[request] 1 dolar VPS with IPV6
Hello!! looking something really cheap, just to test if my vpn works.
i dont have ipv6 (damn isp) but with openvpn i make it work.
i want a cheap vps with ipv6 as a personal vpn (just to have ipv6)
i ordered a nat servers, but still not get the info from provider so, any other? preferably on USA
    Just for clarity, you want to pay $1 p/month or $12 p/year?
    if you only need it to test then use one of the free amazon tier ones https://aws.amazon.com/free/
    A provider is essentially paying you to use it (none nat) when it is just $1
  • hey! dont get angry.
    Not angry :) :+1:
    Was trying to help.
    If you just need one for short term test i will give you one, no need to pay.
  • i dont know, you made me think about it....
    let me wait for the nat, if not, i send you a message
  • Nat is just fine if you need ipv6. I am doing the same thing on @mikho 's box
  • Nat vps + wireguard + pi hole is all you need.. 4 usd per year for 128 MB vps is more than enough..
  • i am just waiting the nat vps, i know what to do. just want to confirm it works =)
    pi-hole for what? lol
  • dont get angry
    Thanked by (1)dedicados
  • Take an Amitz a day and temper/anger will never be an issue.
    Thanked by (1)poisson
    Pi hole inside nat or standalone?
  • FHRFHR Hosting ProviderOG
    Try Tunnelbroker.net from HE, it's free. You do need a public IPv4 though.
  • and dont get angry
  • instructions unclear
    pihole stuck in popo, please advice!
    ain't mad, just saying ... @Amitz
    Also ... with regard to the ipv6 (and not exactly responsive to your $1 request, but maybe for future reference) - @freerangecloud is all about the ipv6 support, and they do some nice deals. Maybe they'd consider an ipv6-only offer, who knows?
    HS4LIFE (+ (* 3 4) (* 5 6))
    Of course pihole inside nat..
    Does wireguard run on OVZ7?
    Got a few inceptionhosting nat vps
  • uptimeuptime OG
    edited December 2019
    Also might do well to spin up an hourly LunaNode - I think their ipv6 setup is pretty smooth
    Not sure what the minimum initial deposit is, but it might be just $5 (or $10?)
  • FHR said: Try Tunnelbroker.net from HE, it's free. You do need a public IPv4 though.
    ISP blocks also ping:
    IP is not ICMP pingable. Please make sure ICMP is not blocked. If you are blocking ICMP, please allow 66.220.2.74 through your firewall.
    $3.5 vps from vultr worked great, using this:
    # apt-get update
    # apt-get install gnupg
    # apt-key adv --keyserver keyserver.ubuntu.com --recv-keys AA8E81B4331F7F50
    # apt-get install ca-certificates nano openssh-client openssh-server;
    # curl -O https://raw.githubusercontent.com/angristan/openvpn-install/master/openvpn-install.sh
    # chmod +x openvpn-install.sh
    # ./openvpn-install.sh
    ipv6 done =)
    Thanked by (1)uptime
  • IPv6 connectivity
    IPv6 Supported
    Address 2904:z880:2:n1::13b:e001
    Type Native IPv6
    SLAAC No
    ICMP Reachable
    Hostname None
    ISP Chupa
    hey yo!
    dont get angry
  • vyasvyas OGRetired
    Did anybody say Angry?
    Of course it will work, but not on kernel level..
    Thanked by (1)skorous
  • skorousskorous OG
    Incidentally, this is why I asked about your requirement for KVM in your other thread but you ignored me.
    EDIT: ( comment for iandk not chocolateshirt )
