IP v4 issue on mrvm.net NAT VPS
Hi guys,
I have got NAT VM delivered recently. But the thing is, I am unable to connect using IP v4, not even able to ping that IP.
However, the IP v6 works just fine. The problem is, my ISP doesn't have IP v6 support, so I have to ssh in to one of my other VM in order to connect ip v6 instance. So, it will be really helpful if IP v4 works out.
Thanks!
Did you setup port forwarding?
Shouldn't need to - ssh port is included automagically.
@coo , which location? Have you verified the ipv4 you're connecting to is what you're expecting? What command are you using to get in via ssh?
https://clients.mrvm.net/submitticket.php
Did you connect using correct SSH port ? Its a NAT VPS so ssh port will not be default 22
Correct.
Check your email, IIRC, there should be details of which port's are being forwarded to what.
A common problem is trying to connect to 172.16.x.x
That won’t work as it is an internal IP.
The external IPv4 is visible in the client area when looking at the service page.
You will also see the external ssh port on that same page.
Wikipedia on 172.16.x.x might help with understanding why one can't connect to 172.16.x.x.
MetalVPS
Which ISP are you using? If they don't support IPv6 in 2021, it's time to name and shame them, and set up an IPv6 tunnel
Most wired isps in india don't have ipv6
@coo
Let us know if you got it sorted, otherwise you should open a ticket.
And Indonesia. IPV6 is a 1st world country privelege.
