♒︎ Age of Aquarius Premium Ryzen 3700X VPS! ♒︎
¡Saludos!
Maybe the Dawning of the Age of Aquarius is today!
For me, today's big Aquarius push was the first of the two tricks in @yoursunny's post, Enable IPv4 Access in EUserv IPv6-only VS2-free. As @yoursunny explained so clearly, all I had to do was change the DNS resolvers to point to a public NAT64 translator service. Then I could enjoy accessing IPv4-only websites via an IPv6-only VPS! Maybe another day soon I will implement @yoursunny's second trick from the linked post, VXLAN, so that my IPv6-only VPS is accessible from IPv4-only machines.
Maybe the Age of Aquarius means that we no longer need to pay the IPv4 tax for our VPSes! Maybe I can deliver cheap but really high performance IPv6-only VPSes which also can access IPv4-only content!
Sssshhh! Please don't spoil the fun by mentioning the obvious fact that @AnthonySmith and many others have been doing NAT VPSes for a long time!
IPv6 only, NAT64 IPv4 enabled, Ryzen Premium $7 Deal!
2 x Ryzen 3700X, 2 GB ECC RAM, 25 GB NVME RAID 1, no IPv4, 1 x /128 IPv6, 1 Gbps, $7/month
Premium Ryzen VPS -- the best performance you can get without spending more than three times as much every month for your own bare metal, dedicated server!
If you are sitting between oversold and slow on one side and expensive bare metal on the other side, then this best performance, premium Ryzen VPS is perfect for you!
You get access to the Proxmox VE control panel. You can see real time load averages and performance graphs for the host node! Do you know any other Hosting Provider who has sufficient confidence in his host node performance to let you see the host node load average numbers? Here is the host node load average graph as it looked while I, @Not_Oles, was writing this. Please note that nproc = 16 and the load averages are 0.4 or lower! This is with 6 nice neighbors! Tons of power remains available!
Add Ons
Additional 2 x Ryzen 3700x + 2 GB ECC RAM + 25 GB NVME RAID 1, $3.00/month
IPv4, as well as bigger plans, are available via @Not_Oles' LES Exclusive Deals, which are visible to logged in LES visitors.
More information
Running on Hetzner AX51-NVMe in Helsinki
LXC, but KVM if you have a good reason, for example, running *BSD, Plan 9, Window$, or Apple. Or, maybe, you just like KVM.
From the control panel, you can start, stop, reboot, backup, and restore your VPS.
Almost any GNU/Linux or *BSD flavor is available. With KVM we can run your custom .iso.
IPv6 /64 or /96 or additional IPv4 addresses available if needed. Default $7 plans have 1 x /128 IPv6.
Bandwidth is unlimited, fair use.
Several Yabs benchmarks were posted in a previous thread. Another Yabs from today on this exact VPS, but with the add on, is posted below.
Free month for the first person who successfully runs KVM inside an unprivileged LXC container.
Warning! Grumpy, incompetent, clueless administrator!
Limited availability. Delivery might take awhile. ?
No service level agreement. Not for business use. Intended especially for serious computer fun!
Check out @Not_Oles' 1337 front end skillz!
@Not_Oles tries to keep the system updated. Occasional reboots are guaranteed.
Please make your own off site backups! The on-the-server backups are not guaranteed to work or even to remain available.
How to Order and Pay
To order, please post here, PM me, @Not_Oles, or use the email on my profile.
Please send Paypal payments to the email on my, @Not_Oles, profile. Please do not pay until after your VPS is set up, and until you are sure you are satisfied.
If you cannot pay by Paypal, let me know, and we will figure out another way.
Amazing Support
Support is available via posting here, LES personal messages, email to the address on my profile, and Signal App.
What People are Saying
"Yes, please. I’ll take that."
"I've been using this one from him. Highly recommend! His support is really amazing!"
"he is the sweetest guy in LES .."
MetalVPS
