Their network has some of the lowest ping I've seen to my location
From what it looks like, all of their HDD's are kept separately and they partition each HDD out individually. So no RAID or redundancy, but that's fine.
5120MB RAM
1024MB SWAP
55GB SSD RAID-10 SSD
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
Phoenix, AZ Location
SolusVM Control Panel
No refund/money back on this plan Note
5120MB RAM
1024MB SWAP
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars! Looking for cost-effective Managed/Anycast/DDoS-Protected/Geo DNS Services? Try ClouDNS (aff).
@Abdullah: Thank you for testing the same machine with different operating systems! m_ _m
I'm assuming you didn't tweak any of these and were just running YABS on a fresh install?
Any thoughts on why Ubuntu might be having ~30% lower IOPS than Alma or Rocky with block sizes other than 4k? In my amateur eyes, one would expect Linux 5 to perform better than Linux 4, unless it's something else than the kernel at fault here..?
greencloudvps 5555 packages
Coventry
NY
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2697 v3 @ 2.60GHz CPU cores : 5 @ 2599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 217.14 MB/s (54.2k) | 1.63 GB/s (25.5k) Write | 217.72 MB/s (54.4k) | 1.64 GB/s (25.6k) Total | 434.86 MB/s (108.7k) | 3.27 GB/s (51.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.81 GB/s (3.5k) | 1.81 GB/s (1.7k) Write | 1.90 GB/s (3.7k) | 1.93 GB/s (1.8k) Total | 3.71 GB/s (7.2k) | 3.74 GB/s (3.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 51.2 Mbits/sec | 73.8 Mbits/sec Online.net | Paris, FR (10G) | 1.85 Gbits/sec | 333 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 241 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 3.57 Gbits/sec | 1.63 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 2.65 Gbits/sec | 491 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 2.14 Gbits/sec | 442 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 145 Mbits/sec | 870 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 702 Multi Core | 3214 Full Test | https://browser.geekbench.com/v5/cpu/13048866MU
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 5 @ 2599.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 208.54 MB/s (52.1k) | 388.92 MB/s (6.0k) Write | 209.09 MB/s (52.2k) | 390.97 MB/s (6.1k) Total | 417.63 MB/s (104.4k) | 779.89 MB/s (12.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.23 GB/s (2.4k) | 1.21 GB/s (1.1k) Write | 1.30 GB/s (2.5k) | 1.29 GB/s (1.2k) Total | 2.53 GB/s (4.9k) | 2.51 GB/s (2.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 574 Mbits/sec | 847 Mbits/sec Online.net | Paris, FR (10G) | 931 Mbits/sec | 922 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 8.34 Mbits/sec | 338 Mbits/sec Clouvider | NYC, NY, US (10G) | 888 Mbits/sec | 893 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 862 Mbits/sec | 880 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 847 Mbits/sec | 846 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 600 Mbits/sec | 595 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 615 Mbits/sec | 848 Mbits/sec Online.net | Paris, FR (10G) | 918 Mbits/sec | 911 Mbits/sec WorldStream | The Netherlands (10G) | 914 Mbits/sec | busy WebHorizon | Singapore (400M) | 788 Mbits/sec | 420 Mbits/sec Clouvider | NYC, NY, US (10G) | 880 Mbits/sec | 882 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 828 Mbits/sec | 839 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 786 Multi Core | 3795 Full Test | https://browser.geekbench.com/v5/cpu/13048905RO
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2698 v3 @ 2.30GHz CPU cores : 5 @ 2299.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 205.13 MB/s (51.2k) | 1.40 GB/s (22.0k) Write | 205.67 MB/s (51.4k) | 1.41 GB/s (22.1k) Total | 410.80 MB/s (102.7k) | 2.82 GB/s (44.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.34 GB/s (2.6k) | 1.35 GB/s (1.3k) Write | 1.42 GB/s (2.7k) | 1.44 GB/s (1.4k) Total | 2.76 GB/s (5.4k) | 2.80 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 114 Mbits/sec | 225 Mbits/sec Online.net | Paris, FR (10G) | 758 Mbits/sec | 548 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 390 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 177 Mbits/sec | 164 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 543 Mbits/sec | 440 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 180 Mbits/sec | 117 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 234 Mbits/sec | 7.28 bits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 614 Multi Core | 2741 Full Test | https://browser.geekbench.com/v5/cpu/13048873TX
