@spiritlhl said:
I have the VPS in Euserv, but i can't conect it in my house...
Buy a VPS or a NAT VPS with both IPv4 and IPv6, you can direct SSH from the VPS to you euserv or set a wireguard on your cheap VPS, then you can connect IPv6 only site..
@yoursunny
Buy another VPS with both IPv4 and IPv6.
What about setting up a he.net IPv6 tunnel at home? https://tunnelbroker.net/
Connect cloudflare warp "VPN". It does provide ipv6 too.
Try cloud flare warp 1.1.1.1
