Post some YABS bench here
1474850525399
  • @Falzo said: Single Core | 570
    Were you running anything else at the same time? I know it's an older E5 but I would have expected a little higher.
    @Falzo said: dunno what kind of magic trickery
    Nothing fancy to be honest. HDDs are hardware RAID with a little bit of controller/NVMe caching. EVerything is provisioned on LVM.
    It just helps with making everything a bit more usable/speedier on the older CPUs.
  • edited January 2022
    @Mr_Tom said: Were you running anything else at the same time? I know it's an older E5 but I would have expected a little higher.
    to be fair, I can't remember / didn't care ;-) that score is totally fine for me as I knew it'd be an E5 and the thing is rarely needing cpu power. only running borg once in a while, but that's not gonna be time ciritical.
    I already put close to 2TB data in, I can run another yabs later while idle, to see if it's the same... but essentially don't care much because it's storage 🤷🏻‍♂️
    @Mr_Tom said: Nothing fancy to be honest. HDDs are hardware RAID with a little bit of controller/NVMe caching. EVerything is provisioned on LVM.
    feels pretty snappy, definitely very good performance for the money (and my use case ;-)) - absolutely recommended!
    edit:
    Geekbench 5 Benchmark Test:
    Single Core     | 563
    Multi Core      | 2168
    Full Test       | https://browser.geekbench.com/v5/cpu/12283382
    about the same. but as said nothing to worry, that's just what the cpu can deliver... and as can be seen the multicore score fully scales on that, so this is a sign that there is not much going on at the whole node either.
    Thanked by (1)Mr_Tom
  • @Falzo said: about the same. but as said nothing to worry, that's just what the cpu can deliver... and as can be seen the multicore score fully scales on that, so this is a sign that there is not much going on at the whole node either.
    No worries. I did a YABS around New Year and it was a little higher but that's probably about right to be honest :)
  • MasonMason AdministratorOG
    Still pretty crazy this thing is free, but thanks Oracle! Pretty good CPU performance for an ARM host.
    #                     v2021-12-28                    #
    Thu Jan 20 15:54:48 GMT 2022
    Processor  : Neoverse-N1
    CPU cores  : 4 @ ??? MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 22.6 GiB
    Swap       : 8.0 GiB
    Disk       : 46.5 GiB
    Read       | 23.07 MB/s    (5.7k) | 48.13 MB/s     (752)
    Write      | 23.06 MB/s    (5.7k) | 49.56 MB/s     (774)
    Total      | 46.14 MB/s   (11.5k) | 97.69 MB/s    (1.5k)
    Read       | 41.17 MB/s      (80) | 40.64 MB/s      (39)
    Write      | 44.70 MB/s      (87) | 45.34 MB/s      (44)
    Total      | 85.87 MB/s     (167) | 85.99 MB/s      (83)
    Clouvider       | London, UK (10G)          | 913 Mbits/sec   | 813 Mbits/sec
    Online.net      | Paris, FR (10G)           | 823 Mbits/sec   | 724 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 833 Mbits/sec   | 643 Mbits/sec
    WebHorizon      | Singapore (400M)          | 174 Mbits/sec   | 282 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.02 Gbits/sec  | 1.01 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 960 Mbits/sec   | 980 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 963 Mbits/sec   | 805 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 172 Mbits/sec   | 915 Mbits/sec
    Single Core     | 876
    Multi Core      | 3403
    Full Test       | https://browser.geekbench.com/v5/cpu/12288275
  • KS-LE but with 4tb drives.