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz CPU cores : 5 @ 2299.994 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 150.70 MB/s (37.6k) | 835.32 MB/s (13.0k) Write | 151.10 MB/s (37.7k) | 839.71 MB/s (13.1k) Total | 301.81 MB/s (75.4k) | 1.67 GB/s (26.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.06 GB/s (2.0k) | 1.08 GB/s (1.0k) Write | 1.12 GB/s (2.1k) | 1.15 GB/s (1.1k) Total | 2.18 GB/s (4.2k) | 2.23 GB/s (2.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 37.3 Mbits/sec | 45.6 Mbits/sec Online.net | Paris, FR (10G) | 819 Mbits/sec | 176 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 573 Mbits/sec | 221 Mbits/sec Clouvider | NYC, NY, US (10G) | 855 Mbits/sec | 365 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 894 Mbits/sec | 214 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 877 Mbits/sec | 337 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 739 Mbits/sec | 169 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 37.0 Mbits/sec | 44.6 Mbits/sec Online.net | Paris, FR (10G) | 816 Mbits/sec | 121 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 535 Mbits/sec | 355 Mbits/sec Clouvider | NYC, NY, US (10G) | 863 Mbits/sec | 372 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 873 Mbits/sec | 467 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 573 Multi Core | 2616 Full Test | https://browser.geekbench.com/v5/cpu/13048919GA
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz CPU cores : 5 @ 2299.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 195.37 MB/s (48.8k) | 1.70 GB/s (26.7k) Write | 195.88 MB/s (48.9k) | 1.71 GB/s (26.8k) Total | 391.25 MB/s (97.8k) | 3.42 GB/s (53.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.15 GB/s (4.2k) | 2.20 GB/s (2.1k) Write | 2.26 GB/s (4.4k) | 2.34 GB/s (2.2k) Total | 4.42 GB/s (8.6k) | 4.54 GB/s (4.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 39.9 Mbits/sec | 50.4 Mbits/sec Online.net | Paris, FR (10G) | 764 Mbits/sec | 509 Mbits/sec WorldStream | The Netherlands (10G) | 783 Mbits/sec | 732 Mbits/sec WebHorizon | Singapore (400M) | busy | 207 Mbits/sec Clouvider | NYC, NY, US (10G) | 872 Mbits/sec | 900 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 877 Mbits/sec | 857 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 771 Mbits/sec | 789 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 711 Mbits/sec | 478 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 45.5 Mbits/sec | 59.2 Mbits/sec Online.net | Paris, FR (10G) | 774 Mbits/sec | 647 Mbits/sec WorldStream | The Netherlands (10G) | busy | 688 Mbits/sec WebHorizon | Singapore (400M) | 269 Mbits/sec | 289 Mbits/sec Clouvider | NYC, NY, US (10G) | 559 Mbits/sec | 881 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 481 Mbits/sec | 804 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 570 Multi Core | 2733 Full Test | https://browser.geekbench.com/v5/cpu/13048922CO
Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz CPU cores : 5 @ 1999.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 179.22 MB/s (44.8k) | 2.03 GB/s (31.7k) Write | 179.69 MB/s (44.9k) | 2.04 GB/s (31.9k) Total | 358.91 MB/s (89.7k) | 4.08 GB/s (63.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.31 GB/s (4.5k) | 2.24 GB/s (2.1k) Write | 2.43 GB/s (4.7k) | 2.39 GB/s (2.3k) Total | 4.75 GB/s (9.2k) | 4.63 GB/s (4.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 35.7 Mbits/sec | 41.7 Mbits/sec Online.net | Paris, FR (10G) | 479 Mbits/sec | 115 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | busy | 49.9 Mbits/sec Clouvider | NYC, NY, US (10G) | 490 Mbits/sec | busy Velocity Online | Tallahassee, FL, US (10G) | 413 Mbits/sec | 106 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 590 Mbits/sec | 163 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 397 Mbits/sec | 93.7 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 570 Multi Core | 2469 Full Test | https://browser.geekbench.com/v5/cpu/13048876Whatbox.ca 2TB HDD $15/month USA Shared
Greencloudvps 5555 deal
5120MB RAM
1024MB SWAP
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
$55 for 2 years WOWWWWWW
you got AZ 5555 vps finally, congrats
Hetzner Auction:
BillingServ - Easy, simple, and hassle-free online invoicing solution. Contact us today.
