I had surprisingly won a 1 year "freebie" last BF... I was on a mobile phone and won twice? Returned one freebie.
Here is the YABS from the other one. 270 days' uptime and counting. Not sure what to make of it ;-)
Fri Aug 27 12:45:37 BST 2021
Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU cores : 2 @ 2800.000 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 1.9 GiB
Swap : 2.0 GiB
Disk : 42.3 GiB
Read | 76.39 MB/s (19.0k) | 652.21 MB/s (10.1k)
Write | 76.60 MB/s (19.1k) | 655.64 MB/s (10.2k)
Total | 152.99 MB/s (38.2k) | 1.30 GB/s (20.4k)
Read | 779.13 MB/s (1.5k) | 718.94 MB/s (702)
Write | 820.52 MB/s (1.6k) | 766.82 MB/s (748)
Total | 1.59 GB/s (3.1k) | 1.48 GB/s (1.4k)
Clouvider | London, UK (10G) | 344 Mbits/sec | 256 Mbits/sec
Online.net | Paris, FR (10G) | 370 Mbits/sec | 293 Mbits/sec
WorldStream | The Netherlands (10G) | 157 Mbits/sec | 224 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | busy | busy
Clouvider | NYC, NY, US (10G) | 760 Mbits/sec | 514 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 508 Mbits/sec | 439 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 508 Mbits/sec | 409 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | 270 Mbits/sec | 343 Mbits/sec
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 2521
Multi Core | 4485
Full Test | https://browser.geekbench.com/v4/cpu/16322153
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 511
Multi Core | 918
Full Test | https://browser.geekbench.com/v5/cpu/9533276
All moved in and set up on new-to-me "ancient" HP Blade server colocated with LevelOneServers at HiVelocity in Dallas! Thanks again to Ian @Ian_Dot_Tech and Amit at LevelOneServers for five star onboarding! Ian and Amit really care about their customers, one of whom I am delighted to be! Thanks again also to @CamoYoshi for selling the server and answering questions! Thanks to Pat Volkerding and Slackware, Linux, and FSF GNU, for the OS! Thanks to Microsoft for the free Windows 10 Developer VMWare image that I used to access the server with IE11 and ActiveX for the Slackware install! Thanks to @Mason for yabs! Thanks to everybody here at LES for teaching and inspiring me!
In the yabs below, I am curious about:
Why do many of the IPv4 send speeds seem much faster than the IPv4 receive speeds from the same location? I appreciate that the opposite direction routes might be different, but the speed difference seems bigger that I expected.
Why do many of the IPv6 send speeds seem slower than the corresponding IPv4 send speeds to the same location?
Anything else you guys see which looks interesting. . . .
WTF is that? Definitely not a VPS.. must be a dedi, right?
@Abdullah said: @Not_Oles for lower Recv speeds, ssd might be the bottleneck. you can do some disk speed tests ?
One way to rule this out is to run the test from a RAM disk (the server has enough RAM to be able to do this, I think); YABS writes all it's files to the same directory it's stored in.
Hi @CamoYoshi@Abdullah I seem to remember running yabs inside a RAM disk and it gave me zero for all the disk read/write tests. It was awhile ago, and I don't remember exactly. Maybe @Mason can give us a tip on whether yabs should be expected to work differently inside a RAM disk? Thanks!
@CamoYoshi Do the read/write speeds look to you as might be expected? Thanks!
@CamoYoshi Nevermind 🤦♂️ + apologies! I just now remembered that you had included a yabs in the info.txt file attached to your ad. Checking the info.txt file again, the results seem consistent with the new yabs that I posted above.
how did you manage to make 20G? their minimum is 50G
Huh? EC2 default is 8G for me.
OnePoundEmail (aff link)
sorry misread it. 50G is for Oracle.
Hosthatch SG 4G (double RAM, storage and bandwidth when paid biannually) $35 py.