    #                     v2021-12-28                    #
    Sat Jan 22 18:13:29 UTC 2022
    Processor  : Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz
    CPU cores  : 12 @ 1487.600 MHz
    RAM        : 31.3 GiB
    Swap       : 4.0 GiB
    Disk       : 3.6 TiB
    Read       | 1.65 MB/s      (413) | 19.32 MB/s     (302)
    Write      | 1.68 MB/s      (421) | 19.87 MB/s     (310)
    Total      | 3.33 MB/s      (834) | 39.19 MB/s     (612)
    Read       | 64.28 MB/s     (125) | 76.71 MB/s      (74)
    Write      | 67.28 MB/s     (131) | 81.82 MB/s      (79)
    Total      | 131.56 MB/s    (256) | 158.53 MB/s    (153)
    Clouvider       | London, UK (10G)          | 96.9 Mbits/sec  | 941 Mbits/sec
    Online.net      | Paris, FR (10G)           | 96.9 Mbits/sec  | 941 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 96.8 Mbits/sec  | 940 Mbits/sec
    WebHorizon      | Singapore (400M)          | 70.0 Mbits/sec  | 66.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 94.2 Mbits/sec  | 898 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 89.1 Mbits/sec  | 731 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 87.1 Mbits/sec  | 19.6 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 84.9 Mbits/sec  | 699 Mbits/sec
    Clouvider       | London, UK (10G)          | 95.6 Mbits/sec  | 928 Mbits/sec
    Online.net      | Paris, FR (10G)           | 95.5 Mbits/sec  | 928 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 95.4 Mbits/sec  | 927 Mbits/sec
    WebHorizon      | Singapore (400M)          | 54.4 Mbits/sec  | busy
    Clouvider       | NYC, NY, US (10G)         | 91.9 Mbits/sec  | 887 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 80.1 Mbits/sec  | 822 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 3851
    Multi Core      | 19050
    Full Test       | https://browser.geekbench.com/v4/cpu/16470757
    Single Core     | 849
    Multi Core      | 4785
    Full Test       | https://browser.geekbench.com/v5/cpu/12331405
    #                     v2021-12-28                    #
    RAM        : 31.3 GiB
    Swap       : 4.0 GiB
    Disk       : 3.6 TiB
    Single Core     | 3851
    Multi Core      | 19050
    Single Core     | 849
    Multi Core      | 4785
    Very nice and lucky find!
    Thanked by (1)cybertech
  • @Mr_Tom I've never seen a KS-LE with such high GB5 scores. What's the secret?
    Team push-ups!
  • Mr_TomMr_Tom OG
    edited January 2022
    @localhost said: Very nice and lucky find!
    Not my find... https://talk.lowendspirit.com/discussion/comment/79898/#Comment_79898
    Edit: they're advertised with 4tb drives, so it's not luck - from the KS panel: "KS-LE Server - Intel Xeon E5-1650v2 - 32GB DDR3 1333MHz - 2x 4To HDD"
    @Astro said: What's the secret?
    I would have thought that score was about right for a 3.5ghz processor? My other LE (2tb drives) GB5 is 881
    Thanked by (1)localhost
    You got an upgraded processor as well! 12 cores vs 8
    Team push-ups!
  • @Astro said: You got an upgraded processor as well! 12 cores vs 8
    See my updated post - this is as advertised. Order form showed KS-LE Server - Intel Xeon E5-1650v2 - 32GB DDR3 1333MHz - 2x 4To HDD
  • looks like a decent box indeed. the 100 Mbit is a bummer still...
    True. Its not all bad as thats only upload and if I need anything from it my home internet cant pull faster than 60mbit anyway lol
    yeah for me it's the other way round... home is 1gbps down, 50mbps up, if Vodafone plays nicely that is (and rarely happens in a stable way) - so I'd be rather limited both directions 🤦🏻‍♂️
  • @Falzo said: 1gbps down, 50mbps
    Nice. We get good old copper phone line 60mbps down/20mbps up lol.
    yeah the best I could get out of copper here is 15mpbs/2.5mbs 🤦🏻‍♂️
    the alternative is (tv) cable, which brings speed - however, as said, it's ... fragile. on a daily basis.
    in an ideal world 300/100 or the likes would be awesome. maybe LTE/5G or something delivers that (soon?). yet you usually get only limited transfer. like 100-200GB with that. obviously quite a fail too, especially if moving a lot of data during spring clean...
