ApeWeb VPS Bonanza. From £1.20pm with dual core Ryzen, nvme and dedicated IPv4.
13»
  • Can I order this custom package as well? or just for skorupion?
    edited April 2021
    @pkr said:
    3GB Ram
    3 Cores @ 3.4 GHz (Ryzen 5)
    100GB NVME storage
    1x ipv4
    Unmetered Bandwidth at gigabit
    and
    4GB Ram
    4 Cores @ 3.4 GHz (Ryzen 5)
    100GB NVME storage
    1x ipv4
    how much? @ApeWeb
    WARNING look at disk speeds(slow for NVME), and variable internet speed. Sadly for me that's a deal breaker and I requested a refund sorry ApeWeb (maybe i will come back when I will need more resources). Btw they provide price excluding VAT, so beware. Above your post I posted yabs, and think if it's worth it.
    Edit: I will reconsider ordering via a friend from the USA, so as not to pay VAT
    edited April 2021
    Seems he edited the description, and if it was exclusive then he would dm me the offer. BEWARE look YABS oh and if from eu add vat on top
    edited April 2021
    Giving your VPS a second chanse at showing its disk speeds:
    Real NVME:
    Read       | 137.12 MB/s  (34.2k) | 863.24 MB/s  (13.4k)
    Write      | 137.48 MB/s  (34.3k) | 867.79 MB/s  (13.5k)
    Total      | 274.60 MB/s  (68.6k) | 1.73 GB/s    (27.0k)
    Read       | 1.13 GB/s     (2.2k) | 1.30 GB/s     (1.2k)
    Write      | 1.19 GB/s     (2.3k) | 1.38 GB/s     (1.3k)
    Total      | 2.32 GB/s     (4.5k) | 2.68 GB/s     (2.6k)
    Your NMVE(?):
    Read       | 36.15 MB/s    (9.0k) | 401.23 MB/s   (6.2k)
    Write      | 36.24 MB/s    (9.0k) | 403.34 MB/s   (6.3k)
    Total      | 72.40 MB/s   (18.1k) | 804.58 MB/s  (12.5k)
    Read       | 240.39 MB/s    (469) | 254.74 MB/s    (248)
    Write      | 253.16 MB/s    (494) | 271.71 MB/s    (265)
    Total      | 493.56 MB/s    (963) | 526.45 MB/s    (513)
    If this improves imma order via a friend that lives in the USA
    Inode capped at 80k
    Thanked by (1)Matt247
    edited April 2021
    here's mine now
    [root@cybertech ~]# curl -sL yabs.sh | bash -s -- -4i
    #                     v2020-12-29                    #
    Wed Apr  7 10:23:32 +08 2021
    Processor  : AMD Ryzen 5 2600 Six-Core Processor
    CPU cores  : 4 @ 3393.622 MHz
    RAM        : 3.8 GiB
    Swap       : 32.0 MiB
    Disk       : 49.9 GiB
    Read       | 58.15 MB/s   (14.5k) | 216.25 MB/s   (3.3k)
    Write      | 58.25 MB/s   (14.5k) | 217.39 MB/s   (3.3k)
    Total      | 116.40 MB/s  (29.1k) | 433.65 MB/s   (6.7k)
    Read       | 279.57 MB/s    (546) | 606.02 MB/s    (591)
    Write      | 294.43 MB/s    (575) | 646.38 MB/s    (631)
    Total      | 574.01 MB/s   (1.1k) | 1.25 GB/s     (1.2k)
    Geekbench 4 Benchmark Test:
    Single Core     | 3963
    Multi Core      | 11352
    Full Test       | https://browser.geekbench.com/v4/cpu/16116276
    I would note that not too long ago, vpses were doing good with SSD 10K IOPS on 4K, so yeah not a Biggie to me if the results aren't as high performing as some other providers show.
    if provider is limiting the IOPS per VM, it should (I think?) do well with multi tenants. but if this result isn't due to rate limit, and if it's a RAID 1 or worse, then hmmm.
  • ApeWebApeWeb Hosting Provider
    @cybertech said:
    here's mine now
    > #              Yet-Another-Bench-Script              #
    > #                     v2020-12-29                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 3.8 GiB
    > Swap       : 32.0 MiB
    > Disk       : 49.9 GiB
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > Block Size | 4k            (IOPS) | 64k           (IOPS)
    > Block Size | 512k          (IOPS) | 1m            (IOPS)
    > Test            | Value
    > Single Core     | 3963
    > Multi Core      | 11352
    This server is in raid 6.
