@LeonDynamic said:
I wonder if all the OVH datacentres have got lovely wood flooring throughout or just isolated to SBG1
RBX 4 definitely, because it's the one they invented that kind of structure used for SBG2 in the first place.
I'd guess SBG3 also is pretty much the same...
from images you only can guess that they build something similar in BHS, but only inside the bigger halls:
I'd say chance for wooden floors in between: highly likely ?♂️
Gravelines otherwise seems different because they reused old production halls that weren't so high and therefore they build kind of smaller cages inside that appear to be rather (thin) metal and have no second floor at all:
Man, their whole DC is a ticking time bomb.
merry xmas.
OVH no longer have plans to restart SBG1 at all and are moving servers to different datacenters.
Dogex pro! I'm losing millions!! /s
SBG1 are four container boxes, I believe. So, those don't have wooden floors.
SBG2 had wooden floors, and I assume their other buildings have the same feature.
so yeah, assess your risks ;-)
