@Sensei said:
It's been taken care of by your customer support. Literally within 10 mins of opening a ticket! Super happy with your service and the server.
virtuozzo as underlying hypervisor... disk is a ploop device, network is routed venet0 - haven't seen that in a while
1blu.de is a long existing german provider, contracts! SEPA only? verification call to a german call center...
most likely not really interesting to non-german customers. still I wanted to try them for a long time. right now this above is on offer for 12⬠first year and even the regular pricing of 4,99⬠per month (incl. german VAT) is quite attractive for the given specs.
with that one I noticed that the multicore GB5 tends to be a bit more jumpy, depending on the host nodes load I guess. Here is a second one a few minutes later:
yeah, that's the thing, its' sold as KVM - however ploop and venet are kinda relicts back when virtuozzo was based on OVZ. not sure how this actually acts today.
I'll dig a bit deeper into it later, just haven't found the time yet to check more closely if f.i. windows install is possible. at least on their page it mentions KVM, 'own OS choice' and such...
seems they have some old german habits though, had to call in to verify on the order, also heard they require a pdf form to be filled for cancelation, PTR only through support request and such.
will find out sooner or later anyway and report back ;-)
i guess the most obvious sign would be checking kernel and possibility of upgrading it..virtuozzo claims to have 200+ upgrades over standard KVM
yeah indeed /boot is empty, dpkg doesn't list any kernel related packages, uname -a gives:
Linux 4.15.0 #1 SMP Fri Nov 20 21:47:55 MSK 2020 x86_64 x86_64 x86_64 GNU/Linux
as said, I'll have to check later, what options there are in the panel and what happens when I want/request to install from my own ISO etc. ;-)
so, the control panel allows for a choice of 'Virtuozzo instance' vs 'empty KVM instance' - which indeed I'd interpret as Virtuozzo rather being just OVZ...
for the empty KVM instance you have to pick, what you want to install, but provide your own ISO anyways. maybe that's just for the optics ... or maybe they place you on a certain node, depending on what you pick, no clue.
the rest of the install is a bit more complicated, as one needs to upload an ISO of your choice via FTP but name it specifically so it gets picked up during reboot. the rest is handled via VNC but lacks a noVNC console. also there is a DHCP server running but gives you only an internal IP which does not have public internet, so also a bit of manual steps involved.
once I am finished, I'll obviously run another yabs to see what this will then provide. expect it to be quite different, because most likely a completely different node and probably different settings/limits and/or hardware... let's see.
sorry for double post and all the text above within this topic anyway.
probably better for readability though - new bench, this time definitely KVM installed from ISO:
didn't expect that. very snappy and for now numbers seem even better than what the virtuozzo/ovz instance offered. if it stays that way that's a keeper even for 5⬠a month... location is Frankfurt, afaik they are running their own DC there.
ā A simple uptime dashboard using UptimeRobot API https://upy.duo.ovh
ā Currently using VPS from BuyVM, GreenCloudVPS, Gullo's, Hetzner, HostHatch, InceptionHosting, LetBox, MaxKVM, MrVM, VirMach.
Thanks! These are obviously low end but Iām doing everything I can to make the price reflect that š
Got a bunch of 1TB disks arriving tomorrow to throw in for a special which will be live on Friday all going well.
webhosting24
22eur/yr
swwwweeet IOPS
Terrahost ā¬60/yr deal. Not sure what's up with IO though. Anyone know?
Team push-ups!
Servarica Polar Bear @ Ubuntu 20.04 (fresh deployment right after sudo apt-get update / upgrade)
A Wild Australian, eh Austria VPS has appeared, Tiny little BEAST
Little ASH of BURN 10$/y
central.so
$22.40/yr
Sydney (OVH)
virtualizor panel
no custom ISO
PM me your IP or customer ID and we'll take a look
Team push-ups!
Thanks, great to hear
new YABS pls
Pretty much the same but IOs now touch 3-4 gigs/s
Team push-ups!
Team push-ups!
Central.so Budget KVM-Silver
2 Cores
2 GB
50GB Pure SSD
2TB @ 1Gbit/s (Monthly)
1 IPv4 Address
1 IPv6 Address
Full Root Access
Price: $22.40/yr w/ coupon "HAPPYHOLIDAYSā
5$/y Virmach Atlanta
ExtraVM, Intel VDS Special 60GB NVMe $10/m with IP management/firewall
lansol.de BF deal VPS-P2 reincheck:
(12⬠first year / full price is 8,98 incl german VAT per month)
new to the (my) game, 1blu.de VPS R8
will monitor and see how it goes ;-)
PHP-Friends X-Mas special reincheck:
stays between 2-2.5k though, which is totally fine I'd say ;-)
is that KVM? still good IOPS and GB
edit: Ubuntu 18.04 LTs came as default
Looks like something @ympker would relish doing !
VPS reviews and benchmarks |
LOL! but it's miiiiinnnnneeee
Terrahost (former Hostsolutions Norway migrated to TH hardware) @ Debian 11
Geekbench 5: https://browser.geekbench.com/v5/cpu/12034207 -> TL;DR single:412, multi:393
Terrahost - ā¬1/yr.
Superb deal..