    imagine pushing 3TB through a flaky 50mbps upload... :lol:
    Read 23.07 MB/s (5.7k) 48.13 MB/s (752)
    Write 23.06 MB/s (5.7k) 49.56 MB/s (774)
    Total 46.14 MB/s (11.5k) 97.69 MB/s (1.5k)
    Read 41.17 MB/s (80) 40.64 MB/s (39)
    Write 44.70 MB/s (87) 45.34 MB/s (44)
    Total 85.87 MB/s (167) 85.99 MB/s (83)
    You can adjust the IO, it's even better now for free
    Thanked by (1)Mason
  • microLXC Chile
    root@lxc38a7450f:~# curl -sL yabs.sh | bash
    #                     v2021-12-28                    #
    Sun Jan 23 18:59:01 UTC 2022
    Processor  : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
    CPU cores  : 1 @ 2099.998 MHz
    RAM        : 244.1 MiB
    Swap       : 0.0 KiB
    Disk       : 7.3 GiB
    Read       | 41.57 MB/s   (10.3k) | 97.21 MB/s    (1.5k)
    Write      | 41.66 MB/s   (10.4k) | 97.72 MB/s    (1.5k)
    Total      | 83.24 MB/s   (20.8k) | 194.93 MB/s   (3.0k)
    Read       | 92.90 MB/s     (181) | 91.84 MB/s      (89)
    Write      | 97.84 MB/s     (191) | 97.96 MB/s      (95)
    Total      | 190.74 MB/s    (372) | 189.81 MB/s    (184)
    Clouvider       | London, UK (10G)          | 45.7 Mbits/sec  | 46.2 Mbits/sec
    Online.net      | Paris, FR (10G)           | 45.5 Mbits/sec  | 44.5 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 43.2 Mbits/sec  | busy
    WebHorizon      | Singapore (400M)          | busy            | busy
    Clouvider       | NYC, NY, US (10G)         | 47.9 Mbits/sec  | 47.5 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 47.7 Mbits/sec  | 47.0 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 35.5 Mbits/sec  | 36.5 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 50.2 Mbits/sec  | 48.0 Mbits/sec
    Clouvider       | London, UK (10G)          | 45.6 Mbits/sec  | 43.2 Mbits/sec
    Online.net      | Paris, FR (10G)           | 43.2 Mbits/sec  | 40.6 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 38.4 Mbits/sec  | 44.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 47.5 Mbits/sec  | 46.3 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 42.5 Mbits/sec  | 44.7 Mbits/sec
  • @Neoon said: RAM : 244.1 MiB
    I was about to ask how you're running microlxc on nodes that small... when I realised that was the container itself lol
    Thanked by (1)Astro
    Indeed, https://talk.lowendspirit.com/discussion/comment/79732/#Comment_79732
    You could nest more LXC container in that, but I would not recommend it.
    Revisit to Hosthatch LAX Storage 1TB, after enabling IPv6
    Lovely box, seems like they improved IOWait.
    root@cybertech:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-28                    #
    Mon 24 Jan 2022 09:17:32 AM +08
    Processor  : AMD EPYC 7551P 32-Core Processor
    CPU cores  : 1 @ 2000.000 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 999.5 GiB
    Read       | 9.01 MB/s     (2.2k) | 82.35 MB/s    (1.2k)
    Write      | 9.05 MB/s     (2.2k) | 82.78 MB/s    (1.2k)
    Total      | 18.06 MB/s    (4.5k) | 165.14 MB/s   (2.5k)
    Read       | 191.49 MB/s    (374) | 288.24 MB/s    (281)
    Write      | 201.67 MB/s    (393) | 307.44 MB/s    (300)
    Total      | 393.16 MB/s    (767) | 595.69 MB/s    (581)
    Clouvider       | London, UK (10G)          | 1.33 Gbits/sec  | 1.31 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.41 Gbits/sec  | 907 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 1.12 Gbits/sec  | 1.09 Gbits/sec
    WebHorizon      | Singapore (400M)          | busy            | 315 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.94 Gbits/sec  | 2.70 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 2.59 Gbits/sec  | 1.33 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.97 Gbits/sec  | 4.18 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 784 Mbits/sec   | 636 Mbits/sec
    Clouvider       | London, UK (10G)          | 1.33 Gbits/sec  | 1.26 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.46 Gbits/sec  | 1.22 Gbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | busy
    WebHorizon      | Singapore (400M)          | busy            | 293 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.86 Gbits/sec  | 2.07 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 2.00 Gbits/sec  | 4.33 Gbits/sec
    Single Core     | 3051
    Multi Core      | 2909
    Full Test       | https://browser.geekbench.com/v4/cpu/16471822
    Single Core     | 653
    Multi Core      | 621
    Full Test       | https://browser.geekbench.com/v5/cpu/12356245
    Thanked by (1)chocolateshirt
  • Ulefone Power Armor 14 Android 11 via Termux app: (almost) nothing works!
