Changing domain.com/cpanel
in Technical
When using cPanel shared, or reseller hosting, is it possible, as a user/customer, to disable, or change the login through:
domain.com/cpanel
I have figured out how to disable cpanel.domain.com, but not the /cpanel
your host provider will need to disable proxying that sub directory from tweak settings.
I doubt its possible to override that in .htaccess
Xsltel OU | A One-man show powered by 250 grams of brain
Offering reliable hosting services, Server management since 2011 and free cPanel hosting since 2020
Yes - .htaccess from user's cPanel account doesn't help.
Is that a normal thing to ask the provider?
Can it be done on a per-customer level?
I would expect it to require a server restart at least.
You have to talk to the provider if its only for one or a few domains,
https://forums.cpanel.net/threads/possible-to-disable-domain-com-cpanel-for-client.468861/
https://clients.mrvm.net
actually after further checking I don't see an option to disable that from tweak settings. I mixed that with subdomain in my first reply.
however its possible to achieve that by these commands
cp /var/cpanel/templates/apache2_4/ea4_main.default /var/cpanel/templates/apache2_4/ea4_main.local
then editing the new file
and finding and commenting these lines
ScriptAliasMatch ^/?controlpanel/?$ /usr/local/cpanel/cgi-sys/redirect.cgi
ScriptAliasMatch ^/?cpanel/?$ /usr/local/cpanel/cgi-sys/redirect.cgi
ScriptAliasMatch ^/?kpanel/?$ /usr/local/cpanel/cgi-sys/redirect.cgi
ScriptAliasMatch ^/?securecontrolpanel/?$ /usr/local/cpanel/cgi-sys/sredirect.cgi
ScriptAliasMatch ^/?securecpanel/?$ /usr/local/cpanel/cgi-sys/sredirect.cgi
ScriptAliasMatch ^/?securewhm/?$ /usr/local/cpanel/cgi-sys/swhmredirect.cgi
ScriptAliasMatch ^/?webmail$ /usr/local/cpanel/cgi-sys/wredirect.cgi
ScriptAliasMatch ^/?webmail/ /usr/local/cpanel/cgi-sys/wredirect.cgi
ScriptAliasMatch ^/?whm/?$ /usr/local/cpanel/cgi-sys/whmredirect.cgi
then
/scripts/rebuildhttpdconf
/scripts/restartsrv_httpd
if someone need to do it on their cPanel server
If you're using Cloudflare, you can do it using their page rules.
For example: domain.tld/cpanel -> domain.tld.
Though if you're on the free plan, you won't have enough rules if you'd like to redirect all cPanel-related URLs (/cpanel, /whm, /webmail, :2083, :2087, :2096, ...)
How much of a "hacking" risk does leaving those available pose?
A friend got warned about these for their website, and asked me if it could be blocked somehow.
I suppose a good, strong password, with any decent provider (that blocks 1000 tries per minute) should suffice. Am I wrong?
Not much risk I think and yes you're right, that should be enough.
You could also enable 2FA.
When I attempted to do this, I was concerned about L4 DDoS attacks to the cPanel server, so I wanted to try and make it a bit harder to get the server IP.
I gave up when I found out that there are many URLs and ports to try to redirect/hide.
From what I could tell, when using Cloudflare, you can't get the server's IP, even when you are redirected to domain.com/cpanel.
Of course, whm.domain.com, cpanel.domain.com etc. are disabled (aren't resolved through DNS), and mail.domain.com is not on the website's hosting server.
2FA is a huge hassle, and not sure if I'm too naive, but I'm not a big fan of that. I understand it makes unauthorized access exponentially more difficult.
