VirMach
I think there may be enough to say about virmach to warrant a thread unto itself - so may as well start this one right here right now
(Following some recent discussion in another thread here)
For now I'll just summarize my assessment from last couple years in a few of their USA locations: solid systems, great uptime, modest specs, okay-ish network (depending on what you need it for - it is colocrossing after all) ... Also reasonable to deal with in terms of support.
So all things considered I've been pleasantly surprised. I'm guessing that the CPU limits (etc) are actually fine for some medium-load webserver duty (such as this forum) - but probably less so for more sustained usage patterns such as transcoding.
tl;dr: could be a good option for many but not all lowend applications - and proven to be worthy of consideration (in my own limited experience at least).
Questions, suggestions, critical comments, horror stories, and/or kudos and benchmarks welcome.
Also feel free to mention any good alternatives in the general price range
HS4LIFE (+ (* 3 4) (* 5 6))
Apologies for not including more gory details in the OP. I'm typing with my thumbs, 6 hours into an 11-hour train ride ... Will be adding more bits and pieces in subsequent posts in this thread at random intervals - possibly for the next several years. (That's an inside joke referencing the 2018 BF flash sale thread from the old forum ...)
Take a nap; sober up. Godspeed!
"The good stuff comes on slow ..."
Also, just to note that VirMach is not exclusively CC, e.g., at their Seattle location.
Their services are rock solid. But, if you are thinking about using their promo services purchased during BF / CM / XMAS for anything beyond initial bench-marking, idling and hosting odd websites or services that require sustained Disk I/O and 'fair share' of CPU cycles, you are better off looking elsewhere, for you'll likely get a crash course in learning to manage expectations and a resounding reminder that you get exactly what you pay for :P
I'm using their BF specials for sustained 40 iops, which isn't 'heavy' but also isn't zero. They clearly publish their limits, and I'm in a position where I can throttle my own stuff to stay within them. The most annoying thing for me is that they hit me for iops once, and gave me a log of it, and their log numbers were significantly different from what I was measuring in
/proc/diskstats
. I don't understand why there's a difference or where it came from, so I ended up just scaling my measurements by a factor, which is an ugly hack.the best thing about Virmach is rock solid stability. IMHO its really suitable for production but in order to do so i believe the resources are really limited on the CPU and I/O side. perhaps such is the specs for BF deals. A simple nench shows some insight on how it is regulated.
The same happened with me once.
While I still keep a couple of $3/y and $5/y services with them that I use for playing around with random scripts, apps etc, I have largely migrated casual projects and personal web services to other hosting companies that do not race to the bottom with their prices and consequently do not suffer from overcrowded nodes or general paucity of resources. Also, servers in USA have little use for me, so that has certainly helped me move on from some seemingly incredible deals I had with Virmach.
At the end of the day, as long as one understands his/her requirements vis-à-vis limitations of said VM, things will likely end on a pleasant note.
I had some question about their KVM lite.
I had OpenVZ with them which was recently migrated to KVM lite for free.(bought it in last yr sale)
I dont find any AUP for their KVM lite. Does someone know about their AUP.
What is the cpu share for KVM lite.?
50GB SSD
3 cores
2TB BW
2GB RAM
12$/yr.
KVM
https://webhorizon.net
I've got 2 VPS that haven't provisioned yet, one since Friday. Presumably other folks are the same?
Funny how we moved to a new forum but have no problem advertising CCs biggest progeny and stating "it's super awesome".
I mean, I get it, a stable cheap service, is a stable cheap service, however, you have to see the irony in this thread being here (regardless of the fact they 'use more datacenters than only CC'). Their main marketing point and ability to offer said services so cheaply is the fact they rely on CC to basically subsidize them with cheap servers and hosting like any other CC elevated brand has in the past.
Just saying, moving to a new forum because we are wanting to get away from CC, then we advertise their largest brand here.. for sure gives me a chuckle to read...
Cheers!
Have an Allwinner H3 device? Android? Check out H3Droid! | Lichee Pi Zero - The 6$ SBC | #SYSarm - Get It! | Atomic Pi - $35 x86 SBC
20+ Years IT Experience in Linux/Windows Hosting, Administration and Development
@TheLinuxBug
Do you often cut off your nose to spite your face? Just saying. ;-)
If your question is, do I avoid all CC properties and related providers like the plague? Then the answer is most assuredly, YES!
So, yes, in this case I would, because, I personally would NEVER recommend a single provider mixed up with CC to anyone.
That's just me though, for some people price is more important than anything else, so I am sure they will blindly continue to purchase anyway. I just won't be one of those out there promoting them and suggesting people gamble on it.
my 2 cents.
Cheers!
hello @Abdulla
I would just assume resource limits as described in https://virmach.com/terms-conditions/#tab1
(these do seem sufficiently restrictive )
@TheLinuxBug
it's a fair cop.
I am indeed an incorrigible troll.
Drat! Missed the $1 - OoS
I didn't, but shit still died before I could checkout.
Well, it did die on me 1st time but when retried it was OoS.
Got a nice Cloudflare page after that.
Ach, maybe there were only 5 available
Thanks for reminding me about the history of virmach.
Cheap as they are, will not be supporting them any longer.
Just learned about them now, after renting for a full year. At least I'll pass on the $50 8GB/80GB from them. Might get UltraVPS 8GB instead, even if it's higher pricing. Their 4GB SAS is the most reliable VPS I've ever had and the pricing is still unbeatable for the reliability.
Doesn't AlphaVPS use CC for their LA location? So you'd put Alex on your blacklist, too, even his UK/Clouvider location?
Mine said it was "Active" but also said something like "Virtual server not found" on the Manage Product page. If you go to the Control Panel the server was there and working fine.
I had that until late last night - now Active and Solus available.
So the next question is, can I use HE.net or tunnelbroker to automagic a proper IPv6 address for my CC Virmach?
Thank you. Yes it is restrictive enough.
That makes Any Low End Spirit box look Prettier
Replying to myself. Yes, easily, and the speed is pretty decent (so far).
Just send them a friendly note that you did this. The TCP fixup notices spam the shit out of the hypervisor kernel - and it can't be turned off. If they don't set it to ignore these notices, you will be spamming the living fuck out of the logs.
Will do, thanks, I had no idea!
Most don't. It's annoying for admins to deal with, and makes work a little more difficult if they're not already setup to handle this.
That said, I ran n+1 (where N=last) as a backup using HE+VirMach for a couple years in the event of everything dying outside of Buffalo.
Worked great. Just a bit slow for UDP and a shitty way to add IPv6 to the box.
