Looking for PHP, JS, or Python devs
lentrolentro Hosting Provider
edited January 2021 in General
Hello,
Looking for PHP, JS, or Python developers to build a customer panel to manage servers, Stripe subscriptions, and interact with an Airtable database.
Will either be a PHP, NodeJS, or Pyflask application. Haven't decided yet.
Comp will be around $10/hour or less (depending on prior experience) for 5-20 hours/week for at least 6 months.
PM me if you are interested!
  • Good luck with your budget.
  • HxxxHxxx OG
    edited January 2021
    You had probably be looking for people in India based on your budget. US devs start at $30.00 /hr minimum. Even for a junior.
    @Hxxx said: You had probably be looking for people in India based on your budget
    Yep, will put smth on Upwork later this week, but I wanted to check with the community first. I have some well-paying U.S.-based ppl, so goal is for them to architect the software and check the code while the lower-paying people actually code.
    Grad students are paid $14/hour.
    Your hourly rate can only hire undergraduate student, but your project is too complex for an undergrad.
    Maybe you should add some push-ups and premium Ryzens as part of the compensation and someone would take it.
    Not that I believe $10/h is fair, but around here (TH) newly graduate - with very basic English - software engineer are paid as official employee ~=$5/h.
    TH?
  • @seenu Thailand! Sorry, should have made it clear.
    Lower than India?
  • it all depends on cost of living.
    If India, Th gets too many projects and cost of living goes up, then countries needs to look up somewhere else
    ex: call center jobs are being moved from India to Philippines these days.