    $ curl -sL yabs.sh | bash -s -- -r
    #                     v2021-12-28                    #
    Sun Jan 23 22:20:20 EST 2022
    bash: line 26: locale: command not found
    Warning: locale 'C' not detected. Test outputs may not be parsed correctly.
    bash: line 43: getconf: command not found
    Processor  : Cortex-A53
    CPU cores  : 8 @ 2301.0000 MHz
    RAM        : 3.7 GiB
    Swap       : 2.0 GiB
    Disk       :
    Generating fio test file...main: line 307: 28669 Bad system call         $FIO_CMD --name=setup --ioengine=libaio --rw=read --bs=64k --iodepth=64 --numjobs=2 --size=$FIO_SIZE --runtime=1 --gtod_reduce=1 --filename=$DISK_PATH/test.fio --direct=1 --minimal &> /dev/null
    Running fio random mixed R+W disk test with 4k blo
    Running fio random mixed R+W disk test with 64k bl
    Running fio random mixed R+W disk test with 512k b
    Running fio random mixed R+W disk test with 1m blo
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    Total      | 0.00 KB/s        (0) | 0.00 KB/s        (0)
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    Performing IPv4 iperf3 send test to Clouvider (Att
    Performing IPv4 iperf3 recv test from Clouvider (A
    Clouvider       | London, UK (10G)          | busy            | busy
    Performing IPv4 iperf3 send test to Online.net (At
    Performing IPv4 iperf3 recv test from Online.net (
    Online.net      | Paris, FR (10G)           | busy            | busy
    Clouvider       | NYC, NY, US (10G)         | busy            | busy
    Performing IPv6 iperf3 send test to Clouvider (Att
    Performing IPv6 iperf3 recv test from Clouvider (A
    Performing IPv6 iperf3 send test to Online.net (At
    Performing IPv6 iperf3 recv test from Online.net (
    #                     v2021-12-28                    #
    RAM        : 3.7 GiB
    Swap       : 2.0 GiB
    Disk       :
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    why buy an unknown support china brand phone? xiaomi / oppo / vivo / honor are way better
  • vyasvyas OGRetired
    edited January 2022
    #                     v2021-12-28                    #
    RAM        : 3.7 GiB
    Swap       : 2.0 GiB
    Disk       :
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    Read       |                   () |                   ()
    Write      |                   () |                   ()
    Sox or seven years ago one could say the same thing about most the brands you mentioned. Many of them are top three brands in most markets they serve. Many of them are owned by same company btw.
    https://en.m.wikipedia.org/wiki/BBK_Electronics
    @yoursunny said: Ulefone Power Armor 14 Android 11 via Termux app: (almost) nothing works!
