Adguard - DNS Amplification Issues - HELP ( SOS )
edited May 2021 in Technical
Dear Les-bians,
Greeting, Hope Everyone is safe and sound in good shape.
Well, Recently I installed a Adguard + Wireguard on a VPS Server. To my suprise am getting New Spam Clients from China and Some other Countries.
Especaillay pizzaseo .com& other clients.
So, kindly say how to stop these, and let me get to know that what i have messed up.
  • @Freek may be able to help?
    Thanked by (2)deepak_leb Freek
  • How it works?
    Email address get from whois domain?
    Thanked by (1)deepak_leb
  • @youandri said:
    How it works?
    Not Spam emails but Spam clients.
    Client(s) who got the IP Address of new DNS server and started using it for DDoS.
    Thanked by (2)deepak_leb youandri
  • Disable DNS over UDP.
    Enable DNS over TLS.
    No amplification attack possible.
    Thanked by (2)_MS_ deepak_leb
  • You mean AdGuard home right? The below works if you are only using AdGuard home to serve your VPS and WireGuard clients.
    Under Settings | DNS settings, scroll down to the Access Control fields at the bottom. Under allowed clients, enter in ip ranges to whitelist. For example, I have whitelisted my VPS and wireguard clients in the 10.9.0.0/24 range.
    127.0.0.1
    10.9.0.0/24
  • @Freek is the DNS Master
  • edited May 2021
    Acl local private ip only
    Thanked by (2)deepak_leb vimalware
    Could you elaborate & PM me ?
    Need some detailed description, since am not much into these things
    Will contact him
    Thank you. Will get back to him
    127.0.0.1
    10.9.0.0/24
    Let me check on to it & pm you
  • edited May 2021
    Thanks for the mention :)
    This will indeed fix your problems, @deepak_leb .But if you absolutely must DNS over UDP, you can try the following:
    But I do wonder; is AdGuard listening on the correct interface? Since it shouldn't be listening on your public IP if you use WireGuard to connect...
    Yes you might be 100% correct as probably in listening interface all interfaces were selected instead of only wireguard interface . Saw the same issue when i did this exact mistake . Once Wireguard interface is selected their are no unknown clients
    I only selected eth0 Wireguard interface alone
    eth0 should be the NIC and wg0 as wireguard interface or whatever name was given for listening interface
    Any guides pls
  • @deepak_leb said:
    Any guides pls
    No guide required . Just select wg0 in listen interface when you setup Adguard
    Thanked by (3)deepak_leb Freek Ouji
  • Add the domain in disallowed domains and limit the rate limit for example 3 per second
  • edited May 2021
    But I couldnt get the wg0. On interfaces, am getting only eth0 and l0 interfaces
  • Whats is your wireguard interface ? Select that interface on Adguard setup page , listen interface
    Will pm u
  • Or maybe you can stop setting up your own DNS server and use 94.140.14.14 / 94.140.15.15 instead
  • Everything has been sorted out. Thank all for your time 🙂
    Write a tutorial for LES blog :).
    Please share how you solved your issue. Like I told you via PM; a forum is to share knowledge, not to keep it secret in private messages.
    🥺 Nothing special, Before Installating the wireguard, I simply installed the Adguard, that's in DNS Interface I haven't got the wireguard WgO interface.
    Besides I followed the NAT Vps Guide blindly though I don't use that NAT VPS
  • So I guess OP replicated the setup I use.
    1) have the adguard/pihole/ANY_dnsserver listen exclusively on wg0 (wireguard nic)
    2) use wireguard tunnel for all internet traffic and the private wg0 ip for dns-nameserver value .
    The dns bots will move on.
    Yep
