How to Self-Host Plausible Analytics Guide
After much anticipation plausible.io released the option to self host their privacy-friendly analytics solution, a couple of months back. Plausible Cloud options
I have written up a cheeky guide https://cyberhost.uk/selfhost-plausible-analytics/ on how to set this up.
Could be another option to replace Google Analytics with @AnthonySmith
Please let me know if you have any issues with the setup or want to suggest a change to the article.
Best Wishes,
CyberHost
Will have a look, cheers!
@cyberhost I love your blog design & content, saves me from anxiety
Is there any plans for an article explaining how to do NFS Share mount via Wireguard?
Appreciate the love @icry (You can thank Ghost), I can understand the anxiety pain with some sites!
I can take a look into a NFS Share mount via Wireguard
, however would Syncthing meet your needs?
No, Syncthing won't do it. I need to use the HostHatch Deal I got, but every article I find about is failing at some point, mostly at file permissions issue
https://github.com/plausible/analytics
What is that .ex stands for, which language the code is written?
Elixir
Website: thomassen.sh
Discord: Decicus#0001
I'd try
chmod 777
?Leave it with me, I'll take a look at writing an article up on it.
Thoughts on that vs Matomo? (https://matomo.org/)
I love you already
My NextCloud, NginxProxyManagerr and Bitwarden setup are based on your Guides
Didn't @Daniel just do a blog article about that?
Matomo > Google Analytics obviously, Matomo collect lots more data so I'd be sure to follow the guide here for GDPR.
I currently use Plausible on cyberhost.uk to respect the privacy of the viewers and the fact I don't need all that data!
Thanks for the support
Hope your backing it up!
Feel free to message me any other article ideas
For lightweight, self-hosted analytics, there's also https://umami.is/
Yeah I recently wrote a post about sharing storage with NFS and WireGuard: https://d.sb/2020/12/nfs-howto
Make sure the files are owned by the same UID you're trying to use to read/write them. NFS only deals with user IDs by default, not usernames (unless you use
idmap
) and your user IDs may differ across machines. Theid
command can give you the UID and GID for a user, or you can just look in/etc/passwd
directly. Grab the UID on the client side then usechown
on the NFS server with the UID (eg.chown -R 1234:1234 .
)If you want to create a new user
adduser
can take the UID and GID using the--uid
and--gid
options respectively, if you want to ensure the user has the same UID across all your servers. Alternatively you could use Kerberos for auth, but it's very tedious to get working properly.If you want root on your client to also essentially have root access on the server, you'll need to add the
no_root_squash
option to your export.Daniel15 | https://d.sb/. List of all my VPSes: https://d.sb/servers
Got NC with NFS working somehow using both guides & pulling hair realizing how dumb I'm in the process
I am really liking the look of this tbh, I am about 90% sure I will switch to this for LES.
Nice. As keen as I am on data protection & GDPR...that cookie banner law was one of the worst things to ever happen to humanity. Really should have been written in a way that doesn't require that no-value added annoyance.