BaseServ Certified to ISO/IEC 27001:2013
WorldStream:
how much?
I'm paying around $150 $170 for that machien.
something
https://webhorizon.net
€38.65 it's a quick little machine.
wholesaleinternet
was supposed to be 100mbit unmetered but i won the lottery
racknerd giveaway
that disk speed
It’s a dinosaur
Nexril 12$/year
NanoKVM Netherlands new Node
Sultan Muda - Amazon Store
🇩🇪 myLoc / Webtropia DUS vServer Linux S KVM
Re-Run YABS - Virmach Amsterdam and New Jersey
Amsterdam
Mon 07 Mar 2022 08:12:42 PM EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2687W v2 @ 3.40GHz CPU cores : 1 @ 3399.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.1 GiB Swap : 256.0 MiB Disk : 24.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 21.74 MB/s (5.4k) | 104.54 MB/s (1.6k) Write | 21.76 MB/s (5.4k) | 105.09 MB/s (1.6k) Total | 43.51 MB/s (10.8k) | 209.63 MB/s (3.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 393.39 MB/s (768) | 380.78 MB/s (371) Write | 414.29 MB/s (809) | 406.14 MB/s (396) Total | 807.68 MB/s (1.5k) | 786.92 MB/s (767) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 386 Mbits/sec | 651 Mbits/sec Online.net | Paris, FR (10G) | 1.53 Gbits/sec | 306 Mbits/sec WorldStream | The Netherlands (10G) | 1.00 Gbits/sec | 759 Mbits/sec WebHorizon | Singapore (400M) | 415 Mbits/sec | 381 Mbits/sec Clouvider | NYC, NY, US (10G) | 659 Mbits/sec | 136 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 678 Mbits/sec | 133 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 736 Mbits/sec | 38.6 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 447 Mbits/sec | 160 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 477 Multi Core | 449 Full Test | https://browser.geekbench.com/v5/cpu/13297823Virmach - NJ
Tue 08 Mar 2022 01:30:29 AM GMT Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU cores : 1 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 981.3 MiB Swap : 256.0 MiB Disk : 19.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 46.06 MB/s (11.5k) | 481.28 MB/s (7.5k) Write | 46.13 MB/s (11.5k) | 483.81 MB/s (7.5k) Total | 92.20 MB/s (23.0k) | 965.09 MB/s (15.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 578.88 MB/s (1.1k) | 655.33 MB/s (639) Write | 609.64 MB/s (1.1k) | 698.97 MB/s (682) Total | 1.18 GB/s (2.3k) | 1.35 GB/s (1.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 53.6 Mbits/sec | 76.7 Mbits/sec Online.net | Paris, FR (10G) | 890 Mbits/sec | 179 Mbits/sec WorldStream | The Netherlands (10G) | 873 Mbits/sec | busy WebHorizon | Singapore (400M) | 550 Mbits/sec | 405 Mbits/sec Clouvider | NYC, NY, US (10G) | 938 Mbits/sec | 880 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 819 Mbits/sec | 258 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 898 Mbits/sec | 91.1 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 390 Mbits/sec | 295 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 413 Multi Core | 419 Full Test | https://browser.geekbench.com/v5/cpu/13298356VPS reviews and benchmarks |
greencloudvps 5555 Coventry
rebench after fixing ddos / abusers
greencloudvps
SG DC1
rebench with IPv6
best box ever due to RAID10
Benchmark from the Last Russian VPS I likely will purchase for now.
Chelyabinsk, 210RUB, why? RETN!!!!!!!!
AX101 Almalinux 8.5 kernel 4.18
AX101 RockyLinux 8.5 kernel 4.18
AX101 Ubuntu 20.04 kernel 5.11
G-Core Labs Poland, 238RUB, RETN!!!!!!!!!!!!!!!!!
How much for this server?
238RUB for the current Rate 1.90€
