What is the best option if I want to create an email using my domain name?
I have a domain name that ends with top and I want to make a mailbox with it. I know many platforms have this kind of service, but I want someone with experience to help me choose.
My daily requirement is to send and receive hundreds of emails every day, and I don't clean my mailbox very often. (Used as a notification email for a private forum)
It's not entirely clear what you're asking
If you need to send hundreds of emails everyday, you'd do best to use a mail-sending service like Amazon SES or MailChimp
I modified my description. Thanks for your suggestions, I will try them all.
Do you want both outgoing and incoming emails?
https://clients.mrvm.net
mxroute.com. No brainer.
I'm sure MX Route can handle it, but I can also see hundreds of forum email notifications a day stacking up in a mailbox being the sort of thing Jar might consider routing into a spam filter.
Indeed.
For ordinary email usage, MXroute is a great choice, but above, I took the OP's usage not to be ordinary email usage. (MXroute also has a limit of 300 emails per hour.)
Mind you multiple spam filters penalise the
.top
TLD during spam scores, including by MXRoute's themselves. Generally cheaper domains and e-mail don't play well due to the higher risk.Otherwise, cheapest option would be MXRoute which gives you both incoming and outgoing emails, although 300/hour per account, and if you abuse this you will be booted. If you need more, move on to Amazon SES or SendGrid.
Perfect! I don't think its limitations affect my usage.
Most of them are outgoing emails.
Mailing lists or forum notifications and such, Amazon SES.
Then combine it with a shared hosting account somewhere for the regular emails.
Thanks to the advice of experienced people, my problem was solved.
