1242526272830»
  • @mikho said:
    @bikegremlin
    Care to create new topics instead of posting in this one?
    Sure you will get more attention to your posts 👍
    No problem - it makes sense. Having a separate thread for each topic. That would make it easier to find the needed info later on.
  • vyasvyas OGRetired
    edited June 2022
    I understand there is some shit show going on in Oxygen pagebuilder world..
    @ympker would you have any update?
    I am sorry, but I don't really follow Oxygen Builder news. I think I am in one of their FB groups, but I never used/bought the product.
    Thanked by (1)vyas
  • Hi,
    What basic plugins do you guys normally recommend?
  • @dosai said:
    Hi,
    Firewall - Wordfence or WP Cerber
    Caching - W3 Total Cache or LiteSpeed Cache
    Optimization - Autoptimize or Fast Velocity Minify
    SEO - SEOPress or The SEO Framework
    Backup - UpdraftPlus or WPvivid
    Thanked by (3)dosai bikegremlin Ympker
  • Yesterday I got DDoS'd on wp-cron.
    178.32.148.251 - - [10/Jul/2022:05:56:10 +0000] "GET /wp-cron.php?93493684389 HTTP/1.1" 508 3976 "https://www.google.com.af/search?q=doma.in/wp-cron.php" "Mozilla/5.0 (Linux x86_64; rv:63.0) Gecko/20210627 Firefox/63.0"
    I looked into wp-config.php and define('DISABLE_WP_CRON', true); was already present.
    Anybody have any idea?
  • DISABLE_WP_CRON will disable wp-cron checks on every request, so you can set your own timing for it. It will not disable the WP Cron system entirely.
    You can block wp-cron.php in your firewall or using .htaccess
    Thanked by (2)dosai Ympker
