https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Surprising disk speed for Crucial SATA
Sun Oct 24 10:27:08 IST 2021
Processor : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz
CPU cores : 2 @ 1060.494 MHz
AES-NI : ❌ Disabled
RAM : 1.9 GiB
Swap : 980.0 MiB
Disk : 108.6 GiB
Read | 6.95 MB/s (1.7k) | 39.28 MB/s (613)
Write | 6.97 MB/s (1.7k) | 39.55 MB/s (618)
Total | 13.93 MB/s (3.4k) | 78.83 MB/s (1.2k)
Read | 38.09 MB/s (74) | 38.70 MB/s (37)
Write | 40.13 MB/s (78) | 41.47 MB/s (40)
Total | 78.22 MB/s (152) | 80.17 MB/s (77)
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 1058
Multi Core | 1437
Full Test | https://browser.geekbench.com/v4/cpu/16390964
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 220
Multi Core | 318
Full Test | https://browser.geekbench.com/v5/cpu/10579002
Edit: The disk speed is intriguing! Could be because of age/ damage /corruption to the SATA connector?
On Disk speed
$ :/tmp$ dd if=/dev/zero of=tempfile bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 18.2439 s, 58.9 MB/s
@vyas maybe check what generation the sata connector is at all. and what kind of disk is that (full smartctl output...) as you said crucial I'd assume an SSD, for which the 4k numbers look feasible. that you don't get a higher througput on 1MB bs is more likely a limitation based on the sata chip and ssd controller. back in the day the main improvment with SSDs was exactly only higher IOps with small blocksizes over bandwidth - simply because SATA couldn't deliver much higher speeds after all.
most likely won't hurt to put in a newer ssd though ;-)
@cybertech said:
seems not too far off from a 2660v2 i have with them, also set to expire
Yes, similar performance.
use external kms servers
for example msguides.com is what i have used for years, just search windows 10 and put some stuff in cmd
is he somehow bruce lee related/reborned? the only other person i see with that many pushup videos is him.
Why not just spend a few bucks for a retail key? It's much more safer.
HostCram LLC - Web Hosting Built For Speed, Reliability, Security & Uptime! [We operate AS39618]
i have used this on my home pc for years now with no problems. i dont think there are any real security risks with using an external kms server,
@LetMeBeSad
Sir you make others sad by posting bms with those specs
VPS reviews and benchmarks |
Cheap home lab
The SSD is giving me some issues, so I'll be getting a replacement soon
Network speeds are while connected to a VPN server 4000 Km / 2400 miles away.
Well, i can post 128 core server with 80 TB NVMe SSD in a raid and 25+25 Gbit/s pipe, so nobody could beat that thing
StarDust1-S Scaleway France1 - Only IPv6 - 0.37 Euro/month
Dell D520 , 2006
Surprising disk speed for Crucial SATA Sun Oct 24 10:27:08 IST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz CPU cores : 2 @ 1060.494 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 980.0 MiB Disk : 108.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.95 MB/s (1.7k) | 39.28 MB/s (613) Write | 6.97 MB/s (1.7k) | 39.55 MB/s (618) Total | 13.93 MB/s (3.4k) | 78.83 MB/s (1.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 38.09 MB/s (74) | 38.70 MB/s (37) Write | 40.13 MB/s (78) | 41.47 MB/s (40) Total | 78.22 MB/s (152) | 80.17 MB/s (77) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 1058 Multi Core | 1437 Full Test | https://browser.geekbench.com/v4/cpu/16390964 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 220 Multi Core | 318 Full Test | https://browser.geekbench.com/v5/cpu/10579002Edit: The disk speed is intriguing! Could be because of age/ damage /corruption to the SATA connector?
On Disk speed
1024+0 records in
1024+0 records out
Smartctl shows
$ sudo smartctl -H /dev/sda
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-5.4.0-89-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
I would have said disk speed looked correct compared with when I've ran yabs on similar era hardware.
Edit - this is newer hardware(ish) - AMD FX4100. SATA3 disks on SATA2 controller in SW RAID1:
that's helpful Many thanks. Was going to check with a different sata disk later today.
Once I've cooked I've got a PC with SATA and IDE drives I can do a comparison with too if it helps.
Ignore me then if it's an SSD - I misread that bit
Update: YABS with a SATA - Kingston M2 NGGF (with M2 to Sata converter).
somewhat better speeds.
