Who do you use for cold backup?
I am finally going to design my 3-2-1 backup plan, which is a step up from my current plan:
replace hard drives before they fail
So, wonder how is everyone's plan look like, what services do you use?
The obvious provider would be AWS... but any other contenders?
How much storage do you require? Also how cold is the storage? Maybe S3 Glacier could work for you or depending on the amount of storage I’m sure a provider would be able to do custom large storage deals.
I typically use Wasabi. But S3 glacier would be great considering the new 100GB free egress + 1TB free Cloudfront
Wasabi is pretty decent
b2 (with or without Cloudflare depending on use)
VPS reviews and benchmarks |
Don't wasabi only have one price (i.e. hot storage)? Same for B2. AWS glacier deep storage is $1/TB/mo, but of course retrieval costs can kill you. Scaleway C14 is 2 Euro/TB/mo, but lower retrieval cost.
Cost comparison from backblaze. We are considering it for our use- once we start video podcasts. Not sure if these are reasonable prices
(10 TB total backup, with 1 TB/ month data xfer -
considering cold storage)
Excellent questions by @natvps_uk btw
Depending on storage requirements the 2 TB plan from sync.com (solo basic or the solo professional ) can also be an option.
I like sync. Rather under rated in the space
https://www.sync.com/pricing/
I probably have less than 1tb to back up unless I count those Linux ISOs I gathered the past decade and a half.
Using onedrive - O365 fam comes with 6TB. And since I need office anyway....
Be sure to encrypt those linux isos...cloud providers hashing copyright content is becoming more fashionable
Hi @terrorgen! I have a 5 TB Seagate lifetime!
It cost $95 last Christmas.
I know this probably isn't what you want, but I can't resist joking around! ¡Saludos! 🤩
MetalVPS
Then uploaded to the cloud via IPoAC?
@terrorgen I'm curious how much are you willing to pay for say 2TB lifetime encrypted storage?
Team push-ups!
Definitely! How appropriate to mention clouds in the context of IPoAC!
You win this round! ✨💖
MetalVPS
I just backup my personal files to my Gsuite Unlimited $12/month legacy plan
@vyas if you proxy Cloudflare in front of B2, you don’t have to pay for any egress costs due to the bandwidth alliance right? Doesn’t that make it a no-brained? And $5/TB/mo without egress costs makes it cheaper than Wasabi… or do I not understand it correctly?
For a cold backup, I use my own server at home. It's just a simple 1U storage server that I built.
The ultimate cold backup: GitHub Archive Program.
Upload your files in a public repository on GitHub.
Wait a few years.
It will be printed as microfilm and store in a cold vault.
Your files will last long past the humanity.
If you are using Wasabi, be aware that they have a minimum storage duration policy which affects pricing.
https://wasabi-support.zendesk.com/hc/en-us/articles/360058734492-How-does-Wasabi-s-minimum-storage-duration-policy-work-
Microsoft Putting azure to use for this?
That was the reason behind posting the link and screenshot.
There are quite a few folks who loathe CF.
So they get both pricing options to play with
can you use the s3 API with the proxied domain? last time I tested, there were errors when connecting via cloudflare-proxied domain, which makes it useless if your using most backup softwares. plus, wasabi has more locations available, which is a big plus too.