Racknerd, Chicago
Fri Aug 27 12:45:37 BST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU cores : 2 @ 2800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 2.0 GiB Disk : 42.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 76.39 MB/s (19.0k) | 652.21 MB/s (10.1k) Write | 76.60 MB/s (19.1k) | 655.64 MB/s (10.2k) Total | 152.99 MB/s (38.2k) | 1.30 GB/s (20.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 779.13 MB/s (1.5k) | 718.94 MB/s (702) Write | 820.52 MB/s (1.6k) | 766.82 MB/s (748) Total | 1.59 GB/s (3.1k) | 1.48 GB/s (1.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 344 Mbits/sec | 256 Mbits/sec Online.net | Paris, FR (10G) | 370 Mbits/sec | 293 Mbits/sec WorldStream | The Netherlands (10G) | 157 Mbits/sec | 224 Mbits/sec Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 760 Mbits/sec | 514 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 508 Mbits/sec | 439 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 508 Mbits/sec | 409 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 270 Mbits/sec | 343 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2521 Multi Core | 4485 Full Test | https://browser.geekbench.com/v4/cpu/16322153 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 511 Multi Core | 918 Full Test | https://browser.geekbench.com/v5/cpu/9533276VPS reviews and benchmarks |
My Evolution-Host.com Free VPS.
That is awesome free VPS you have @giang
What location? Thought the GB5 score might have been a bit higher for a 2288g
MetalVPS
It's in OVH Roubaix, France.
@Not_Oles said:
root@darkstar is a giveaway
Yep! Want a free darkstar account?
MetalVPS
Kind sir
For an offer like this , yea please .. maybe a few days
Please PM me an ed25519 ssh public key whenever you are ready.
MetalVPS
https://webhorizon.net
my desktop:
Your desktop has only 23gb of disk, that's gruesome
I am pretty sure iperf in yabs does not write anything to the disks, so this won't apply ;-)
(and disk speed test are directly above anyway ;-)))
10GB is more than enough for debian 11.
Advin Servers, Dallas, USA- Ryzen 5 test machine
Fri Aug 27 19:26:55 EDT 2021
Processor : AMD Ryzen 9 5900X 12-Core Processor
CPU cores : 2 @ 3692.984 MHz
AES-NI : ✔ Enabled
RAM : 15.3 GiB
Swap : 0.0 KiB
Disk : 155.5 GiB
iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 832 Mbits/sec | 388 Mbits/sec Online.net | Paris, FR (10G) | 842 Mbits/sec | 637 Mbits/sec WorldStream | The Netherlands (10G) | 750 Mbits/sec | 868 Mbits/sec Biznet | Jakarta, Indonesia (1G) | 563 Mbits/sec | 35.0 Mbits/sec Clouvider | NYC, NY, US (10G) | 915 Mbits/sec | 926 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 919 Mbits/sec | 927 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 922 Mbits/sec | 927 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 798 Mbits/sec | 839 Mbits/secGeekbench 4 Benchmark Test:
Test | Value
Single Core | 6557
Multi Core | 11035
Full Test | https://browser.geekbench.com/v4/cpu/16322866
Test | Value
Single Core | 1533
Multi Core | 2792
Full Test | https://browser.geekbench.com/v5/cpu/9542466
3700X Yep, EPYC one is definitely a dedi
which cost 34 EUR for me.
Hi @CamoYoshi @Abdullah I seem to remember running yabs inside a RAM disk and it gave me zero for all the disk read/write tests. It was awhile ago, and I don't remember exactly. Maybe @Mason can give us a tip on whether yabs should be expected to work differently inside a RAM disk? Thanks!
MetalVPS
Just tested in /dev/shm, all zeros. I don't think fio plays well with ram disks. Probably due to the "direct" flag being used.
@Mason Thanks for checking and explaining!
MetalVPS
Virmach free VPS
Sultan Muda - Amazon Store
You could still test the speeds of the network and just ignore the disk results, perhaps. Wasn't aware of the fio limitations... TIL!