    Thanked by (2)chimichurri Ganonk
    edited January 2022
    revisit to alphavps giveaway
    512GB storage
    Sofia, BG
    migrated to another node due to download speed
    (all fixed now)
    root@storage-server-1:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-28                    #
    Mon 24 Jan 2022 06:25:55 AM EST
    Processor  : Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz
    CPU cores  : 1 @ 2394.228 MHz
    RAM        : 976.4 MiB
    Swap       : 1024.0 MiB
    Disk       : 510.9 GiB
    Read       | 10.69 MB/s    (2.6k) | 16.79 MB/s     (262)
    Write      | 10.70 MB/s    (2.6k) | 17.37 MB/s     (271)
    Total      | 21.40 MB/s    (5.3k) | 34.16 MB/s     (533)
    Read       | 81.50 MB/s     (159) | 124.88 MB/s    (121)
    Write      | 85.84 MB/s     (167) | 133.20 MB/s    (130)
    Total      | 167.34 MB/s    (326) | 258.09 MB/s    (251)
    Clouvider       | London, UK (10G)          | 739 Mbits/sec   | 639 Mbits/sec
    Online.net      | Paris, FR (10G)           | 918 Mbits/sec   | 701 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 917 Mbits/sec   | 572 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 880 Mbits/sec   | 243 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 819 Mbits/sec   | 240 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 815 Mbits/sec   | 375 Mbits/sec
    Performing IPv4 iperf3 recv test from Iveloz Telecom (Attempt #1 of 5)...
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 3.06 Mbits/sec  | 124 Mbits/sec
    Clouvider       | London, UK (10G)          | 177 Mbits/sec   | 369 Mbits/sec
    Online.net      | Paris, FR (10G)           | 308 Mbits/sec   | 552 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 355 Mbits/sec   | 416 Mbits/sec
    WebHorizon      | Singapore (400M)          | 173 Mbits/sec   | 65.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 287 Mbits/sec   | 364 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 413 Mbits/sec   | 333 Mbits/sec
    Single Core     | 2285
    Multi Core      | 2157
    Full Test       | https://browser.geekbench.com/v4/cpu/16472182
    Single Core     | 466
    Multi Core      | 460
    Full Test       | https://browser.geekbench.com/v5/cpu/12363845
  • havochavoc OG
    edited January 2022
    Before/After on nexus migration. About same overall with io and net down a bit
    @havoc said:
    Nexus says my VPS is getting migrated (DE>>NL) so dropping a before here & after to follow a bit later.
    Big gotcha though - not representative of migration overall. It's a grandfathered once off clearance special with nine lives and a lot of luck that @seriesn very honourably rolled 1:1 specs wise last migration when really the platforms were not 1:1 comparable at all. So regardless of before/after results I won't be complaining
    Tue 28 Dec 2021 12:24:43 PM EST
    Processor  : AMD Ryzen 7 3700X 8-Core Processor
    CPU cores  : 4 @ 3593.248 MHz
    RAM        : 15.6 GiB
    Swap       : 0.0 KiB
    Disk       : 39.4 GiB
    Read       | 358.87 MB/s  (89.7k) | 3.31 GB/s    (51.7k)
    Write      | 359.82 MB/s  (89.9k) | 3.33 GB/s    (52.0k)
    Total      | 718.69 MB/s (179.6k) | 6.64 GB/s   (103.8k)
    Read       | 3.69 GB/s     (7.2k) | 3.83 GB/s     (3.7k)
    Write      | 3.89 GB/s     (7.5k) | 4.09 GB/s     (3.9k)
    Total      | 7.58 GB/s    (14.8k) | 7.92 GB/s     (7.7k)
    Clouvider       | London, UK (10G)          | 939 Mbits/sec   | 933 Mbits/sec
    Online.net      | Paris, FR (10G)           | 953 Mbits/sec   | 937 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 894 Mbits/sec   | 534 Mbits/sec
    Single Core     | 1252
    Multi Core      | 4008
    Full Test       | https://browser.geekbench.com/v5/cpu/11864054
    After
