Anyone using TinyCP?
2»
    edited January 2021
    almost gave up a couple of times, but finally got staging site up. and boy the panel is really light and fast.
    I supposed SQL has to be tuned in SSH terminal? PHP max child , on-demand mode as well?
    Thanked by (1)AlwaysSkint
  • @cybertech said: I supposed SQL has to be tuned in SSH terminal? PHP max child , on-demand mode as well?
    Yup, I'd assume so (also the case with many/most control panels)
    mysqltuner.pl / tuning-primer.sh are your friends.
    Make your life easier by creating a soft link to your php.ini for tweaking eg.
    ln -s /opt/alt/php/php74/php.ini /root/php.ini
    Or wherever it is; then you can just
    vim /root/php.ini
    Thanked by (1)cybertech
    vim /root/php.ini
    did mess around with it before, until aapanel came. did everything on the UI.
