Inception Hosting UK-SSD-KVM-2048
seems like 1270s gonna be phased out? check out the new 3.8Gs:
UK-SSD-KVM-2048
2 CPU Core (Equal Share) 2048 MB Ram 20 GB Pure NVMe SSD Disk space 2000 GB Bandwidth @ 1 gbit (shared) 1 x IPv4 address 1 x /64 IPv6 Full daily backup €5/mth https://clients.inceptionhosting.com/cart.php?a=add&pid=185 no AFFs sorry
there's vps, there's prem vps, then there's inception hosting vps.
YABS
[root@cybertech ~]# curl -sL yabs.sh | bash -s -- -i4 # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2020-12-07 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Dec 16 06:02:24 GMT 2020 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz CPU cores : 2 @ 3792.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 257.0 MiB Disk : 19.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 214.08 MB/s (53.5k) | 1.12 GB/s (17.5k) Write | 214.64 MB/s (53.6k) | 1.12 GB/s (17.6k) Total | 428.73 MB/s (107.1k) | 2.25 GB/s (35.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.20 GB/s (2.3k) | 1.31 GB/s (1.2k) Write | 1.27 GB/s (2.4k) | 1.40 GB/s (1.3k) Total | 2.48 GB/s (4.8k) | 2.71 GB/s (2.6k) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5546 Multi Core | 9437 Full Test | https://browser.geekbench.com/v4/cpu/15941470 [root@cybertech ~]#
bench.sh
--------------------------------- ---------------------------------------------------------------------- CPU Model : Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz CPU Cores : 2 CPU Frequency : 3792.000 MHz CPU Cache : 16384 KB Total Disk : 20.0 GB (1.9 GB Used) Total Mem : 1981 MB (149 MB Used) Total Swap : 256 MB (0 MB Used) System uptime : 0 days, 0 hour 31 min Load average : 0.15, 0.03, 0.01 OS : CentOS 8.3.2011 Arch : x86_64 (64 Bit) Kernel : 5.10.1-1.el8.elrepo.x86_64 TCP CC : bbr Virtualization : KVM Organization : AS62240 Clouvider Limited Location : London / GB Region : England ---------------------------------------------------------------------- I/O Speed(1st run) : 1.9 GB/s I/O Speed(2nd run) : 2.1 GB/s I/O Speed(3rd run) : 1.9 GB/s Average I/O speed : 2013.9 MB/s ---------------------------------------------------------------------- Node Name Upload Speed Download Speed Latency Speedtest.net 932.21 Mbps 875.76 Mbps 46.08 ms Beijing CU 375.84 Mbps 433.10 Mbps 201.92 ms Shanghai CT 0.35 Mbps 349.86 Mbps 264.91 ms Shanghai CU 9.91 Mbps 455.26 Mbps 311.67 ms Guangzhou CU 4.57 Mbps 142.42 Mbps 305.25 ms Shenzhen CU 4.48 Mbps 403.37 Mbps 330.25 ms Shenzhen CM 279.79 Mbps 743.81 Mbps 293.29 ms Hongkong CN 389.37 Mbps 510.30 Mbps 206.58 ms Singapore SG 196.93 Mbps 199.42 Mbps 352.33 ms Tokyo JP 158.58 Mbps 8.59 Mbps 228.41 ms ---------------------------------------------------------------------- [root@cybertech ~]#
monster bench
OS : CentOS 8.3.2011 (64 Bit)
Virt/Kernel : KVM / 5.10.1-1.el8.elrepo.x86_64
CPU Cores : 2 @ 3792.000 MHz x86_64 16384 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled
Load Average : 0.26, 0.10, 0.02
Total Space : 20G (2.0G ~10% used)
Total RAM : 1981 MB (157 MB + 285 MB Buff in use)
Total SWAP : 256 MB (0 MB in use)
Uptime : 0 days 0:45
ASN & ISP : AS62240, World CDN Limited
Organization : Inception Hosting Limited
Region : England
## Geekbench v4 CPU Benchmark:
Single Core : 5533 (EXCELLENT)
Multi Core : 9276
## IO Test
CPU Speed:
bzip2 : 137 MB/s
sha256 : 451 MB/s
md5sum : 743 MB/s
RAM Speed:
Avg. write : 5017.6 MB/s
Avg. read : 8840.5 MB/s
Disk Speed:
1st run : 2.0 GB/s
2nd run : 2.0 GB/s
3rd run : 2.0 GB/s
Average : 2048.0 MB/s
## Global Speedtest.net
Location Upload Download Ping
Nearby 646.07 Mbit/s 867.56 Mbit/s 31.63 ms
USA, New York (Optimum) 232.38 Mbit/s 124.00 Mbit/s 74.602 ms
USA, Chicago (Windstream) 202.43 Mbit/s 118.19 Mbit/s 93.853 ms
USA, Dallas (Frontier) 172.48 Mbit/s 167.08 Mbit/s 107.793 ms
USA, Miami (Frontier) 190.73 Mbit/s 150.33 Mbit/s 102.060 ms
USA, Los Angeles (Windstream) 139.43 Mbit/s 184.62 Mbit/s 132.281 ms
UK, London (toob Ltd) 899.11 Mbit/s 934.60 Mbit/s 2.085 ms
France, Lyon (SFR) 575.64 Mbit/s 568.39 Mbit/s 18.198 ms
Germany, Berlin (DNS:NET) 534.55 Mbit/s 385.71 Mbit/s 21.808 ms
Spain, Madrid (MasMovil) 325.34 Mbit/s 133.10 Mbit/s 33.259 ms
Italy, Rome (Unidata) 402.93 Mbit/s 365.75 Mbit/s 32.378 ms
Russia, Moscow (Rostelecom) 309.60 Mbit/s 278.50 Mbit/s 56.428 ms