    #                     v2021-12-28                    #
    Mon 24 Jan 2022 03:18:26 PM EST
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 4 @ 3792.872 MHz
    RAM        : 15.6 GiB
    Swap       : 0.0 KiB
    Disk       : 39.4 GiB
    Read       | 314.04 MB/s  (78.5k) | 1.93 GB/s    (30.2k)
    Write      | 314.87 MB/s  (78.7k) | 1.94 GB/s    (30.4k)
    Total      | 628.92 MB/s (157.2k) | 3.88 GB/s    (60.7k)
    Read       | 2.37 GB/s     (4.6k) | 2.44 GB/s     (2.3k)
    Write      | 2.49 GB/s     (4.8k) | 2.61 GB/s     (2.5k)
    Total      | 4.87 GB/s     (9.5k) | 5.05 GB/s     (4.9k)
    Clouvider       | London, UK (10G)          | 800 Mbits/sec   | 895 Mbits/sec
    Online.net      | Paris, FR (10G)           | 620 Mbits/sec   | 665 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 416 Mbits/sec   | 370 Mbits/sec
    Single Core     | 1193
    Multi Core      | 4048
    Full Test       | https://browser.geekbench.com/v5/cpu/12371948
    racknerd last bench
    san jose
    root@racknerd-87a951:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-28                    #
    Tue 25 Jan 2022 01:21:39 AM EST
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 2 @ 2800.000 MHz
    RAM        : 1.9 GiB
    Swap       : 1.5 GiB
    Disk       : 18.2 GiB
    Read       | 65.86 MB/s   (16.4k) | 449.72 MB/s   (7.0k)
    Write      | 66.00 MB/s   (16.5k) | 452.08 MB/s   (7.0k)
    Total      | 131.86 MB/s  (32.9k) | 901.80 MB/s  (14.0k)
    Read       | 553.02 MB/s   (1.0k) | 591.19 MB/s    (577)
    Write      | 582.41 MB/s   (1.1k) | 630.56 MB/s    (615)
    Total      | 1.13 GB/s     (2.2k) | 1.22 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 844 Mbits/sec   | 141 Mbits/sec
    Online.net      | Paris, FR (10G)           | 842 Mbits/sec   | 78.2 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 818 Mbits/sec   | 150 Mbits/sec
    WebHorizon      | Singapore (400M)          | 215 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 907 Mbits/sec   | 251 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 890 Mbits/sec   | 533 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 932 Mbits/sec   | 902 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 804 Mbits/sec   | 157 Mbits/sec
    Single Core     | 2415
    Multi Core      | 4404
    Full Test       | https://browser.geekbench.com/v4/cpu/16472866
    Single Core     | 524
    Multi Core      | 959
    Full Test       | https://browser.geekbench.com/v5/cpu/12378345
    advinservers
    Luxembourg
    root@cybertech ~]# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-28                    #
    Tue Jan 25 02:05:41 EST 2022
    CPU cores  : 1 @ 3393.618 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 26.5 GiB
    Read       | 17.23 MB/s    (4.3k) | 246.36 MB/s   (3.8k)
    Write      | 17.24 MB/s    (4.3k) | 247.66 MB/s   (3.8k)
    Total      | 34.47 MB/s    (8.6k) | 494.02 MB/s   (7.7k)
    Read       | 443.71 MB/s    (866) | 509.68 MB/s    (497)
    Write      | 467.29 MB/s    (912) | 543.63 MB/s    (530)
    Total      | 911.01 MB/s   (1.7k) | 1.05 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 872 Mbits/sec   | 340 Mbits/sec
    Online.net      | Paris, FR (10G)           | 786 Mbits/sec   | 328 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 882 Mbits/sec   | 342 Mbits/sec
    WebHorizon      | Singapore (400M)          | 226 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 712 Mbits/sec   | 139 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 704 Mbits/sec   | 85.4 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 452 Mbits/sec   | 114 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 600 Mbits/sec   | 218 Mbits/sec
