IPv6-to-IPv4 Translation Providers or Other Methods
Basically I couldn't use the Cloudflare method which is for a NAT VPS which has dedicated IPv6 only. Is there any other providers/solutions for this?
  • Your NAT provider did not give you public IPv6?
  • I've never seen anything like it. Wait for a solid solution
    Thanked by (1)ysdx
    It does have a private IPv6.
    Thanked by (2)amiir ceddr
    You mean link local.
    Did you tiket for IPv6?
    Its not link local. And the problem with Cloudflare is related to domain when trying to add a website, nothing else.
  • Check with your provider:
    • if they have HAProxy, then you could point A record on cloudflare DNS to shared public IPv4 and enable clpudflare proxy
    • if they did not have HAProxy, then you could point AAAA record to public IPv6 address of your VPS and enable cloudflare proxy
    Or
    Do you mean you have only 1 IPv6 address without IPv4 (NAT) address?
    Or
    Cloudflare proxy is fine if it accepts your domain name and you can 'add a website'. But I thought maybe there is another way or proxy provider.
  • Without any clarity from you, the best option would be buy a cheapskate VPS with IPv4 or buy a shared hosting.