Israel, Haifa (013Netvision) 251.46 Mbit/s 312.15 Mbit/s 69.477 ms
India, New Delhi (GIGATEL) 121.23 Mbit/s 212.50 Mbit/s 153.562 ms
Singapore (FirstMedia) 69.17 Mbit/s 34.26 Mbit/s 158.821 ms
Japan, Tsukuba (SoftEther) 35.16 Mbit/s 56.96 Mbit/s 247.708 ms
Australia, Sydney (Optus) 19.61 Mbit/s 50.20 Mbit/s 288.906 ms
RSA, Randburg (Cool Ideas) 124.98 Mbit/s 269.42 Mbit/s 157.481 ms
Brazil, Sao Paulo (Criare) 59.12 Mbit/s 85.10 Mbit/s 195.691 ms
Finished in : 8 min 57 sec
Timestamp : 2020-12-16 06:53:18 GMT
Saved in : /root/speedtest.log
Share results:
- https://www.speedtest.net/result/10597812427.png
- https://browser.geekbench.com/v4/cpu/15941537
- https://clbin.com/UEYge
nench
[root@cybertech ~]# wget -qO- wget.racing/nench.sh | bash ------------------------------------------------- nench.sh v2019.07.20 -- https://git.io/nench.sh benchmark timestamp: 2020-12-16 06:55:00 UTC ------------------------------------------------- Processor: Intel(R) Xeon(R) E-2276G CPU @ 3.80GHz CPU cores: 2 Frequency: 3792.000 MHz RAM: 1.9Gi Swap: 256Mi Kernel: Linux 5.10.1-1.el8.elrepo.x86_64 x86_64 Disks: vda 20G HDD CPU: SHA256-hashing 500 MB 1.663 seconds CPU: bzip2-compressing 500 MB 4.087 seconds CPU: AES-encrypting 500 MB 0.774 seconds ioping: seek rate min/avg/max/mdev = 52.1 us / 243.2 us / 6.78 ms / 162.4 us ioping: sequential read speed generated 10.8 k requests in 5.00 s, 2.63 GiB, 2.15 k iops, 538.7 MiB/s dd: sequential write speed 1st run: 1716.61 MiB/s 2nd run: 1907.35 MiB/s 3rd run: 1907.35 MiB/s average: 1843.77 MiB/s IPv4 speedtests your IPv4: 185.164.136.xxxx Cachefly CDN: 107.53 MiB/s Leaseweb (NL): 13.57 MiB/s Softlayer DAL (US): 10.08 MiB/s Online.net (FR): 91.00 MiB/s OVH BHS (CA): 16.61 MiB/s No IPv6 connectivity detected ------------------------------------------------- [root@cybertech ~]#
No geekbench 5?
This is very prem VPS, unfortunately it is faraway from my location..
Thanks for the benchmarks.
As a reminder to everyone, you can get a trial VPS as above for €0.50 for the first month here: https://talk.lowendspirit.com/discussion/2202/0-50-month-trial-2gb-uk-kvm-nvme/p1
Here's idea for killer promo in community spirit: Make 10 of them recurring at this price.
with that i think Ant is like
Killer as in that sort of promo would close Inception Hosting down because they would sell at a recurring loss?
lol.
Inception Hosting is A+
Delete the IPv4 and switch to 3-year payment term, and it won't be as much a loss.
Reference: BF-DOLLA-NAT
Yup, but still a loss.
Well my comment was a joke. This is a very nice server and totally worth 5€(that's about a small lunch for two here) for Europe(geographically). I think I may get one for a PBX...
Or... maybe drServer can start this initiative to sell 10 of the KVM at that killer price first?
"Humanity is f*cked up" - Jay
Heh... I'll think about it. We don't have NVMe though.
Most of us will probably not care about whether it is NVMe or SSD at €0.5/m...
(For this price at 2GB RAM, I would probably be fine with HDD too)
Maybe we will do something next Black Friday here...
Or upcoming Christmas/New Year...
I can't promise anything for Christmas at SUCH pricing..
However, let's not derail further as this is an InceptionHosting review thread after all and I do respect that.
Good point, sorry @AnthonySmith and please split and merge into Cest Pit if needed
If it was a small lunch for 2 here I might be able to do it, sadly these days it’s not even a drink for 2 lol.
Don’t worry about derailment it’s all good
Asterisk only needs 16MB RAM. What are you going to use the remaining memory for?
For this price at 2GB RAM, would you rather take 20GB HDD or 5GB NVMe?
My choice would be 5GB NVMe. The CPU score is high enough to encode push-ups efficiently, with intermediate files placed in ramdisk.
OS and programs can fit in 3GB NVMe; the remaining 2GB can store about 80 minutes of input and output files.
well in my case neither. 20GB RAID 10 SSD at a minimum.
CentOS with panel with website already close to 10GB. with backups 25GB would be more comfortable
I quoted a benchmark of this early on, before all the other BF/CM orders ticked in and everyone started benchmarking ... GB5 of 1351 single core
Love the performance of this node!
