USA Ryzen 5900X/5950X VPS - RAID5 SATA SSD - $1/GB RAM - UPDATE 11/18/21 UK ADDED
2»
  • AdvinAdvin Hosting Provider
    @adanforest said:
    Something went wrong: User has blocked requests through HTTP.
    so that problem from vps?
    It's most likely a problem with the software you are using, we don't specifically block anything other than port 25.
  • Mr_TomMr_Tom OG
    edited November 2021
    @Advin said: Coventry, UK
    I've considered Coventry as a location in the UK in the past.
    Edit: As a provider this wasn't meant to look like I was jumping in on someone elses thread, just thought Coventry was an interesting choice outside of London.
    Thanked by (1)vr10
    Decided to stick with Coventry for now since I found a provider that was flexible there :)
    Also, it's all good!
    @Advin said:
    We've now confirmed UK as a new location and it should be available within 1-3 weeks. However, we'll most likely be going with Coventry, UK instead of London, UK (which is a little bit farther, but not by much).
    Hybrid's will likely not launch there, but, we'll most likely keep the same pricing and specifications as our Dallas location.
    LETS GOOOO BI****S WOOT WOOT!!!
    UK is now out, there's an option to choose it at checkout :)
    Please note that there is limited stock.
    #                     v2021-10-09                    #
    Fri 19 Nov 2021 03:11:36 AM CET
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 1 @ 3692.866 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 13.7 GiB
    Read       | 4.41 MB/s     (1.1k) | 68.72 MB/s    (1.0k)
    Write      | 4.43 MB/s     (1.1k) | 69.01 MB/s    (1.0k)
    Total      | 8.85 MB/s     (2.2k) | 137.73 MB/s   (2.1k)
    Read       | 172.78 MB/s    (337) | 109.51 MB/s    (106)
    Write      | 181.96 MB/s    (355) | 116.80 MB/s    (114)
    Total      | 354.75 MB/s    (692) | 226.31 MB/s    (220)
    Clouvider       | London, UK (10G)          | 840 Mbits/sec   | 591 Mbits/sec
    Online.net      | Paris, FR (10G)           | 798 Mbits/sec   | 804 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 772 Mbits/sec   | busy
    WebHorizon      | Singapore (1G)            | 229 Mbits/sec   | 326 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 907 Mbits/sec   | 727 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 27.2 Mbits/sec  | 566 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 896 Mbits/sec   | 688 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 831 Mbits/sec   | 571 Mbits/sec
    Clouvider       | London, UK (10G)          | 831 Mbits/sec   | 559 Mbits/sec
    Online.net      | Paris, FR (10G)           | 832 Mbits/sec   | 716 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 773 Mbits/sec   | 567 Mbits/sec
    WebHorizon      | Singapore (1G)            | 137 Mbits/sec   | 474 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 861 Mbits/sec   | 818 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 886 Mbits/sec   | 759 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 398
    Multi Core      | 396
    Full Test       | https://browser.geekbench.com/v5/cpu/11078486
    @Dazzle said:
    # Yet-Another-Bench-Script #
    # v2021-10-09 #
    AES-NI : ✔ Enabled
    RAM : 1.9 GiB
    Swap : 0.0 KiB
    Disk : 13.7 GiB
    Test | Value
    Single Core | 398
    Multi Core | 396
    Could you open a ticket? Those GB5 scores are really low... they should be in the 600 mark since it's 1/2 vCore.
  • Wtf is that diskspeed