--------------------------------- Processor : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz CPU cores : 2 @ 1106.843 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 2.0 GiB Disk : 439.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 7.93 MB/s (1.9k) | 36.03 MB/s (563) Write | 7.96 MB/s (1.9k) | 36.39 MB/s (568) Total | 15.90 MB/s (3.9k) | 72.43 MB/s (1.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 48.46 MB/s (94) | 49.71 MB/s (48) Write | 50.86 MB/s (99) | 52.17 MB/s (50) Total | 99.33 MB/s (193) | 101.88 MB/s (98)@falzo said:
Yes, a Crucial BX500 2.5" SSD, 120 GB
Thanks for the help so far folks- reviving this machine has been a great experience so far.
I might go back to the Crucial disk on this machine - not sure if this machine can support a 480 GB Disk.
Dunno if it helps but comparison with SSD (same PC as other test - no RAID/etc just SSD (Kingston I think) on SATA2 controller:
@Mr_Tom,
appreciate the data- suppose the machines from the era have a limitation - but they do have some life left in them!
This is my daily desktop in my home office lol.
My new NAS build at home:
@daffy
Nice gb5 score for an i3. And results overall.
More than enough for serving some files over LAN and powering my Plex server.
The last result of VirMach 2018 BF deal $10/yr in Amsterdam before its retirement at the end of November.
Racknerd Amsterdam $14.38 yearly
Yet-Another-Bench-Script
v2021-10-09
Mon 25 Oct 2021 02:00:05 PM BST
Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU cores : 1 @ 2799.998 MHz
AES-NI : ✔ Enabled
RAM : 981.2 MiB
Swap : 1024.0 MiB
Disk : 13.8 GiB
Clouvider | London, UK (10G) | 844 Mbits/sec | 847 Mbits/sec
Online.net | Paris, FR (10G) | 845 Mbits/sec | 837 Mbits/sec
WorldStream | The Netherlands (10G) | busy | 850 Mbits/sec
WebHorizon | Singapore (1G) | 260 Mbits/sec | 515 Mbits/sec
Clouvider | NYC, NY, US (10G) | 189 Mbits/sec | 318 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 508 Mbits/sec | 845 Kbits/sec
Clouvider | Los Angeles, CA, US (10G) | 559 Mbits/sec | 367 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | 258 Mbits/sec | 202 Mbits/sec
Test | Value
Single Core | 444
Multi Core | 438
Full Test | https://browser.geekbench.com/v5/cpu/10603658
Naranjatech Dronten $9 yearly
v2021-10-09
Mon 25 Oct 2021 09:01:16 AM EDT
Processor : AMD EPYC 7302 16-Core Processor
CPU cores : 1 @ 2999.998 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 987.2 MiB
Swap : 0.0 KiB
Disk : 19.7 GiB
Clouvider | London, UK (10G) | 907 Mbits/sec | 887 Mbits/sec
Online.net | Paris, FR (10G) | 903 Mbits/sec | 888 Mbits/sec
WorldStream | The Netherlands (10G) | 896 Mbits/sec | 935 Mbits/sec
WebHorizon | Singapore (1G) | 375 Mbits/sec | 517 Mbits/sec
Clouvider | NYC, NY, US (10G) | 853 Mbits/sec | 266 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 788 Mbits/sec | 290 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 726 Mbits/sec | 235 Mbits/sec
Iveloz Telecom | Sao Paulo, BR (2G) | 704 Mbits/sec | 207 Mbits/sec
Clouvider | London, UK (10G) | 900 Mbits/sec | 899 Mbits/sec
Online.net | Paris, FR (10G) | 902 Mbits/sec | 856 Mbits/sec
WorldStream | The Netherlands (10G) | 881 Mbits/sec | 921 Mbits/sec
WebHorizon | Singapore (1G) | 292 Mbits/sec | 341 Mbits/sec
Clouvider | NYC, NY, US (10G) | 851 Mbits/sec | 249 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 771 Mbits/sec | 179 Mbits/sec
Test | Value
Single Core | 958
Multi Core | 967
Full Test | https://browser.geekbench.com/v5/cpu/10603678
Picked up a HP Workstation for cheap. Added a bit of RAM, OS on SSD and /home on NVMe (via PCI-e adapter).
just for fun, Ubuntu 20.04 under WSL2/Windows 10 on my daily driver:
dedipath $3.25 LEB kvm in phoenix
their phoenix nodes are ryzen for the same price, while othe locations is E5 v1/v2
My idler from hostus.us
Amadex • Hosting Forums • Webshop: Guide to Start Selling Online • Free Debit Card & Online Bank Account 🤑
