Direct Admin Technical Thread
15678911»
    I am about to switch back to Debian but I need to confirm compatibility for Jailshell/Bubblewrap.
    Feature doc says "For CentOS 7 and up" but I've had no errors compiling on Debian. Hoping I'm good to go?
    Yes, no problems with Debian/Ubuntu :smile:
    Thanked by (1)MichaelCee
  • visualwebtechnovisualwebtechno Hosting ProviderOG
    @LeonDynamic said:
    Just wondering if anyone here is running DirectAdmin prerelease binary. There has been a new theme added called Facelift. It looks similar to the existing Sidebar theme but appears to be a replacement for the Standard theme as when viewed on a mobile it changes back to the Standard theme.
    nice theme
    Awesome :)
    P.S Resource throttling working as intended now I've switched to a compatible machine. Thank you.
  • Hello!
    When I enter the server IP in the browser I'm redirected to the only domain I have there.
    I'd like to show a simple HTML page instead, is it possible?
  • Well... checking again that server is not running DA. It's just OLS. Sorry.
    LOL
  • Curious about the Pro Pack DA is offering now. Is this being provided with free licences you see being offered with some providers like BuyVM and IH?
  • Is it possible to get owned lifetime license now?
    No.
    No, at the moment it is being provided only with retail standard & lite licenses for no extra charge. I hope DA change their mind later & it becomes available to be purchased from NOCs for extra charges.
    Maybe @smtalk can let us all know if they have any such plans in future.
    Thanked by (1)Lee
  • @vpsgeek3333 said: No, at the moment it is being provided only with retail standard & lite licenses for no extra charge.
    Thanks, make sense. I did think a comment I saw was incorrect which suggested they did. Which really made no sense.
  • Quick question:
    In DirectAdmin, when a user is migrated from cPanel, I see these directories in
    domains/mygreatdomain.tld:
    awstats logs private_html public_ftp public_html stats
    Are all of these directories actually used by DA?
    Initially I thought maybe onlye the {private,public}_html dirs were in use, but it seems files in stats are updated (used for the *Extra Features/Resource Usage* part, I guess).
    Checking further it seems also logs and awstats dirs has files with current datestamps ...
    So, they're all in use? B)
  • @flips said:
    Quick question:
    Yes - it seems all are in use.
    Even for a newly created DirectAdmin account, or a manually migrated cPanel account (so only files from public_html and a database export were "copied").
    Thanked by (1)flips
