I found vServer.site's client area hard to access. Every link I clicked on redirects me to the login page before loading the actual page I am accessing.
For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars! Looking for cost-effective Managed/Anycast/DDoS-Protected/Geo DNS Services? Try ClouDNS (aff).
Sounds like an issue with session cookies, make sure your browser is accepting them for their site, or try clearing your cache, if you haven't already.
Most likely this... however I did not explicitly not accepting cookies from the site. There is a cookie notice when I entered the main site but not the client area?
Also realized that Nexusbyte's client area is having the same problem. Also I have not explicitly disabled cookies from the site as well.
maybe some antivirus/anti-malware/anti-whatever software playing tricks on you then?
@tototo said:
Switching your browser to "incognito browsing mode" may solve the problem.
(In such a case, the error is often caused by extensions like adblock)
I started incognito mode on Chrome and still facing the same issue...?
Looks to be all good from here.
No issues this side also
THIS is JUST the beginning
Maybe the account has been closed.
Perhaps consider taking a look inside the Chrome Development Tools CTRL-Shift-I and see what might be learned there?
MetalVPS
Does it happen with other browsers as well? No issues here. I'm on Firefox.
Hallowed be thy name.
