My Idlers - Self hosted web app for your servers, shared hosting and domains information
corbpiecorbpie OG
edited February 2021 in General
My Idlers is a web app for displaying, organizing and storing information about servers (VPS), shared hosting and domains.
Despite what the name infers this self-hosted web app isn't just for storing idling server information. By using a YABs output you can get disk & network speed values along with GeekBench 5 scores to do easier comparing and sorting.
Version 1.3 31st Jan 2021
Sample page (Add/Edit/Update/Delete disabled)
GitHub repo
Install instructions
Notes
Features
Add servers
Add shared hosting
Add domains
Auto suggest locations
Auto suggest providers
Auto get IP's from hostname
Check up/down status
Get YABs data from output
Save & view YABs output
Next due date system
Multi currency compatibility
Multi payment-term compatibility
Pre-defined operating systems
Assign tags
Assign labels
Assign server type (KVM, OVZ, LXC & dedi)
Easy to edit values
Order by table
Search items
Tally/stats card
One-page design
Screenshots
My idlers screenshot1
My idlers screenshot2
My idlers screenshot3
My idlers screenshot4
My idlers screenshot5
My idlers screenshot6
My idlers screenshot7
My idlers screenshot8
My idlers screenshot9
My idlers screenshot10
Auto complete location
Auto complete provider
Auto complete IP's
Get up/down status
Table scrolling x
«13
  • Idling server management at its best.
    Thanked by (3)corbpie yoursunny bdl
  • It's cool.
    Thanked by (1)corbpie
  • Wow I'm impressed, Ima install this quick,
  • Really nice features :)
  • Does it have a means to store YABs history? Add to that, it'll be great to have a way to compare different YABs results from different test times. :)
    Thanked by (1)Wolveix
  • I have a (mostly) idle MXroute. Where do I put that?
    Thanked by (2)Brueggus lgsin
  • Neat way to keep track of everything. Might have to give it a try. Good work!
  • yokowasisyokowasis Services Provider
    Is there a way i can upvote this thread ?
  • ehabehab Content Writer
    edited January 2021
    this is a super tool, i will check it out.
    Thank you very much.
  • looks awesome. already have a few more suggestions I'd love to see:
    • a field for non standard ssh port
    • a free text field to add any individual info or note
    • put it behind some login (ideally ofc a small user management to share data individually)
    thanks for sharing and all the efforts you already put into that!
  • Also: a way to back up or export to CSV or Excel format :)
  • Very neat! Great alternative for those using an Excel sheet for this.
    Thanked by (2)corbpie seriesn
  • Did you copy that nameserver field from whcms?
    Thanked by (1)webcraft
  • I like your subdomain naming!
    User management would be overkill and any homemade user management is subject to attacks. For starters, it's very easy to make mistakes in how to store passwords.
    An easier and more secure way is to deploy two separate webapps:
    • An admin site that allows editing.
    • An external site for showcasing, with no editing capability. List of displayed fields are determined through a config file.
    Then, the user can have the admin site listen on localhost and accessed via SSH tunnel, while the external site can either be open to everyone or placed behind Basic Auth configured in HTTP server.
  • Love the 'View YABS' feature :D
    Layout/formatting could be better I suppose.
  • _MS__MS_ OG
    edited January 2021
    True. At first, I thought that was the Close button :D. It's just the first release, and we might see changes in the future based on the feedback from the community.
    Yeah.
    Nevertheless, it's a piece of work ?
  • AsimAsim OGServices Provider
    How to report bugs @corbpie , github issues?
  • MasonMason AdministratorOG
    Well done! Looks great :)
  • If I use a server to manage other servers, should I add the server itself to the list?
    No, that server should go on a sticky note instead, stuck to your monitor or CPU :joy:
  • Just a couple of feature requests (if you are accepting them and they are within scope of the project):
    • Password protection for portal login (doesn't have to be a full user management deal, just an option to add a password prompt)
    • Option to create a HTML report or provide some sort of public facing view to allow people to view your servers publicly, with perhaps options on what details to show to the public or not (such as DNS, IP, etc.)
    This looks awesome and will likely replace my spreadsheet I have. :)
    Thanked by (3)Asim Hxxx corbpie
    Unfortunately, in my country, sticky note and maker may count as weapon, I cannot use sticky note at will. :#
  • @corbpie
    -You didn't used a framework so you are missing good security practices. Good thing you used PDO.
    @everyone
    -This project is not to be hosted publicly accessible. Basically there is zero user management, means no login, no secure sessions, no token etc. I guess is ok if you host it in your local computer where nobody can access it from the outside.
  • HxxxHxxx OG
    edited January 2021
    This is why you don't reinvent the wheel, instead you choose from one of the proven secure and stable PHP frameworks which already include best user management practices. User management is never overkill.
    This is your opinion, but is not the year 1998.
    Will work on that just for Disk & network speeds though.
    Thank you, they're on the todo list.
    Export & import would be great however these can only be done once it is settled on the final fields/inputs.
    The NS1 and NS2? No, i was just cutting down on using "Name server"
    Thanks, that is a nice idea and has been noted.
