33% off in Frankfurt and Phoenix - FREE direct admin!! - 10 days left!
InceptionHostingInceptionHosting Hosting ProviderOG
edited September 2021 in Offers
Repeat offer for those that did not catch it the first time.
Coupon Code: FRAPHX33
Works on all plans with 1GB Ram or more in Frankfurt or Phoenix.
Order Frankfurt Plans: https://clients.inceptionhosting.com/cart.php?gid=34
Order Phoenix Plans: https://clients.inceptionhosting.com/cart.php?gid=35
Example plans:
  • 2 CPU Core (Equal Share E-2276G or similar)
  • 1 GB Ram DDR4
  • 20 GB Pure NVMe SSD Disk space (Enterprise grade)
  • 3000 GB Bandwidth @ 10 Gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
€1.68 /month
  • 2 GB Ram DDR4
  • 30 GB Pure NVMe SSD Disk space (Enterprise grade)
  • 6000 GB Bandwidth @ 10 gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
€3.35 /Month
  • 3 GB Ram DDR4
  • 40 GB Pure NVMe SSD Disk space (Enterprise grade)
  • 9000 GB Bandwidth @ 10 gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
€5.03 /Month
  • 4 GB Ram DDR4
  • 50 GB Pure NVMe SSD Disk space (Enterprise grade)
  • 12000 GB Bandwidth @ 10 gbit (shared)
  • 1 x IPv4 address
  • 1 x /64 IPv6
€6.70 /Month
All plans come with FREE complimentary DDOS protection and are eligible for FREE direct admin standard licenses on request.
Speed tests: https://as62240.net/speedtest
Network Diagnostics: https://as62240.net/tools
The new Pheonix Plans are on Clouviders network, they have IPv6 :)
Any questions are welcome :)
Cheers.
Ant.
  • Will the discount carry over for future plan upgrades? Thanks!
  • Just a small typo (if I may): Enterprize --> Enterprise
  • vyasvyas OGRetired
    Or maybe it was a hint..
    "Enter to win a prize = Enterprize" :-)
  • Do you support custom iso?
    Can i install Windows 10 and use Forex Trading app
  • bshbsh
    I've used 7 boxes from Ant. When I'd like to use a custom iso (out of the list of many many distros seen from SolusVM), he's always willing to mount. You would not be able upload iso by yourself.
    Thanked by (1)Ark
    Yes.
    You may :disappointed:
    We will add any ISO you request as long as it is legal for us to do so and Windows 10 is not sorry :)
    we do also have netbook.xyz which if you do a little google you can chain load and ISO with... happy to add them but some people also enjoy doing this :)
    Thanked by (2)casadebamburojo bsh
    [whispering] (There are still three occurrences of the said word)
    https://englishhelponline.files.wordpress.com/2010/02/embarrassed.jpg
  • we do also have netbook.xyz which if you do a little google...
    I think you mean https://netboot.xyz ...
    it comes from there
    Order page says speed is 1gbit.Can you clarify pl? Thx
    Edit: VPS plans list 1 gbit, the secondary heading does say 10 gbit (at node)
    10 at node, you can burst to 10Gbit on the VPS also.
    Thanked by (3)vyas cybertech vimalware
    I think it's hard to burst to maximum of 10
    # ethtool eth0
    Settings for eth0:
    Supported ports: [ ]
    Supported link modes: Not reported
    Supported pause frame use: No
    Supports auto-negotiation: No
    Supported FEC modes: Not reported
    Advertised link modes: Not reported
    Advertised pause frame use: No
    Advertised auto-negotiation: No
    Advertised FEC modes: Not reported
    Speed: Unknown!
    Duplex: Unknown! (255)
    Auto-negotiation: off
    Port: Other
    PHYAD: 0
    Transceiver: internal
    Link detected: yes
  • Test from Frankfurt to Phoenix:
    # iperf3 --client 45.86.ccc.ddd --omit 1 --parallel 2 --time 10 --reverse
    [SUM] 0.00-10.14 sec 416 MBytes 344 Mbits/sec 0 sender
    [SUM] 0.00-10.00 sec 411 MBytes 345 Mbits/sec receiver
    It's good enough then
  • edited September 2021
    iperf (multithreaded) says otherwise...
    [SUM]   0.00-10.00  sec  10.8 GBytes  9.31 Gbits/sec  39755             sender
    [SUM]   0.00-10.00  sec  10.8 GBytes  9.28 Gbits/sec                  receiver
    iperf Done.
    ed: frankfurt to hamburg (wilhelm.tel)
    Thanked by (1)vimalware
  • Yep, so good
    fair enough, single thread across the pond, you are right, never gonna burst that 10Gbit (with no provider). ;-) ;-)
    Yeah, so bandwidth is a relative definition :) No provider gives a VPS with even 1Gbps transatlantic :)
    Here is the transpacific bandwidth, testing from HostHatch Singapore:
    # iperf3 --client 45.86.209.ddd --omit 1 --parallel 2 --time 10 --reverse
    [SUM] 0.00-10.19 sec 239 MBytes 197 Mbits/sec 1341 sender
    [SUM] 0.00-10.00 sec 233 MBytes 196 Mbits/sec receiver
    iperf Done.
    yeah that's simply not how networking and even physics work with that distance...
