@terrorgen said:
Yet I chose i3, which is not prebuilt, lol
It helps to have one already working; then just add the option to lightdm/sddm/whatever login servie you're using. After working, then remove gnome/kde/cinnamon/etc..
I did not take a look at Devuan since it came out. Is it a mature alternative in the meantime?
Amitz said: I did not take a look at Devuan since it came out.
Neither have I, but so far I've been able to avoid any systemdebilitating malware by carefully curating my Debian installs. So far only with Promox based setups have I had to sell my soul to the devil and that too because I've not (yet) had the time to invest in converting one package to play nice. Eventually...
Yeah. Ascii (latest for Devuan) is basically on-par with Deb 9. There is no specific Deb 10 compatible build that is complete, yet. Keep in mind it took like 6 months from 9's release before we saw any real work on ASCII. As long as you can handle patches but don't need bleeding edge, it works perfectly fine.
Devuan feels a bit like "old-time Debian", and I mean this in a positive sense. As @WSS says, Devuan ASCII ~ Debian 9, definitely stable.
ah! didn't know to trick!
Neither have I, but so far I've been able to avoid any system debilitating malware by carefully curating my Debian installs. So far only with Promox based setups have I had to sell my soul to the devil and that too because I've not (yet) had the time to invest in converting one package to play nice. Eventually...