    Thanked by (1)cybertech
    @pkr said:
    3GB Ram
    100GB NVME storage
    1x ipv4
    £6pm
    4GB Ram
    100GB NVME storage
    1x ipv4
    £7.50pm
    Real NVME:
    Your NMVE(?):
    Inode capped at 80k
    Disk io is not restricted. Looks like you have hit it at an unfortunate time when it was under load as those are lower results than I would have expected (although should still be perfectly usable). I would have offered to transfer you to a different node.
    edited April 2021
    Dude I'm getting those results (even at better time) on my Contabo VPS with NORMAL ssd in raid 10. Those in my opinion are not normal speeds for nvme
    Btw look at tickets, and refound me imma order via a friend that lives outside of eu to avoid vat
    Check your ticket it has already been replied to.
    Done thx :3
    To be fair i also had raised the same issue of network and speeds and then refunded
    I also had same disk speeds as YABS in the thread
  • My server with them has been solid. Is it worth requesting yours to be moved to a different server?
    Thanked by (1)ApeWeb
  • @AlexC said: My server with them has been solid.
    Same here. I'm somewhat surprised about the negative feedback. The benchmarks posted above look much better than many boxes I have with other providers which still do a great job.
    Thanked by (2)cybertech ApeWeb
  • Unmetered bandwidth ?
    Wondering what is the cheapest plan you can do with 60 mbps all day / night traffic allowed ?
    Minimum 10 gb disk.
    maybe something can be tweaked for the disk settings. DD is good.
     CPU Model             : AMD Ryzen 5 2600 Six-Core Processor
     CPU Cores             : 4
     CPU Frequency         : 3393.622 MHz
     CPU Cache             : 512 KB
     Total Disk            : 50.0 GB (7.5 GB Used)
     Total Mem             : 3929 MB (839 MB Used)
     Total Swap            : 31 MB (0 MB Used)
     System uptime         : 2 days, 1 hour 46 min
     Load average          : 0.04, 0.03, 0.00
     OS                    : CentOS Linux release 8.3.2011
     Arch                  : x86_64 (64 Bit)
     Kernel                : 5.11.11-1.el8.elrepo.x86_64
     TCP CC                : bbr
     Virtualization        : KVM
     Organization          : AS201814 Meverywhere sp. z o.o.
     Region                : Mazovia
     I/O Speed(1st run)    : 2.0 GB/s
     I/O Speed(2nd run)    : 2.1 GB/s
     I/O Speed(3rd run)    : 2.1 GB/s
     Average I/O speed     : 2116.3 MB/s
     Node Name        Upload Speed      Download Speed      Latency
     Speedtest.net    939.04 Mbps       940.06 Mbps         10.46 ms
     Beijing    CU    229.63 Mbps       429.59 Mbps         337.67 ms
     Shanghai   CT    238.88 Mbps       584.47 Mbps         241.97 ms
     Shanghai   CU    250.91 Mbps       721.97 Mbps         317.03 ms
     Guangzhou  CT    345.55 Mbps       739.60 Mbps         226.95 ms
     Shenzhen   CU    248.18 Mbps       570.97 Mbps         313.01 ms
     Hongkong   CN    398.55 Mbps       949.21 Mbps         203.00 ms
     Singapore  SG    226.94 Mbps       642.04 Mbps         332.92 ms
     Tokyo      JP    100.30 Mbps       81.06 Mbps          235.05 ms
    Minimum 10 gb disk.
    Do you need ipv4?
  • edited April 2021
    @ApeWeb said:
    Do you need ipv4?
    Yes
    (Can be nat ipv4, with 20 ports forwaded)
    @codelock said:
    Yes
    70mbps Unmetered, 10gb nvme, 512mb memory, 1x ipv4 1x /112 ipv6. £6pm.
  • edited April 2021
    @ApeWeb can you pls check website is offline . I had PMed you yesterday but you have not replied
    The website is back up. We were experiencing a layer 7 denial of service attack on it but this has been mitigated now.
    ok thanks
  • Any News about your Moldova location ? :)
