OpenVPN Connected but no internet
Hi,
I have recently bough VPS from @Abdullah (webhorizon.in)
Earlier I was using dedicated VPS for openvpn. Now I am switched to NAT VPS. The problem is when I am connecting to OpenVPN through mobile or desktop app. It is connecting to VPN but no internet is working. I am not expert in VPS so need help!
Please let me know if any screenshot or log to be shown here.
You install openvpn the script way or manually?
the script way by this commnad: wget https://git.io/vpn -O openvpn-install.sh && bash openvpn-install.sh
Do you have iptables installed on your VPS? If so, you may need to add these lines to your config:
Substitute with your IP and interface names.
@abskillz when you buy from @Abdullah there is no internet -- u don't need it.
hi, can you please elaborate further more? Where I have to put IP and interface name? and Which IP IPV4 or internal IP ?
Hi, I just bought while ago. I don't know why no internet maybe I am doing some mistake in configuaration.
Have you enabled Tun? Which port you are using?
Yes, tun is enabel. For the port I am using from my given 20 ports. Like my internal IP is ending with 180 so I am using 18005 for OpenVPN
i was fooling around, i am sure he will help you if he has time. so open a ticket,.
But why are you using OpenVPN instead of wireguard which is faster than OpenVPN
@Abdullah had linked both in his thread
OpenVPN: https://github.com/Nyr/openvpn-install
Wireguard: https://github.com/Nyr/wireguard-install
Both scripts are well proofed , why not use them ?
there is no problem in NATs as i am also using them at 2 locations . No issues faced
I installed wireguard also now, but same issue connected but no internet.
Are you using your allotted ports ?
have you activated forwader on kernel ?
Yes, as I told you my internal IP ending with 180 so I am using 18001-18020 port
Hi, did the same but not working :-)
Check your
client.conf
it should look like below,Could be your ISP. Try using v2ray. It works even if your ISP is blocking VPN traffic.
If you are sure that the vpn is connected successfully (able to ping the server over the vpn) just no internet access, then sounds like iptables not set up correctly.
I also bought a NAT VPS from @Abdullah recently and both of @Nyr scripts worked flawlessly for me. Did you use those or some other way? If you haven't tried those already I highly recommend reinstalling fresh using those scripts instead. Takes away a lot of the iptables/routing config issues that I used to struggle with in the past.
I don't know why but I had this issue once, too. It had to do with which DNS I selected during Nyr's setup. I think only system resolvers option worked for me. Try this and/or change your end user device's DNS manually to Google DNS or Quad9/CF..
You are missing NAT rules in iptables/nftables.
