan said: Yeah I suppose so, at 3GB RAM, it should work fine for a few users, the bottleneck will become the DB probably. NextCloud is heavy, like pretty heavy. Only those spirits damned Atlassian products are worse than it in terms of bloat.
    Jeez, I have just installed it on my Synology. It's actually heavier than Confluence. It somehow uses less resources, but it's way slower. Now I understand.
  • AC_FanAC_Fan OG
    The amount of stuff you have to keep track of is pretty disturbing, really.
    Don't use External Storages too much, because a local cache isn't kept, so it's ridiculously slow.
    Don't depend on the JIT Preview Generator, because it is ridiculously slow.
    Don't add too many plugins, because they aren't well maintained and are therefore, you guessed it, slow.
    And yet, it's still the best option for a self hosted cloud storage. Sad life. It's mostly held back by the architecture they used in the beginning, and rather than fixing it, they choose to just add half-assed features. The improvements in PHP 7 and 7.3 have helped a fair bit, but at the end of the day, how many ways can you polish up a turd?
    Systems tend to be well balanced, so TBs of storage comes with plenty of RAM and CPU. That's the only reason it's so widely used, because mostly it doesn't matter how bloated it is, when the resources aren't going to be used otherwise. Plenty of similar systems manage to run in 25% or less resources.
    What’s up boss,
    Next cloud isn’t the culprit. But people trying to run the full blow suit or those who rely on ui heavily.
    I have guys running nextcloud without any issue even on the smaller plans :)
    Thanked by (2)sgheghele dahartigan
  • Rereading my comment, I feel like I might have come across a bit too critical of NC. I'm more used to stuff like RClone, Redis, Nginx etc. which were built with performance, reliability and ease-of-use as the foremost concerns. After that, any project that comes from an enterprise point of view tend to annoy me a bit more than they should.
    When setup properly, NC is mostly fine. It's just that it takes a bit too much effort to set it up that annoys me.
    Makes 2 of us. I find the UI kind of annoying. Or I am simply getting old. Or both.
    For my personal usage, been using owncloud for almost 6 years without any issue.
    It's probably both.
    OwnCloud is stable, but old. They didn't develop much for years I think, so NC might (might) be faster than them. I wish somebody would just make a open source clone of FileRun, that software seems decently made, all things considered.
  • I get the nextcloud thing.. to a new user, you end up with a nosql database (disk io heavy) and a default set of plugins/apps that also thrash disk (activity, photos, versions, etc) and the whole shebang starts bringing a spinning disk to it's knees. The bigger the store of files the bigger the problem gets.
    My $0.02
    My $0.02
    It is like the whole plugin thingy with wordpress. You get carried away and then next thing you know, everything is slow.
    Thanked by (1)dahartigan
    You can watch the video here.
    Coming to YABS
    Singapore. Upgraded to 3 GB Plan. (and went broke, but that is a different story)
    Thu 26 Nov 2020 05:40:45 AM CET
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 2 @ 3792.874 MHz
    RAM        : 2.9 GiB
    Swap       : 4.0 GiB
    Disk       : 59.0 GiB
    Read       | 355.40 MB/s  (88.8k) | 3.74 GB/s    (58.5k)
    Write      | 356.34 MB/s  (89.0k) | 3.76 GB/s    (58.8k)
    Total      | 711.74 MB/s (177.9k) | 7.51 GB/s   (117.4k)
    Read       | 4.22 GB/s     (8.2k) | 4.09 GB/s     (3.9k)
    Write      | 4.44 GB/s     (8.6k) | 4.36 GB/s     (4.2k)
    Total      | 8.66 GB/s    (16.9k) | 8.45 GB/s     (8.2k)
    Clouvider       | London, UK (10G)          | 353 Mbits/sec   | 814 Mbits/sec
    Online.net      | Paris, FR (10G)           | 197 Mbits/sec   | 523 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 822 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 940 Mbits/sec   | 924 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 318 Mbits/sec   | 692 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 348 Mbits/sec   | 699 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 391 Mbits/sec   | 840 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 1293
    Multi Core      | 2414
    Full Test       | https://browser.geekbench.com/v5/cpu/4997674
    Thanked by (1)sahjanivishal
  • seriesnseriesn OG
    Alrighty people! We got the winners!!
    -> Meme Contest: Win $25 Amazon Gift Card
    Picked using rand function on excel, ours truly @vyas
    -> Bench Warmers: Win $25 Amazon Gift Card
    Picked using rand function on excel, Mr Destruction specialist @HuntersPad (I guess he doesn't lurk here)
    -> Thanksgiving raffle: $100 Amazon gift card
    Lucky winner has been notified via our support desk. If you happen to lurk here,
    @vyas11 and @HuntersPad please DM me your email address and your digital gift card will be emailed to you before the Cyber Monday madness begins.
    Thank you for playing everyone!!
    Congratulations to all the lucky winners :)
    Yay! Thanks :-)
