SSH Port Client Connection
Hi all, I need some hints from you.
My problem is NAT service and port 22 not used to SSH client connection.
I bought a NAT service about 2 months ago and port 22 of SSH client connection is ok.
Last week, I bought a same NAT service and make a SSH conection, however the connection time out, then I open a ticket, and My anwser open ticket help is port 22 not used to SSH client connection
Two days ago, I bought another NAT service, then I got through the conection with IPv4 server with port 22.
I don't know what happen yet, although I have checked the page service in many time. Port 22 is also default port to my server.
Thanks a lot,
It is NAT, your assigned external port for SSH for ipv4 is forwarded to your port 22. If you want to directly use port 22 use ipv6.
Read carefully the instructions of the welcome email you received from your provider. You normally get an external shared IPv4 and a custom port that is redirect to your SSH port on the internal network.
It seems highly unlikely that you are using port 22 for SSH on a NAT service, please provide more specific information, xxx out the last 2 octets of the IP's and paste the instruction emails or something, I am sure we can help you out.
Many thanks to @InceptionHosting , and I am very sure using port 22 for SSH on a NAT service.
Here is IPv4 45.61.147.135 could you check it out when you have spare time.
And some informations paste from email;
IPv4 NAT IP Information
You have been assigned a range of 20 ports along with your NAT IPv4 address and 1 redirection port for ssh.
The first 20 ports are based on the last octet of your IP, you can use these for anything you want, examples below:
EXAMPLES:
172.16.0.3 has the following port range forwarded: 301 - 320
172.16.0.13 has the following port range forwarded: 1301 - 1320
If you intend to connect using IPv4, you also get 1 extra forwarded port to your servers port 22 (default ssh port). This is added to your allocated ports.
EXAMPLES:
192.168.0.3 has the following port forwarded to port 22: - 321
That IP may well have ssh running on it but it's not your NAT instance. It says this in the email you quote.
That is your public IPv4 address.
@Kingzerro, what is your local/private VPS IPv4 address?
If your local/provate IPv4 address
172.16.0.3
, then your SSH port using public IPv4 address45.61.147.135
port321
172.16.0.17
port1721
172.16.0.100
port10021
Thanks @chocolateshirt, It works like that. +1:
That was your problem
As I'm tagged in this thread, I believe it was you who also opened a ticket about this where I answered that you should check your service details page for the IP and port to use?
https://clients.mrvm.net
Is it such a wise idea to display these details in public (albeit as a picture)?
That VPS is not running anymore. And never will boot again.
Is it such a wise idea to assign <1024 ports to a NAT container?
As long as it isn’t in use by another application, I don’t see why not?
It is against the ”rules” but I’ve been doing this for many years now and this is rhe first time I hear that question.
