Avast/AVG VPN $3/year
bruh21bruh21 Hosting Provider
edited January 2022 in General
As long as you’re comfortable using a little google translate, you can get AVG vpn for $3/ first year and $4 recurring.
Just buy from this link: https://www.avg.com/es-ar/secure-vpn
When it asks for CUIT just put any number until it is satisfied, and you’ll be good to go. If you want a discount on year 2 as well just follow the unsubscribe prompt until it offers you a discount
As for the VPN itself, I would say it’s about on par with keepsolid or fastestvpn. It does have the advantage of being backed by a larger company. It’s another good one for my arsenal of cheap VPNs
    Avast has the same offer but the renewal is like 15 dollars and the VPN is exactly the same
  • Cart submit fails 😪
    edited January 2022
  • Figured it out. Must select Argentina country. Does not proceed when selecting other countries.
    Hooray! 🎉 Bought 3 years for about $7 USD. Thanks!
    Thanked by (1)pspatial
    No problem, hope it works well for you. So far it is decent for my torrenting needs
    How did you get multiple years? Can I just buy it multiple times to extend?
  • Select 3 years at checkout. Comes to 719 ARS = ~$7.
    Thanked by (1)sanvit
  • edited January 2022
    Thanks for posting! I wonder if @Ympker has any experience with this VPN.
    Sorry, I never used that one.
    I can give you an avast activation code if you want, I’m not using it
    Thanks! It seems like the 3 year option is only available in PC
    @sanvit said: only available in PC
    There's other OS / Length options on their webstore
    This one (which is the same one on their homepage) seems to say that it can be used on all devices
    If the links show non ARS, visit one of the other links in the thread first
    Whoopse! I meant that the 3 yr option is only available in their desktop page :) The subscription itself seems to be valid on all compatible devices
  • Are they any good?
    @sonic said:
    Are they any good?
    Like I said in my post, the performance seems to be on par with other cheap VPNs. It’s not something I would pay regular price for, but for $3 I think the app is better than keepsolid and fastestvpn so this is the one I use
    Thanks! Which methods do they support? Wireguard available?
    No, I don’t think they have manual configs anyways. On iPhone they use ikev2 and on pc they use OpenVPN. I’m not sure what they use on android if you intend on that. If you want to use manual configs I would recommend fastestvpn lifetime deal
    fastestvpn does support openvpn manual config but it always says password is wrong when I connect lol
    btw Keepsolid serves me well
    edited January 2022
    I like keepsolid but their mobile app is slow to load for me. I would give AVG/Avast VPN to my parents because the app is so simple
    So you can only use their service if you use their app?
  • https://campaigns.avira.com/de/heise-adventskalender
    Free VPN from Avira for 6 months, it's not great, but it's free.
    Thanked by (1)bruh21
    @user123 said: So you can only use their service if you use their app?
    Their VPN app, yeah, seems to be required. On a PC, it claims to run openvpn under the hood, but I can't find any .ovpn files that I can import into other programs. My other vpn uses OpenVPN, and still working on the same system as AVG vpn so far.
    Thanked by (1)user123