    Clouvider       | London, UK (10G)          | 873 Mbits/sec   | 66.0 Mbits/sec
    Online.net      | Paris, FR (10G)           | 872 Mbits/sec   | 293 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 495 Mbits/sec   | 287 Mbits/sec
    WebHorizon      | Singapore (400M)          | 256 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 768 Mbits/sec   | 72.6 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 635 Mbits/sec   | 22.1 Mbits/sec
    Single Core     | 2850
    Multi Core      | 2532
    Full Test       | https://browser.geekbench.com/v4/cpu/16472881
    Single Core     | 552
    Multi Core      | 560
    Full Test       | https://browser.geekbench.com/v5/cpu/12378908
  • HostHatch STO Storage enabled IPv6
    choco@sto-01:~$ curl -sL yabs.sh | bash
    #                     v2021-12-28                    #
    Tue Jan 25 19:32:00 WIB 2022
    CPU cores  : 1 @ 1999.984 MHz
    RAM        : 473.1 MiB
    Swap       : 510.0 MiB
    Disk       : 456.7 GiB
    Read       | 2.54 MB/s      (636) | 18.94 MB/s     (296)
    Write      | 2.55 MB/s      (638) | 19.42 MB/s     (303)
    Total      | 5.09 MB/s     (1.2k) | 38.37 MB/s     (599)
    Read       | 63.58 MB/s     (124) | 99.67 MB/s      (97)
    Write      | 66.82 MB/s     (130) | 106.31 MB/s    (103)
    Total      | 130.41 MB/s    (254) | 205.98 MB/s    (200)
    Clouvider       | London, UK (10G)          | 482 Mbits/sec   | 3.74 Gbits/sec
    Online.net      | Paris, FR (10G)           | 2.65 Gbits/sec  | 2.47 Gbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 1.37 Gbits/sec
    WebHorizon      | Singapore (400M)          | 231 Mbits/sec   | 322 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 317 Mbits/sec   | 824 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 969 Mbits/sec   | 794 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 331 Mbits/sec   | 672 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 202 Mbits/sec   | 456 Mbits/sec
    Clouvider       | London, UK (10G)          | 3.91 Gbits/sec  | 2.40 Gbits/sec
    Online.net      | Paris, FR (10G)           | 3.47 Gbits/sec  | 1.62 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 3.83 Gbits/sec  | 4.21 Gbits/sec
    WebHorizon      | Singapore (400M)          | 314 Mbits/sec   | 297 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.17 Gbits/sec  | 1.05 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 730 Mbits/sec   | 653 Mbits/sec
    Single Core     | 497
    Multi Core      | 471
    Full Test       | https://browser.geekbench.com/v5/cpu/12383758
    Thanked by (2)cybertech chimichurri
    CPU cores  : 32 @ 3400.000 MHz
    RAM        : 125.8 GiB
    Swap       : 0.0 KiB
    Disk       : 14.0 TiB
    Read       | 1.03 GB/s   (259.0k) | 3.83 GB/s    (59.8k)
    Write      | 1.03 GB/s   (259.7k) | 3.85 GB/s    (60.1k)
    Total      | 2.07 GB/s   (518.8k) | 7.68 GB/s   (120.0k)
    Read       | 4.88 GB/s     (9.5k) | 4.95 GB/s     (4.8k)
    Write      | 5.14 GB/s    (10.0k) | 5.27 GB/s     (5.1k)
    Total      | 10.03 GB/s   (19.5k) | 10.23 GB/s    (9.9k)
    Clouvider       | London, UK (10G)          | 5.31 Gbits/sec  | 3.33 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.22 Gbits/sec  | 1.65 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.32 Gbits/sec  | 1.52 Gbits/sec
    Clouvider       | London, UK (10G)          | 6.52 Gbits/sec  | 2.86 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.27 Gbits/sec  | busy
    Clouvider       | NYC, NY, US (10G)         | 1.35 Gbits/sec  | 1.41 Gbits/sec
    Single Core     | 6844
    Multi Core      | 62694
    Full Test       | https://browser.geekbench.com/v4/cpu/16473838
    Single Core     | 1653
    Multi Core      | 14073
    Full Test       | https://browser.geekbench.com/v5/cpu/12404593
